Since we have finalized the new vault format, we are now pleased to announce the availability of 1.5.0-beta1, which can be downloaded here. Not many new features, mostly under-the-hood improvements and new localizations.
Needless to say, we strongly recommend making backups.
We’re also working on compatibility for our mobile apps to use the new vault format.
The new beta is working great and - more importantly - looks great.
One problem though. It was late, I wasn’t really watching what is going on… now I can’t access files from iOS. Do you have a roadmap on updating TestFlight to a version that can support the new vault format?
Without naming any dates, we’ll release a beta version for iOS via TestFlight as soon as possible. The implementation is mostly done so it’s really not that far away. For anyone interested, same goes for the Android app, we’ll release a beta version there as well.
Great to hear, going to test it with google drive file stream. I don’t expect much success but it’s worth a try, thanks for making this awesome program.
It’s done also the Android 1.5.0 beta version is released and does support the basic operations of vault format 7. The support for long file names will be added in the next beta update in a few days. Apart of that, we introduce a few other features and fixes (the most important):
Added offline cache
Added option to lock vault immediately when Cryptomator is closed or in background
Added possibility to close the vault while a file is open after the timeout of the vault (changes may get lost)
Fixed and improved auto photo upload (e.g., after device reboot or on Android 10 under certain conditions)
Improved general stability
You can test this version by subscribing to our beta channel. We’re really interested in your feedback!
Hi @overheadhunter . I started with Version 1.5 and have already some feedback.
To be sure to have the easiest way for you (and other testers) to work with that feedback, where/how do you want me (and others) to send it to? One post for each issue here in the board? all issues here in this thread? or only on github? or is there any other way for feedback that I just don’t noticed?
Could not find specific information about the feedback process in the github release notes.
For general feedback, feel free to just reply on this thread.
If you have rough ideas that you want to discuss on a non-technical basis, rather create a new thread in this forum. Once you feel you can express the idea as a well-defined feature request, head over to GitHub.
If you found reproducable bugs, better create a new issue on GitHub directly (each bug in a separate issue, please). Please look for existing issues first. If you’re unsure, if an existing issue is the same or just related, create a new issue. We can still mark it as a duplicate.
If you miss features that were present in 1.4.x, use GitHub as well.
The rule of thumb is: If you are 90% certain that the only discussion will be of technical nature, directly create issues on GitHub. If you think you have some ideas or feedback that might be seen differently depending on the opinion of other users and can’t yet be clearly poured into a distinctive feature request, try to keep the discussion in the forum.
(Note to myself: We need to document this in our official docs)
Thank you.
I have created some github issues, a new post in this board, and heres my general feedback so far: it looks great to me. I had only one major issue when opening my vaults that only could be solved by killing the cryptomator process. unfortunately I am not able to reproduce it, so I just will have an eye on that.
As soon as my syncs are done (takes some time), Im happy to have a look at the iOS app. @overheadhunter: just a minor question: is there a reason why there is a progress bar when migrating a vault with webdav, but there is none with dokany (well, there is one but it does not show the actual progress state but only that the progress is still running) ?
Migration doesn’t know how you want to mount a drive. The progress bar only depends on the number of items in the vault and the storage medium it is on. Small vaults on SSDs will migrate so quickly that you will only see the migration preparation but no actual progress. It just happens instantaneously.
I think we should also add a “vault version history” in the docs, I’ll put it on my to-do list. I created a gist some months ago that summarizes the changes from v6 to v7:
