Drive not mounted - system error 67
After installing the latest version of CM I cannot mount a vault. I did not use CM before. I am on Win7 and I want to move on from BoxCryptor.
I did not find a solution here. I have additionally installed Dokany und VC++ 2017 RT und rebooted, but all to no avail.
Any help is appreciated.
Log follows:
12:30:11.234 [main] INFO  org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.10 on Windows 7 6.1 (amd64)
12:30:11.242 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
12:30:11.243 [main] DEBUG org.cryptomator.launcher.IpcFactory - [Client] Failed to connect.
12:30:11.485 [main] DEBUG org.cryptomator.launcher.IpcFactory - [Server] Wrote IPC port 49182 to C:\Users\Frank\AppData\Roaming\Cryptomator\ipcPort.bin
12:30:11.487 [main] INFO  o.c.launcher.IpcProtocolImpl - Received launch args:
12:30:11.489 [main] DEBUG org.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI...
12:30:11.775 [JavaFX Application Thread] INFO  org.cryptomator.launcher.Cryptomator - JavaFX application started.
12:30:11.805 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
12:30:11.805 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language "de" and region "DE"
12:30:11.809 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de_DE.txt
12:30:11.809 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de.txt
12:30:11.975 [JavaFX Application Thread] INFO  org.cryptomator.jni.JniModule - loaded WinFunctions.dll
12:30:12.035 [JavaFX Application Thread] INFO  o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
12:30:17.879 [JavaFX Application Thread] DEBUG o.c.k.WindowsProtectedKeychainAccess - Attempting to load keychain from C:\Users\Frank\AppData\Roaming\Cryptomator\keychain.json
12:30:34.365 [Background Thread 2] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
12:30:35.258 [Background Thread 2] WARN  org.cryptomator.ui.model.VaultModule - Using WebDAV, because Dokany is not supported.
12:30:35.304 [Background Thread 2] INFO  org.eclipse.jetty.util.log - Logging initialized @25032ms to org.eclipse.jetty.util.log.Slf4jLog
12:30:35.404 [Background Thread 2] INFO  o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
12:30:35.447 [Background Thread 2] INFO  o.e.jetty.server.AbstractConnector - Started ServerConnector@4c223a24{HTTP/1.1,[http/1.1]}{127.0.0.1:42427}
12:30:35.451 [Background Thread 2] INFO  org.eclipse.jetty.server.Server - jetty-9.4.17.v20190418; built: 2019-04-18T19:45:35.259Z; git: aa1c656c315c011c01e7b21aabb04066635b9f67; jvm 11.0.2+9
12:30:35.482 [Background Thread 2] INFO  o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@3b0d4b9b{/,null,AVAILABLE}
12:30:35.482 [Background Thread 2] INFO  org.eclipse.jetty.server.Server - Started @25211ms
12:30:35.482 [Background Thread 2] INFO  o.c.frontend.webdav.WebDavServer - WebDavServer started.
12:30:35.522 [Background Thread 2] INFO  org.eclipse.jetty.server.session - DefaultSessionIdManager workerName=node0
12:30:35.522 [Background Thread 2] INFO  org.eclipse.jetty.server.session - No SessionScavenger set, using defaults
12:30:35.523 [Background Thread 2] INFO  org.eclipse.jetty.server.session - node0 Scavenging every 600000ms
12:30:35.531 [Background Thread 2] INFO  o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
12:30:35.532 [Background Thread 2] INFO  o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
12:30:35.532 [Background Thread 2] INFO  o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
12:30:35.532 [Background Thread 2] INFO  o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@47c203d{/rk5YRilcQYjk/PrivateDokumente,null,AVAILABLE}
12:30:35.532 [Background Thread 2] INFO  o.c.f.w.s.WebDavServletController - WebDavServlet started: /rk5YRilcQYjk/PrivateDokumente
12:30:35.536 [Background Thread 2] INFO  o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/rk5YRilcQYjk/PrivateDokumente using org.cryptomator.frontend.webdav.mount.WindowsMounter
12:30:35.560 [Background Thread 2] DEBUG o.c.f.webdav.mount.WindowsMounter - Original Registry value for ProxyOverride is: <local>;cryptomator-vault:42427;cryptomator-vault;127.0.0.1;127.0.0.1:42427
12:30:35.563 [Background Thread 2] DEBUG o.c.f.webdav.mount.WindowsMounter - Setting Registry value for ProxyOverride to: <local>;cryptomator-vault:42427;cryptomator-vault;127.0.0.1;127.0.0.1:42427
12:30:35.615 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
org.cryptomator.ui.model.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: Systemfehler 67 aufgetreten.
Der Netzwerkname wurde nicht gefunden.
	at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:63)
	at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:47)
	at org.cryptomator.ui.model.Vault.unlock(Vault.java:113)
	at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:439)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: Systemfehler 67 aufgetreten.
	at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:60)
	... 12 common frames omitted
Installing Dokany does not change anything since you are using WebDAV as the unlocked vault provider. (; You can change this in the settings.
Otherwise, there are a ton of posts about Systemerror 67 regarding crpytomator:
My first suggestion is to check up the names and order of items in the registry keys of:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\NetworkProvider\HwOrder
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\NetworkProvider\Order
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\NetworkProvider\ProviderOrder
Thanks for finding the posts for me. I will check.
Service “WebClient” was deactivated. Possibly as a result of some hardening, unrelated to CM.
