Having issue with this even after reinstallation
	at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: ru.serce.jnrfuse.FuseException: Unable to mount FS
	at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:46)
	at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
	... 12 more
	at org.cryptomator.frontend.fuse.mount.AbstractMounter.lambda$mount$0(AbstractMounter.java:26)
	... 1 more
	... 2 more
Looks like this.
anyone could help on the above?
Re-installing or updating macFUSE should solve this problem.
actually I did try but to no avail.
Did you also give the necessary permissions to macFUSE? We don’t have a detailed documentation ourselves but this one covers it very well: https://docs.hedge.video/postlab/drive/fuse
If nothing works and even though I would recommend to use macFUSE, you can still use WebDAV (go to Preferences → Virtual Drive) if you can’t get FUSE to work.
Thanks, I just reinstalled everything from scratch again and use macFuse allowing all necessary permission. Now it works!! Thank you.
