Cryptomator charsing @ Ubuntu 20.04
I have a fresh install of Ubuntu 20.04 with Cryptomator.
But when I try to unlock a Vault the Cryptomator keeps crashing each time, giving me this error:
11:59:58.777 [App Background Thread 003] DEBUG o.c.common.vaults.FuseVolume - Successfully checked custom mount point: /home/user/Documents
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007fb01619a189, pid=101301, tid=101600
# JRE version: OpenJDK Runtime Environment Zulu14.29+23-CA (14.0.2+12) (build 14.0.2+12)
# Java VM: OpenJDK 64-Bit Server VM Zulu14.29+23-CA (14.0.2+12, mixed mode, tiered, compressed oops, g1 gc, linux-amd64)
# Problematic frame:
# C  [jffi4891430637700450402.so+0x7189]
# Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport %p %s %c %d %P %E" (or dumping to /home/user/core.101301)
# An error report file with more information is saved as:
# /home/user/hs_err_pid101301.log
# If you would like to submit a bug report, please visit:
#   http://www.azulsystems.com/support/
Any idea aboutm how can I fix it?
Thanks
A post was merged into an existing topic: Cryptomator crashes with SIGSEGV (0xb) when unlocking vault
