How do I enable debug mode on Android?
If we ask you to send a log file to us, please follow these steps:
  1. Go to the splash screen in the Cryptomator app (start screen)
  2. Open “Settings”
  3. Scroll down and enable “Debug mode”
    => Debug mode is enabled, now reproduce the problem
  4. Go back to “Settings”
  5. Tap on “Send log file”
  6. Choose your mail app and send an email to the Cryptomator team
Please don’t forget to disable “Debug mode” after sending the email.
An Error Ocurred
Android App - brauche Hilfe das es immer abstürzt
Getting asked for password frequently
Not able to connect onedrive - Application 'b57...' is disabled
Android App - OneDrive Login does not open
Current Issue with Google Drive Connection in Cryptomator for Android and iOS
Nextcloud auf Android Smartphone
Cryptomator android google drive auth fails "this app is blocked"
Problem with Android
Connection to vault via webdav doesn't work
File-Upload stops with Error "Ein Fehler ist aufgetreten" - ErrorCode: 611A:JB59
No QNAP-NAS WebDAV access with Android
OneDrive on Android without Play Services?
GrapheneOS unable to log in to cloud services
Cannot upload files
Cannot open files in Android App ("Ein Fehler ist aufgetreten")
Google Drive could not be authenticated via microg
Onedrive Authentifizierung fehlgeschlagen
Fehlermeldung beim Foto-Upload
Dropbox authentication problem
Automatic photo upload does not upload everything
Cloudflare R2 bucket
How to connect Storj S3?
Cryptomator keep stopping when i downloaded thousands of files
Crash When Trying To Export
Connect to Linode Object Storage
I can't open my valut after reinstalling cryptomator- Android
.tmp Folder in Android
Automatic foto upload: Error message when vault is unlocked (OneDrive)
Unable to add an existing local vault on Android
Backblaze B2 Connection (Android)
App Android Snc Kdrive
Cryptomator 1.6.0: What you need to know
Fail to upload files to yandex drive vault
S3 authentication problem
"Google Drive could not be authenticated" running Android app on CalyxOS with MicroG
Can¨t enable biometric authentication
Cryptomator Android apk - can't connect to container on qnap via webdav
Auto upload does not start
pCloud compatibility
Getting "An error occurred" on Android
Feature Request:Log in Multipule Onedrive Accounts
"Vault not found" in Android App
How can I connect Cryptomator to pcloud on my Android devices?
Cryptomator and SFTP support
Unable to open my vault even after providing right password and no data is altered. Help me Dev
Vault Local Custom Location Catastrophic Failure
Yandex disk login troubles
Cryptomator keeps stopping when adding local storage sd card
Multiple files upload fails
Upgraded to 1.5.1 Version, Opened In Android Cryptomator which in result removed all files from OneDrive
Open Exisiting Vault "Error Occured"
Authentication failed - webdav - Android
1 tresor lässt sich nich verbinden
Auto photo upload
SSL pinning error / certificate pinning failure (Android)
Android 10 can't use finger unlock
Android App und Synology
Which Android folder does automatic picture upload get the pictures from?
Accessing cryptomator vault which is synced by nextcloud
Photo upload not working in OneDrive
Automatischer Foto-Upload
Android app can't access university-provided Google Drive account
Attempt to open Cryptomator vault in DropBox reports "an error occurred"
An error occurred when trying to open an existing vault in Google drive
An Error occured when adding a OneDrive vault
Closing Cryptomator in Android breaks connection to Google Drive
Cannot access my vaults on Nextcloud from Android
A post was merged into an existing topic: Authentication failed - webdav - Android
