I keep getting this when trying to create a new vault. Using Mac Mojave and Fuse and locating the vault on my internal hard drive. Help! Thanks, Harry
Data Below:
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:107)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:45)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:105)
... 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:43)
... 13 more
... 14 more
... 12 more
... 13 more
... 14 more
