To enable debug mode,
- start Cryptomator and go into the settings,
- enable the checkbox
Debug Mode, and
restart Cryptomator to make the setting effective.(no longer needed since version 1.4.6)
Debug mode adds additional messages to the log file. You may enable debug mode if we request a log file to allow us to view all relevant details.
With debug mode enabled, the paths of all files you encrypt are stored in the log file – so do not forget to disable it after you did what you wanted to.
