Existing vault cannot be migrated. I use:
macOS 11.4
Cryptomator 1.5.15
macFUSE 4.1.2
I get the following error message:
org.cryptomator.cryptofs.migration.api.NoApplicableMigratorException
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:111)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:117)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:140)
The hints and tips on Github and here in the forum for the same errors, do not help. What I have done so far:
- changed vault (switching)
- removed vault and added it again
- removed all vaults
- created a completely new vault (works)
- updated macFUSE
- sync checked
There are other old vaults where migration worked. Just not for this one. Mobile (iOS), however, the vault and files can still be opened. According to the masterkey.cryptomator file, this is version 3.
...,"version":3}
Any tips or ideas?
Thanks,
Spezi
In return I bought a support certificate.
