[HELP!] No files after upgrade 1.5.17 to 1.6.1
Hello community
After upgrade from 1.5.17 to last 1.6.1 the vault open but no files there.
During unlock vault ask for migrate to new version and then no files :sob:
LOGS:
health check → ******************************************** Cryptomator Vault Health Repo - Pastebin.com
other log → 17:47:16.441 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Crypto - Pastebin.com
Can someone help me?
Thanks
The migration does not touch your files, as described here: Vault Format 8
What virtual file system provider is selected in the general preferences, virtual volume tab? If it is WebDAV, you are suffering of Issue #1273. I suggest to switch, why not try WinFSP?
Thanks!
You save my day!
i’ve installed WinFSP and files shows again!
