Update: It works in both directions now
For more info, see my new Github repository
Orginal Post:
Warning upfront: this post is only relevant for power users on Windows who know what they’re doing. I’m quite reluctant to guide non-programmers through the process of installing all prerequisites to run this script and deal with the consequences when something goes wrong. So: use at your own risk!
Background: after doing a sync between two PCs yesterday I got a sync error on an encrypted vault file. Apparently the file was modified on both PCs before the sync. To solve it, I’d need to know which decrypted file it represents, so I can inspect the file on both ends to fix the conflict manually.
However, since there is no way to map encrypted files in a vault to their decrypted file paths, that’s a dead stop in fixing such issues. I’ve been hit by this issue a couple of times in the past already. So far I resorted to a manual procedure to find out which file(s) were involved;
- unlock the vault on one PC,
- open a command prompt and write a recursive dir listing for the unlocked vault into a text file,
- browse to the conflicting encrypted file in Cryptomator’s encrypted storage folder,
- move the file over to e.g. the desktop,
- re-do the dir listing to another text file,
- restore the encrypted file back to it’s proper location,
- diff the two dir listing text files to see which file is absent in one of them.
Quite a tedious procedure, especially since the dir command also lists the special ‘.’ and ‘…’ folder entries, but uses the current time as their time stamp. Since the two dir listing files are not created at exactly the same time, all these entries cause false positives in the diff. So for large vaults I also preprocessed the text files to strip out these lines with a regex.
And yesterday was the time I decided “enough is enough - this can be scripted”. So, see below the Python script that does this process for you. You need to have Python 3 installed with the win32com and wx packages. See the source code for the full instructions on how to use the script.
Edit: Script see GitHub Link
