Cryptomator crashes with SIGSEGV (0xb) when unlocking vault
I am using version 1.5.3 on OpenSUSE tumbleweed. Just did a distribution upgrade, and everything seems fine except now cryptomator crashes when I try unlocking a vault. Output from the terminal is:
12:30:54.815 [main] DEBUG org.cryptomator.common.Environment - java.library.path: /tmp/.mount_cryptowE2Ty5/lib/app:/tmp/.mount_cryptowE2Ty5/bin
12:30:54.818 [main] DEBUG org.cryptomator.common.Environment - user.language: en
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - user.region: null
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - logback.configurationFile: null
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.ipcPortPath: ~/.config/Cryptomator/ipcPort.bin:~/.Cryptomator/ipcPort.bin
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.keychainPath: null
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.minPwLength: null
12:30:54.819 [main] DEBUG org.cryptomator.common.Environment - cryptomator.buildNumber: appimage-1
12:30:54.843 [main] DEBUG org.cryptomator.common.ShutdownHook - Registered shutdown hook.
12:30:54.922 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/hornet/.config/Cryptomator/settings.json
12:30:54.980 [main] INFO org.cryptomator.common.settings.SettingsProvider - Settings loaded from /home/hornet/.config/Cryptomator/settings.json
12:30:55.342 [main] INFO  org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.3 on Linux 5.6.8-1-default (amd64)
12:30:55.660 [JavaFX Application Thread] INFO  o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
12:31:02.248 [JavaFX Application Thread] INFO  o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.3, lastest version: 1.5.3
12:31:16.029 [App Background Thread 004] INFO  org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f62b16ed189, pid=23578, tid=23710
# JRE version: OpenJDK Runtime Environment Zulu14.28+21-CA (14.0.1+8) (build 14.0.1+8)
# Java VM: OpenJDK 64-Bit Server VM Zulu14.28+21-CA (14.0.1+8, mixed mode, tiered, compressed oops, g1 gc, linux-amd64)
# Problematic frame:
# C  [jffi17413466840685389187.so+0x7189]
# Core dump will be written. Default location: Core dumps may be processed with "/bin/false" (or dumping to /home/hornet/bin/core.23578)
# An error report file with more information is saved as:
# /home/hornet/bin/hs_err_pid23578.log
# If you would like to submit a bug report, please visit:
#   http://www.azulsystems.com/support/
Interesting to see, that GitHub Actions uses a Zulu JVM. That said, the problem seems to be jffi-related, i.e. near the Java/C interface of some module.
Can you please post the contents of /home/hornet/bin/hs_err_pid23578.log as well?
Can’t upload an attachment, and the file is too large to put in one post. Here is the first part:
---------------  S U M M A R Y ------------
Command Line: -Djava.library.path=/tmp/.mount_cryptowE2Ty5/lib/app:/tmp/.mount_cryptowE2Ty5/bin -Djava.launcher.path=/tmp/.mount_cryptowE2Ty5/bin -Dcryptomator.logDir=~/.local/share/Cryptomator/logs -Dcryptomator.settingsPath=~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json -Dcryptomator.ipcPortPath=~/.config/Cryptomator/ipcPort.bin:~/.Cryptomator/ipcPort.bin -Dcryptomator.mountPointsDir=~/.local/share/Cryptomator/mnt -Dcryptomator.buildNumber=appimage-1 -Xss2m -Xmx512m org.cryptomator.launcher.Cryptomator
Host: AMD Ryzen 5 2600 Six-Core Processor, 12 cores, 31G, openSUSE Tumbleweed
Time: Sat May  9 12:31:16 2020 EDT elapsed time: 22 seconds (0d 0h 0m 22s)
---------------  T H R E A D  ---------------
Current thread is native thread
Stack: [0x00007f62b08e5000,0x00007f62b10e4000],  sp=0x00007f62b10e2aa0,  free space=8182k
Native frames: (J=compiled Java code, A=aot compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [libffi.so.8+0x44de]
siginfo: si_signo: 11 (SIGSEGV), si_code: 128 (SI_KERNEL), si_addr: 0x0000000000000000
Register to memory mapping:
RAX=0x0 is NULL
RBX=
[error occurred during error reporting (printing register info), id 0xb, SIGSEGV (0xb) at pc=0x00007f643ff2bf6b]
Registers:
RAX=0x0000000000000000, RBX=0x00007f62b10e2cc0, RCX=0xf5158d4cfa1e0ff3, RDX=0x0000000000010004
RSP=0x00007f62b10e2aa0, RBP=0x00007f62b10e2b00, RSI=0x00007f62b10e2ac0, RDI=0x00007f62942e1b00
R8 =0x0000000000000001, R9 =0x00007f62b10e2cc0, R10=0x00007f62942e1b60, R11=0x00007f62b2db0df0
R12=0x00007f62b10e2ac0, R13=0xf5158d4cfa1e0ff3, R14=0x00007f62942e1b00, R15=0x00007f62b10e2c90
RIP=0x00007f62b16ed189, EFLAGS=0x0000000000010246, CSGSFS=0x002b000000000033, ERR=0x0000000000000000
  TRAPNO=0x000000000000000d
Top of Stack: (sp=0x00007f62b10e2aa0)
0x00007f62b10e2aa0:   7fffffffffffffff 00007f62b10e2b10
0x00007f62b10e2ab0:   0000000000000000 00007f62b10e2b78
0x00007f62b10e2ac0:   00007f62b10e2b7c cecfd4a7aa226900
0x00007f62b10e2ad0:   00007f62b10e2b10 00007f62b10e2cc0
Instructions: (pc=0x00007f62b16ed189)
0x00007f62b16ed089:   ce 48 8d 04 40 4c 8d 24 c5 00 00 00 00 48 8b 07
0x00007f62b16ed099:   4c 03 63 20 ff 90 a8 00 00 00 48 85 c0 49 89 44
0x00007f62b16ed0a9:   24 08 74 09 83 43 2c 01 4c 89 e2 eb be 48 8b 05
0x00007f62b16ed0b9:   23 a1 20 00 48 8d 15 64 6e 00 00 4c 89 ef 48 8b
0x00007f62b16ed0c9:   30 31 c0 e8 df e6 ff ff 31 d2 eb 9f 66 66 2e 0f
0x00007f62b16ed0d9:   1f 84 00 00 00 00 00 55 48 89 e5 41 56 49 89 fe
0x00007f62b16ed0e9:   41 55 49 89 d5 41 54 53 8b 42 2c 85 c0 7e 2b 45
0x00007f62b16ed0f9:   31 e4 31 db 0f 1f 00 49 8b 55 20 49 8b 06 4c 89
0x00007f62b16ed109:   f7 41 83 c4 01 48 8b 74 1a 08 48 83 c3 18 ff 90
0x00007f62b16ed119:   b0 00 00 00 45 39 65 2c 7f dd 49 8b 7d 20 e8 74
0x00007f62b16ed129:   e7 ff ff 49 8b 7d 18 be 01 00 00 00 e8 e6 e8 ff
0x00007f62b16ed139:   ff 5b 41 5c 4c 89 ef 41 5d 41 5e c9 e9 56 e7 ff
0x00007f62b16ed149:   ff 66 0f 1f 44 00 00 55 48 89 e5 41 57 49 89 f7
0x00007f62b16ed159:   41 56 49 89 fe 41 55 49 89 cd 41 54 4c 8d 65 c0
0x00007f62b16ed169:   53 4c 89 e6 48 83 ec 38 48 89 55 a8 ba 04 00 01
0x00007f62b16ed179:   00 64 48 8b 04 25 28 00 00 00 48 89 45 c8 31 c0
0x00007f62b16ed189:   48 8b 41 10 48 8b 58 10 48 8b 03 48 89 df ff 50
0x00007f62b16ed199:   30 85 c0 0f 85 08 02 00 00 45 31 e4 48 8b 7d c0
0x00007f62b16ed1a9:   48 8b 07 ff 90 20 07 00 00 84 c0 0f 85 de 01 00
0x00007f62b16ed1b9:   00 49 8b 55 10 8b 42 30 85 c0 0f 84 97 00 00 00
0x00007f62b16ed1c9:   41 8b 46 04 41 8b 7e 04 83 c0 01 48 8d 04 c5 1e
0x00007f62b16ed1d9:   00 00 00 48 c1 e8 04 48 c1 e0 04 48 29 c4 48 8d
0x00007f62b16ed1e9:   4c 24 0f 48 83 e1 f0 85 ff 0f 8e 7f 01 00 00 4c
0x00007f62b16ed1f9:   8b 45 a8 4c 8d 15 65 6d 00 00 48 89 ce 45 31 c9
0x00007f62b16ed209:   eb 25 0f 1f 44 00 00 48 c7 06 00 00 00 00 41 8b
0x00007f62b16ed219:   7e 04 41 83 c1 01 49 83 c0 08 48 83 c6 08 44 39
0x00007f62b16ed229:   cf 0f 8e 47 01 00 00 48 c7 06 00 00 00 00 49 8b
0x00007f62b16ed239:   46 08 48 89 f2 48 29 ca 48 8b 14 02 66 83 7a 0a
0x00007f62b16ed249:   0e 77 c4 0f b7 42 0a 49 63 04 82 4c 01 d0 ff e0
0x00007f62b16ed259:   0f 1f 80 00 00 00 00 48 8b 45 a8 48 8b 7d c0 48
0x00007f62b16ed269:   8d 4d b0 4c 89 7d b0 48 89 45 b8 48 8b 07 48 8b
0x00007f62b16ed279:   52 08 49 8b 75 08 ff 90 f8 01 00 00 48 8b 7d c0
Stack slot to memory mapping:
stack at sp + 0 slots:
[error occurred during error reporting (inspecting top of stack), id 0xb, SIGSEGV (0xb) at pc=0x00007f643ff2bf6b]
---------------  P R O C E S S  ---------------
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap address: 0x00000000e0000000, size: 512 MB, Compressed Oops mode: 32-bit
Narrow klass base: 0x0000000000000000, Narrow klass shift: 3
Compressed class space size: 1073741824 Address: 0x0000000100000000
Heap:
 garbage-first heap   total 81920K, used 36064K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 17 young (17408K), 1 survivors (1024K)
 Metaspace       used 49448K, capacity 51137K, committed 51328K, reserved 1093632K
  class space    used 6530K, capacity 7187K, committed 7296K, reserved 1048576K
Heap Regions: E=young(eden), S=young(survivor), O=old, HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, OA=open archive, CA=closed archive, TAMS=top-at-mark-start (previous, next)
|   0|0x00000000e0000000, 0x00000000e0100000, 0x00000000e0100000|100%| O|  |TAMS 0x00000000e0100000, 0x00000000e0000000| Untracked
|   1|0x00000000e0100000, 0x00000000e0200000, 0x00000000e0200000|100%| O|  |TAMS 0x00000000e0200000, 0x00000000e0100000| Untracked
|   2|0x00000000e0200000, 0x00000000e0300000, 0x00000000e0300000|100%| O|  |TAMS 0x00000000e0300000, 0x00000000e0200000| Untracked
|   3|0x00000000e0300000, 0x00000000e0400000, 0x00000000e0400000|100%| O|  |TAMS 0x00000000e0400000, 0x00000000e0300000| Untracked
|   4|0x00000000e0400000, 0x00000000e0495400, 0x00000000e0500000| 58%| O|  |TAMS 0x00000000e0495400, 0x00000000e0400000| Untracked
|   5|0x00000000e0500000, 0x00000000e0600000, 0x00000000e0600000|100%|HS|  |TAMS 0x00000000e0600000, 0x00000000e0500000| Complete
|   6|0x00000000e0600000, 0x00000000e0700000, 0x00000000e0700000|100%|HC|  |TAMS 0x00000000e0700000, 0x00000000e0600000| Complete
|   7|0x00000000e0700000, 0x00000000e0800000, 0x00000000e0800000|100%| O|  |TAMS 0x00000000e0800000, 0x00000000e0700000| Untracked
|   8|0x00000000e0800000, 0x00000000e0900000, 0x00000000e0900000|100%| O|  |TAMS 0x00000000e0900000, 0x00000000e0800000| Untracked
|   9|0x00000000e0900000, 0x00000000e0a00000, 0x00000000e0a00000|100%| O|  |TAMS 0x00000000e0a00000, 0x00000000e0900000| Untracked
|  10|0x00000000e0a00000, 0x00000000e0b00000, 0x00000000e0b00000|100%| O|  |TAMS 0x00000000e0b00000, 0x00000000e0a00000| Untracked
|  11|0x00000000e0b00000, 0x00000000e0c00000, 0x00000000e0c00000|100%| O|  |TAMS 0x00000000e0c00000, 0x00000000e0b00000| Untracked
|  12|0x00000000e0c00000, 0x00000000e0d00000, 0x00000000e0d00000|100%| O|  |TAMS 0x00000000e0d00000, 0x00000000e0c00000| Untracked
|  13|0x00000000e0d00000, 0x00000000e0e00000, 0x00000000e0e00000|100%| O|  |TAMS 0x00000000e0e00000, 0x00000000e0d00000| Untracked
|  14|0x00000000e0e00000, 0x00000000e0f00000, 0x00000000e0f00000|100%|HS|  |TAMS 0x00000000e0f00000, 0x00000000e0e00000| Complete
|  15|0x00000000e0f00000, 0x00000000e1000000, 0x00000000e1000000|100%|HC|  |TAMS 0x00000000e1000000, 0x00000000e0f00000| Complete
|  16|0x00000000e1000000, 0x00000000e1100000, 0x00000000e1100000|100%| O|  |TAMS 0x00000000e1100000, 0x00000000e1000000| Untracked
|  17|0x00000000e1100000, 0x00000000e1200000, 0x00000000e1200000|100%| O|  |TAMS 0x00000000e1200000, 0x00000000e1100000| Untracked
|  18|0x00000000e1200000, 0x00000000e1240a00, 0x00000000e1300000| 25%| O|  |TAMS 0x00000000e1240a00, 0x00000000e1200000| Untracked
|  19|0x00000000e1300000, 0x00000000e1300000, 0x00000000e1400000|  0%| F|  |TAMS 0x00000000e1300000, 0x00000000e1300000| Untracked
|  20|0x00000000e1400000, 0x00000000e1500000, 0x00000000e1500000|100%| O|  |TAMS 0x00000000e1500000, 0x00000000e1400000| Untracked
|  21|0x00000000e1500000, 0x00000000e1600000, 0x00000000e1600000|100%| O|  |TAMS 0x00000000e1600000, 0x00000000e1500000| Untracked
|  22|0x00000000e1600000, 0x00000000e1600000, 0x00000000e1700000|  0%| F|  |TAMS 0x00000000e1600000, 0x00000000e1600000| Untracked
|  23|0x00000000e1700000, 0x00000000e1700000, 0x00000000e1800000|  0%| F|  |TAMS 0x00000000e1700000, 0x00000000e1700000| Untracked
|  24|0x00000000e1800000, 0x00000000e1800000, 0x00000000e1900000|  0%| F|  |TAMS 0x00000000e1800000, 0x00000000e1800000| Untracked
|  25|0x00000000e1900000, 0x00000000e1900000, 0x00000000e1a00000|  0%| F|  |TAMS 0x00000000e1900000, 0x00000000e1900000| Untracked
|  26|0x00000000e1a00000, 0x00000000e1a00000, 0x00000000e1b00000|  0%| F|  |TAMS 0x00000000e1a00000, 0x00000000e1a00000| Untracked
|  27|0x00000000e1b00000, 0x00000000e1b00000, 0x00000000e1c00000|  0%| F|  |TAMS 0x00000000e1b00000, 0x00000000e1b00000| Untracked
|  28|0x00000000e1c00000, 0x00000000e1c00000, 0x00000000e1d00000|  0%| F|  |TAMS 0x00000000e1c00000, 0x00000000e1c00000| Untracked
|  29|0x00000000e1d00000, 0x00000000e1d00000, 0x00000000e1e00000|  0%| F|  |TAMS 0x00000000e1d00000, 0x00000000e1d00000| Untracked
|  30|0x00000000e1e00000, 0x00000000e1e00000, 0x00000000e1f00000|  0%| F|  |TAMS 0x00000000e1e00000, 0x00000000e1e00000| Untracked
|  31|0x00000000e1f00000, 0x00000000e1f00000, 0x00000000e2000000|  0%| F|  |TAMS 0x00000000e1f00000, 0x00000000e1f00000| Untracked
|  32|0x00000000e2000000, 0x00000000e2000000, 0x00000000e2100000|  0%| F|  |TAMS 0x00000000e2000000, 0x00000000e2000000| Untracked
|  33|0x00000000e2100000, 0x00000000e21622f0, 0x00000000e2200000| 38%| S|CS|TAMS 0x00000000e2100000, 0x00000000e2100000| Complete
|  34|0x00000000e2200000, 0x00000000e2200000, 0x00000000e2300000|  0%| F|  |TAMS 0x00000000e2200000, 0x00000000e2200000| Untracked
|  35|0x00000000e2300000, 0x00000000e2300000, 0x00000000e2400000|  0%| F|  |TAMS 0x00000000e2300000, 0x00000000e2300000| Untracked
|  36|0x00000000e2400000, 0x00000000e2400000, 0x00000000e2500000|  0%| F|  |TAMS 0x00000000e2400000, 0x00000000e2400000| Untracked
|  37|0x00000000e2500000, 0x00000000e2500000, 0x00000000e2600000|  0%| F|  |TAMS 0x00000000e2500000, 0x00000000e2500000| Untracked
|  38|0x00000000e2600000, 0x00000000e2600000, 0x00000000e2700000|  0%| F|  |TAMS 0x00000000e2600000, 0x00000000e2600000| Untracked
|  39|0x00000000e2700000, 0x00000000e2700000, 0x00000000e2800000|  0%| F|  |TAMS 0x00000000e2700000, 0x00000000e2700000| Untracked
|  40|0x00000000e2800000, 0x00000000e2800000, 0x00000000e2900000|  0%| F|  |TAMS 0x00000000e2800000, 0x00000000e2800000| Untracked
|  41|0x00000000e2900000, 0x00000000e2900000, 0x00000000e2a00000|  0%| F|  |TAMS 0x00000000e2900000, 0x00000000e2900000| Untracked
|  42|0x00000000e2a00000, 0x00000000e2a00000, 0x00000000e2b00000|  0%| F|  |TAMS 0x00000000e2a00000, 0x00000000e2a00000| Untracked
|  43|0x00000000e2b00000, 0x00000000e2b00000, 0x00000000e2c00000|  0%| F|  |TAMS 0x00000000e2b00000, 0x00000000e2b00000| Untracked
|  44|0x00000000e2c00000, 0x00000000e2c00000, 0x00000000e2d00000|  0%| F|  |TAMS 0x00000000e2c00000, 0x00000000e2c00000| Untracked
|  45|0x00000000e2d00000, 0x00000000e2d00000, 0x00000000e2e00000|  0%| F|  |TAMS 0x00000000e2d00000, 0x00000000e2d00000| Untracked
|  46|0x00000000e2e00000, 0x00000000e2e00000, 0x00000000e2f00000|  0%| F|  |TAMS 0x00000000e2e00000, 0x00000000e2e00000| Untracked
|  47|0x00000000e2f00000, 0x00000000e2f00000, 0x00000000e3000000|  0%| F|  |TAMS 0x00000000e2f00000, 0x00000000e2f00000| Untracked
|  48|0x00000000e3000000, 0x00000000e3000000, 0x00000000e3100000|  0%| F|  |TAMS 0x00000000e3000000, 0x00000000e3000000| Untracked
|  49|0x00000000e3100000, 0x00000000e3100000, 0x00000000e3200000|  0%| F|  |TAMS 0x00000000e3100000, 0x00000000e3100000| Untracked
|  50|0x00000000e3200000, 0x00000000e3200000, 0x00000000e3300000|  0%| F|  |TAMS 0x00000000e3200000, 0x00000000e3200000| Untracked
|  51|0x00000000e3300000, 0x00000000e3300000, 0x00000000e3400000|  0%| F|  |TAMS 0x00000000e3300000, 0x00000000e3300000| Untracked
|  52|0x00000000e3400000, 0x00000000e3400000, 0x00000000e3500000|  0%| F|  |TAMS 0x00000000e3400000, 0x00000000e3400000| Untracked
|  53|0x00000000e3500000, 0x00000000e3500000, 0x00000000e3600000|  0%| F|  |TAMS 0x00000000e3500000, 0x00000000e3500000| Untracked
|  54|0x00000000e3600000, 0x00000000e3600000, 0x00000000e3700000|  0%| F|  |TAMS 0x00000000e3600000, 0x00000000e3600000| Untracked
|  55|0x00000000e3700000, 0x00000000e3700000, 0x00000000e3800000|  0%| F|  |TAMS 0x00000000e3700000, 0x00000000e3700000| Untracked
|  56|0x00000000e3800000, 0x00000000e3800000, 0x00000000e3900000|  0%| F|  |TAMS 0x00000000e3800000, 0x00000000e3800000| Untracked
|  57|0x00000000e3900000, 0x00000000e3900000, 0x00000000e3a00000|  0%| F|  |TAMS 0x00000000e3900000, 0x00000000e3900000| Untracked
|  58|0x00000000e3a00000, 0x00000000e3a00000, 0x00000000e3b00000|  0%| F|  |TAMS 0x00000000e3a00000, 0x00000000e3a00000| Untracked
|  59|0x00000000e3b00000, 0x00000000e3b00000, 0x00000000e3c00000|  0%| F|  |TAMS 0x00000000e3b00000, 0x00000000e3b00000| Untracked
|  60|0x00000000e3c00000, 0x00000000e3c00000, 0x00000000e3d00000|  0%| F|  |TAMS 0x00000000e3c00000, 0x00000000e3c00000| Untracked
|  61|0x00000000e3d00000, 0x00000000e3d00000, 0x00000000e3e00000|  0%| F|  |TAMS 0x00000000e3d00000, 0x00000000e3d00000| Untracked
|  62|0x00000000e3e00000, 0x00000000e3e00000, 0x00000000e3f00000|  0%| F|  |TAMS 0x00000000e3e00000, 0x00000000e3e00000| Untracked
|  63|0x00000000e3f00000, 0x00000000e3f00000, 0x00000000e4000000|  0%| F|  |TAMS 0x00000000e3f00000, 0x00000000e3f00000| Untracked
|  64|0x00000000e4000000, 0x00000000e4072980, 0x00000000e4100000| 44%| E|  |TAMS 0x00000000e4000000, 0x00000000e4000000| Complete
|  65|0x00000000e4100000, 0x00000000e4200000, 0x00000000e4200000|100%| E|CS|TAMS 0x00000000e4100000, 0x00000000e4100000| Complete
|  66|0x00000000e4200000, 0x00000000e4300000, 0x00000000e4300000|100%| E|CS|TAMS 0x00000000e4200000, 0x00000000e4200000| Complete
|  67|0x00000000e4300000, 0x00000000e4400000, 0x00000000e4400000|100%| E|CS|TAMS 0x00000000e4300000, 0x00000000e4300000| Complete
|  68|0x00000000e4400000, 0x00000000e4500000, 0x00000000e4500000|100%| E|CS|TAMS 0x00000000e4400000, 0x00000000e4400000| Complete
|  69|0x00000000e4500000, 0x00000000e4600000, 0x00000000e4600000|100%| E|CS|TAMS 0x00000000e4500000, 0x00000000e4500000| Complete
|  70|0x00000000e4600000, 0x00000000e4700000, 0x00000000e4700000|100%| E|CS|TAMS 0x00000000e4600000, 0x00000000e4600000| Complete
|  71|0x00000000e4700000, 0x00000000e4800000, 0x00000000e4800000|100%| E|CS|TAMS 0x00000000e4700000, 0x00000000e4700000| Complete
|  72|0x00000000e4800000, 0x00000000e4900000, 0x00000000e4900000|100%| E|CS|TAMS 0x00000000e4800000, 0x00000000e4800000| Complete
|  73|0x00000000e4900000, 0x00000000e4a00000, 0x00000000e4a00000|100%| E|CS|TAMS 0x00000000e4900000, 0x00000000e4900000| Complete
|  74|0x00000000e4a00000, 0x00000000e4b00000, 0x00000000e4b00000|100%| E|CS|TAMS 0x00000000e4a00000, 0x00000000e4a00000| Complete
|  75|0x00000000e4b00000, 0x00000000e4c00000, 0x00000000e4c00000|100%| E|CS|TAMS 0x00000000e4b00000, 0x00000000e4b00000| Complete
|  76|0x00000000e4c00000, 0x00000000e4d00000, 0x00000000e4d00000|100%| E|CS|TAMS 0x00000000e4c00000, 0x00000000e4c00000| Complete
|  77|0x00000000e4d00000, 0x00000000e4e00000, 0x00000000e4e00000|100%| E|CS|TAMS 0x00000000e4d00000, 0x00000000e4d00000| Complete
| 486|0x00000000fe600000, 0x00000000fe700000, 0x00000000fe700000|100%| E|CS|TAMS 0x00000000fe600000, 0x00000000fe600000| Complete
| 501|0x00000000ff500000, 0x00000000ff600000, 0x00000000ff600000|100%| E|CS|TAMS 0x00000000ff500000, 0x00000000ff500000| Complete
Card table byte_map: [0x00007f64287fa000,0x00007f64288fa000] _byte_map_base: 0x00007f64280fa000
Marking Bits (Prev, Next): (CMBitMap*) 0x00007f6438052fe8, (CMBitMap*) 0x00007f6438052fa8
 Prev Bits: [0x00007f64276fa000, 0x00007f6427efa000)
 Next Bits: [0x00007f6427efa000, 0x00007f64286fa000)
Polling page: 0x00007f6441190000
Metaspace:
Usage:
  Non-class:     42.92 MB capacity,    41.91 MB ( 98%) used,   839.82 KB (  2%) free+waste,   192.56 KB ( <1%) overhead.
      Class:      7.02 MB capacity,     6.38 MB ( 91%) used,   561.49 KB (  8%) free+waste,    94.75 KB (  1%) overhead.
       Both:     49.94 MB capacity,    48.29 MB ( 97%) used,     1.37 MB (  3%) free+waste,   287.31 KB ( <1%) overhead.
Virtual space:
  Non-class space:       44.00 MB reserved,      43.00 MB ( 98%) committed
      Class space:        1.00 GB reserved,       7.12 MB ( <1%) committed
             Both:        1.04 GB reserved,      50.12 MB (  5%) committed
Chunk freelists:
   Non-Class:  58.00 KB
       Class:  0 bytes
        Both:  58.00 KB
MaxMetaspaceSize: unlimited
CompressedClassSpaceSize: 1.00 GB
CodeHeap 'non-profiled nmethods': size=120028Kb used=2532Kb max_used=2532Kb free=117495Kb
 bounds [0x00007f6430ac9000, 0x00007f6430d49000, 0x00007f6438000000]
CodeHeap 'profiled nmethods': size=120028Kb used=11330Kb max_used=11330Kb free=108697Kb
 bounds [0x00007f6429592000, 0x00007f642a0b2000, 0x00007f6430ac9000]
CodeHeap 'non-nmethods': size=5704Kb used=1677Kb max_used=1692Kb free=4026Kb
 bounds [0x00007f6429000000, 0x00007f6429270000, 0x00007f6429592000]
 total_blobs=7631 nmethods=5166 adapters=981
 compilation: enabled
              stopped_count=0, restarted_count=0
 full_count=0
Compilation events (20 events):
Event: 22.260 Thread 0x00007f643829e800 5158       3       java.util.concurrent.locks.AbstractQueuedSynchronizer::acquireSharedInterruptibly (36 bytes)
Event: 22.260 Thread 0x00007f643829e800 nmethod 5158 0x00007f642a09af10 code [0x00007f642a09b100, 0x00007f642a09b5b0]
Event: 22.260 Thread 0x00007f643829e800 5159       3       javafx.scene.Scene::syncLights (177 bytes)
Event: 22.261 Thread 0x00007f643829e800 nmethod 5159 0x00007f642a09b710 code [0x00007f642a09b9e0, 0x00007f642a09cd90]
Event: 22.261 Thread 0x00007f643829e800 5162       3       com.sun.javafx.geom.RectBounds::intersectWith (82 bytes)
Event: 22.261 Thread 0x00007f643829e800 nmethod 5162 0x00007f642a09d290 code [0x00007f642a09d4c0, 0x00007f642a09dd00]
Event: 22.261 Thread 0x00007f643829e800 5161       3       com.sun.javafx.tk.quantum.SceneState::update (80 bytes)
Event: 22.266 Thread 0x00007f643829e800 nmethod 5161 0x00007f642a09df10 code [0x00007f642a09e100, 0x00007f642a09e7d0]
Event: 22.267 Thread 0x00007f63f419b800 nmethod 5136 0x00007f6430d3d310 code [0x00007f6430d3d5a0, 0x00007f6430d3da38]
Event: 22.267 Thread 0x00007f643829e800 5160       3       javafx.scene.Scene$ScenePulseListener::synchronizeSceneProperties (189 bytes)
Event: 22.268 Thread 0x00007f63f419b800 5128       4       com.sun.javafx.geom.transform.AffineBase::concatenate (1433 bytes)
Event: 22.273 Thread 0x00007f643829e800 nmethod 5160 0x00007f642a09e990 code [0x00007f642a09eec0, 0x00007f642a0a1b60]
Event: 22.274 Thread 0x00007f63f419b800 nmethod 5128 0x00007f6430d3dc90 code [0x00007f6430d3df40, 0x00007f6430d3e4f8]
Event: 22.274 Thread 0x00007f63f419b800 5145       4       javafx.scene.Node::isVisible (19 bytes)
Event: 22.275 Thread 0x00007f63f419b800 nmethod 5145 0x00007f6430d3e890 code [0x00007f6430d3ea20, 0x00007f6430d3eaf8]
Event: 22.275 Thread 0x00007f63f419b800 5110       4       org.objectweb.asm.SymbolTable::get (13 bytes)
Event: 22.276 Thread 0x00007f63f419b800 nmethod 5110 0x00007f6430d3ec10 code [0x00007f6430d3eda0, 0x00007f6430d3ee98]
Event: 22.276 Thread 0x00007f63f419b800 5111       4       java.lang.reflect.Modifier::isProtected (12 bytes)
Event: 22.276 Thread 0x00007f63f419b800 nmethod 5111 0x00007f6430d3ef90 code [0x00007f6430d3f100, 0x00007f6430d3f158]
Event: 22.276 Thread 0x00007f63f419b800 5146       4       java.lang.ClassLoader::getClassLoadingLock (35 bytes)
GC Heap History (20 events):
Event: 7.236 GC heap before
{Heap before GC invocations=16 (full 0):
 garbage-first heap   total 37888K, used 27040K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 9 young (9216K), 2 survivors (2048K)
 Metaspace       used 41137K, capacity 42444K, committed 42624K, reserved 1085440K
  class space    used 5459K, capacity 5978K, committed 6016K, reserved 1048576K
Event: 7.238 GC heap after
{Heap after GC invocations=17 (full 0):
 garbage-first heap   total 37888K, used 18945K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 1 young (1024K), 1 survivors (1024K)
Event: 7.586 GC heap before
{Heap before GC invocations=17 (full 0):
 garbage-first heap   total 37888K, used 29185K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 11 young (11264K), 1 survivors (1024K)
 Metaspace       used 42909K, capacity 44264K, committed 44416K, reserved 1087488K
  class space    used 5726K, capacity 6265K, committed 6272K, reserved 1048576K
Event: 7.589 GC heap after
{Heap after GC invocations=18 (full 0):
 garbage-first heap   total 37888K, used 19565K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 2 young (2048K), 2 survivors (2048K)
Event: 9.683 GC heap before
{Heap before GC invocations=19 (full 0):
 garbage-first heap   total 39936K, used 26733K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 11 young (11264K), 2 survivors (2048K)
 Metaspace       used 44249K, capacity 45783K, committed 45952K, reserved 1089536K
  class space    used 5893K, capacity 6495K, committed 6528K, reserved 1048576K
Event: 9.686 GC heap after
{Heap after GC invocations=20 (full 0):
 garbage-first heap   total 39936K, used 20293K [0x00000000e0000000, 0x0000000100000000)
Event: 21.700 GC heap before
{Heap before GC invocations=21 (full 0):
 garbage-first heap   total 40960K, used 26437K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 7 young (7168K), 2 survivors (2048K)
 Metaspace       used 45121K, capacity 46654K, committed 46848K, reserved 1089536K
  class space    used 6009K, capacity 6611K, committed 6656K, reserved 1048576K
Event: 21.703 GC heap after
{Heap after GC invocations=22 (full 0):
 garbage-first heap   total 40960K, used 20594K [0x00000000e0000000, 0x0000000100000000)
Event: 21.756 GC heap before
{Heap before GC invocations=23 (full 0):
 garbage-first heap   total 96256K, used 65650K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 13 young (13312K), 2 survivors (2048K)
 Metaspace       used 45209K, capacity 46718K, committed 46848K, reserved 1089536K
Event: 21.758 GC heap after
{Heap after GC invocations=24 (full 0):
 garbage-first heap   total 96256K, used 54464K [0x00000000e0000000, 0x0000000100000000)
Event: 21.792 GC heap before
{Heap before GC invocations=24 (full 0):
 garbage-first heap   total 96256K, used 79040K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 25 young (25600K), 1 survivors (1024K)
 Metaspace       used 45263K, capacity 46782K, committed 47104K, reserved 1089536K
Event: 21.794 GC heap after
{Heap after GC invocations=25 (full 0):
 garbage-first heap   total 96256K, used 54420K [0x00000000e0000000, 0x0000000100000000)
Event: 21.842 GC heap before
{Heap before GC invocations=26 (full 0):
 garbage-first heap   total 106496K, used 80020K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 26 young (26624K), 1 survivors (1024K)
 Metaspace       used 45300K, capacity 46844K, committed 47104K, reserved 1089536K
  class space    used 6009K, capacity 6610K, committed 6656K, reserved 1048576K
Event: 21.843 GC heap after
{Heap after GC invocations=27 (full 0):
 garbage-first heap   total 106496K, used 54446K [0x00000000e0000000, 0x0000000100000000)
Event: 21.889 GC heap before
{Heap before GC invocations=27 (full 0):
 garbage-first heap   total 106496K, used 89262K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 35 young (35840K), 1 survivors (1024K)
 Metaspace       used 45317K, capacity 46845K, committed 47104K, reserved 1089536K
Event: 21.891 GC heap after
{Heap after GC invocations=28 (full 0):
 garbage-first heap   total 106496K, used 54435K [0x00000000e0000000, 0x0000000100000000)
Event: 21.952 GC heap before
{Heap before GC invocations=29 (full 0):
 garbage-first heap   total 109568K, used 91299K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 37 young (37888K), 1 survivors (1024K)
 Metaspace       used 45333K, capacity 46845K, committed 47104K, reserved 1089536K
Event: 21.953 GC heap after
{Heap after GC invocations=30 (full 0):
 garbage-first heap   total 109568K, used 54430K [0x00000000e0000000, 0x0000000100000000)
Event: 22.027 GC heap before
{Heap before GC invocations=30 (full 0):
 garbage-first heap   total 109568K, used 94366K [0x00000000e0000000, 0x0000000100000000)
  region size 1024K, 40 young (40960K), 1 survivors (1024K)
 Metaspace       used 45744K, capacity 47304K, committed 47488K, reserved 1089536K
  class space    used 6067K, capacity 6678K, committed 6784K, reserved 1048576K
Event: 22.029 GC heap after
{Heap after GC invocations=31 (full 0):
 garbage-first heap   total 109568K, used 20704K [0x00000000e0000000, 0x0000000100000000)
The next part:
Deoptimization events (20 events):
Event: 22.058 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f65100 sp=0x00007f6387dfa160
Event: 22.058 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df95b8 mode 0
Event: 22.066 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f6564c sp=0x00007f6387dfa160
Event: 22.066 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df95b8 mode 0
Event: 22.074 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f65100 sp=0x00007f6387dfa160
Event: 22.074 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df95b8 mode 0
Event: 22.080 Thread 0x00007f6314795800 Uncommon trap: trap_request=0xffffff45 fr.pc=0x00007f6430b4ceb4 relative=0x0000000000000774
Event: 22.080 Thread 0x00007f6314795800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f6430b4ceb4 method=java.lang.AbstractStringBuilder.append(Ljava/lang/String;)Ljava/lang/AbstractStringBuilder; @ 1 c2
Event: 22.080 Thread 0x00007f6314795800 DEOPT PACKING pc=0x00007f6430b4ceb4 sp=0x00007f62b1ef76f0
Event: 22.080 Thread 0x00007f6314795800 DEOPT UNPACKING pc=0x00007f6429048e25 sp=0x00007f62b1ef7680 mode 2
Event: 22.088 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f6564c sp=0x00007f6387dfa280
Event: 22.088 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df96d8 mode 0
Event: 22.099 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f6564c sp=0x00007f6387dfa160
Event: 22.099 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df95b8 mode 0
Event: 22.114 Thread 0x00007f6314795800 Uncommon trap: trap_request=0xffffff45 fr.pc=0x00007f6430c75cdc relative=0x00000000000004fc
Event: 22.114 Thread 0x00007f6314795800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f6430c75cdc method=java.util.ArrayList.grow(I)[Ljava/lang/Object; @ 17 c2
Event: 22.114 Thread 0x00007f6314795800 DEOPT PACKING pc=0x00007f6430c75cdc sp=0x00007f62b1ef7e40
Event: 22.114 Thread 0x00007f6314795800 DEOPT UNPACKING pc=0x00007f6429048e25 sp=0x00007f62b1ef7df8 mode 2
Event: 22.126 Thread 0x00007f638c047800 DEOPT PACKING pc=0x00007f6429f6564c sp=0x00007f6387dfa160
Event: 22.126 Thread 0x00007f638c047800 DEOPT UNPACKING pc=0x00007f642904933a sp=0x00007f6387df95b8 mode 0
Classes unloaded (1 events):
Event: 21.806 Thread 0x00007f643826f800 Unloading class 0x00000001005f3440 'jdk/internal/net/http/common/Demand$$Lambda$978'
Classes redefined (0 events):
No events
Internal exceptions (20 events):
Event: 7.601 Thread 0x00007f638c08e800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000ff5d3e98}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeStatic(java.lang.Object, java.lang.Object, int, int, int, int, int, java.lang.Object)'> (0x00000000ff5d3e98)
thrown [./src/hotspot/share/interpreter/linkResolver.cpp, line 766]
Event: 7.602 Thread 0x00007f638c08e800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe640b80}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeStatic(java.lang.Object, java.lang.Object, java.lang.Object, int, int, int, int, int)'> (0x00000000fe640b80)
Event: 7.602 Thread 0x00007f638c08e800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe6469f8}: 'java.lang.Object java.lang.invoke.Invokers$Holder.linkToTargetMethod(java.lang.Object, java.lang.Object, int, int, int, int, int, java.lang.Object)'> (0x00000000fe6469f8)
Event: 7.735 Thread 0x00007f62ac007800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe6eb110}: 'void java.lang.invoke.DirectMethodHandle$Holder.invokeStatic(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object)'> (0x00000000fe6eb110)
Event: 11.877 Thread 0x00007f638c047800 Implicit null exception at 0x00007f6430ca8e80 to 0x00007f6430ca959d
Event: 21.671 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000fe6d36d0}> (0x00000000fe6d36d0)
thrown [./src/hotspot/share/prims/jni.cpp, line 599]
Event: 21.671 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000fe6d3b58}> (0x00000000fe6d3b58)
Event: 21.671 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000fe6d3f58}> (0x00000000fe6d3f58)
Event: 21.690 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000e24a7eb8}> (0x00000000e24a7eb8)
Event: 22.012 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000e4498538}> (0x00000000e4498538)
Event: 22.013 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000e4499338}> (0x00000000e4499338)
Event: 22.040 Thread 0x00007f6314795800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe60ddc0}: 'long java.lang.invoke.DirectMethodHandle$Holder.invokeInterface(java.lang.Object, java.lang.Object)'> (0x00000000fe60ddc0)
Event: 22.042 Thread 0x00007f6314795800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe635f70}: 'void java.lang.invoke.DirectMethodHandle$Holder.invokeInterface(java.lang.Object, java.lang.Object, int)'> (0x00000000fe635f70)
Event: 22.048 Thread 0x00007f6314795800 Exception <a 'sun/nio/fs/UnixException'{0x00000000fe6631c0}> (0x00000000fe6631c0)
Event: 22.052 Thread 0x00007f6314795800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000fe694e88}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeStaticInit(java.lang.Object, int)'> (0x00000000fe694e88)
Event: 22.080 Thread 0x00007f6314795800 Implicit null exception at 0x00007f6430b4c774 to 0x00007f6430b4ce9c
Event: 22.152 Thread 0x00007f6314795800 Exception <a 'java/lang/UnsatisfiedLinkError'{0x00000000e4711250}: fuse: cannot open shared object file: No such file or directory> (0x00000000e4711250)
thrown [./src/hotspot/share/prims/jni.cpp, line 620]
Event: 22.153 Thread 0x00007f6314795800 Exception <a 'java/lang/UnsatisfiedLinkError'{0x00000000e471d748}: libfuse.so: cannot open shared object file: No such file or directory> (0x00000000e471d748)
Event: 22.231 Thread 0x00007f6314795800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000e4246140}: 'int java.lang.invoke.DirectMethodHandle$Holder.invokeInterface(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object)'> (0x00000000e4246140)
Event: 22.250 Thread 0x00007f6314795800 Exception <a 'java/lang/NoSuchMethodError'{0x00000000e414d6b8}: 'int java.lang.invoke.DirectMethodHandle$Holder.invokeInterface(java.lang.Object, java.lang.Object, java.lang.Object, int)'> (0x00000000e414d6b8)
Events (20 events):
Event: 22.255 Executing VM operation: HandshakeOneThread
Event: 22.255 Executing VM operation: HandshakeOneThread done
Event: 22.256 Executing VM operation: HandshakeOneThread
Event: 22.256 Executing VM operation: HandshakeOneThread done
Event: 22.256 Executing VM operation: BulkRevokeBias
Event: 22.256 Executing VM operation: BulkRevokeBias done
Event: 22.259 Executing VM operation: HandshakeOneThread
Event: 22.259 Executing VM operation: HandshakeOneThread done
Event: 22.260 Executing VM operation: HandshakeOneThread
Event: 22.260 Executing VM operation: HandshakeOneThread done
Event: 22.261 Executing VM operation: HandshakeOneThread
Event: 22.261 Executing VM operation: HandshakeOneThread done
Dynamic libraries:
e0000000-e4e00000 rw-p 00000000 00:00 0
e4e00000-fe600000 ---p 00000000 00:00 0
fe600000-fe700000 rw-p 00000000 00:00 0
fe700000-ff500000 ---p 00000000 00:00 0
ff500000-ff600000 rw-p 00000000 00:00 0
ff600000-100000000 ---p 00000000 00:00 0
100000000-100720000 rw-p 00000000 00:00 0
100720000-140000000 ---p 00000000 00:00 0
55e031fe9000-55e03200f000 r-xp 00000000 00:85 307                        /tmp/.mount_cryptowE2Ty5/bin/Cryptomator
55e03220e000-55e032210000 r--p 00025000 00:85 307                        /tmp/.mount_cryptowE2Ty5/bin/Cryptomator
55e032210000-55e032211000 rw-p 00027000 00:85 307                        /tmp/.mount_cryptowE2Ty5/bin/Cryptomator
55e032431000-55e03249c000 rw-p 00000000 00:00 0                          [heap]
7f6284000000-7f6284046000 rw-p 00000000 00:00 0
7f6284046000-7f6288000000 ---p 00000000 00:00 0
7f6288000000-7f6288025000 rw-p 00000000 00:00 0
7f6288025000-7f628c000000 ---p 00000000 00:00 0
7f628c000000-7f628c6ef000 rw-p 00000000 00:00 0
7f628c6ef000-7f6290000000 ---p 00000000 00:00 0
7f6290000000-7f6290021000 rw-p 00000000 00:00 0
7f6290021000-7f6294000000 ---p 00000000 00:00 0
7f6294000000-7f6294356000 rw-p 00000000 00:00 0
7f6294356000-7f6298000000 ---p 00000000 00:00 0
7f6298000000-7f6298a3e000 rw-p 00000000 00:00 0
7f6298a3e000-7f629c000000 ---p 00000000 00:00 0
7f629c000000-7f629c06f000 rw-p 00000000 00:00 0
7f629c06f000-7f62a0000000 ---p 00000000 00:00 0
7f62a0000000-7f62a0021000 rw-p 00000000 00:00 0
7f62a0021000-7f62a4000000 ---p 00000000 00:00 0
7f62a4000000-7f62a4021000 rw-p 00000000 00:00 0
7f62a4021000-7f62a8000000 ---p 00000000 00:00 0
7f62a8000000-7f62a83c6000 rw-p 00000000 00:00 0
7f62a83c6000-7f62ac000000 ---p 00000000 00:00 0
7f62ac000000-7f62ac021000 rw-p 00000000 00:00 0
7f62ac021000-7f62b0000000 ---p 00000000 00:00 0
7f62b00e2000-7f62b00e3000 ---p 00000000 00:00 0
7f62b00e3000-7f62b08e3000 rw-p 00000000 00:00 0
7f62b08e3000-7f62b08e4000 ---p 00000000 00:00 0
7f62b08e4000-7f62b10e4000 rw-p 00000000 00:00 0
7f62b10e4000-7f62b10e8000 ---p 00000000 00:00 0
7f62b10e8000-7f62b12e5000 rw-p 00000000 00:00 0
7f62b12e5000-7f62b12e9000 ---p 00000000 00:00 0
7f62b12e9000-7f62b15e6000 rw-p 00000000 00:00 0
7f62b15e6000-7f62b16e6000 ---p 00000000 00:00 0
7f62b16e6000-7f62b16f8000 r-xp 00000000 00:3c 41363                      /tmp/jffi17413466840685389187.so (deleted)
7f62b16f8000-7f62b18f7000 ---p 00012000 00:3c 41363                      /tmp/jffi17413466840685389187.so (deleted)
7f62b18f7000-7f62b18f8000 rw-p 00011000 00:3c 41363                      /tmp/jffi17413466840685389187.so (deleted)
7f62b18f8000-7f62b1af8000 rw-p 00000000 00:00 0
7f62b1af8000-7f62b1afc000 ---p 00000000 00:00 0
7f62b1afc000-7f62b1cf9000 rw-p 00000000 00:00 0
7f62b1cf9000-7f62b1cfd000 ---p 00000000 00:00 0
7f62b1cfd000-7f62b20fa000 rw-p 00000000 00:00 0
7f62b20fa000-7f62b20fe000 ---p 00000000 00:00 0
7f62b20fe000-7f62b22fb000 rw-p 00000000 00:00 0
7f62b22fb000-7f62b22ff000 ---p 00000000 00:00 0
7f62b22ff000-7f62b26fc000 rw-p 00000000 00:00 0
7f62b26fc000-7f62b2700000 ---p 00000000 00:00 0
7f62b2700000-7f62b28fd000 rw-p 00000000 00:00 0
7f62b28fd000-7f62b2901000 ---p 00000000 00:00 0
7f62b2901000-7f62b2cfe000 rw-p 00000000 00:00 0
7f62b2da4000-7f62b2dad000 r--p 00000000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2dad000-7f62b2dc7000 r-xp 00009000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2dc7000-7f62b2dd1000 r--p 00023000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2dd1000-7f62b2dd2000 ---p 0002d000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2dd2000-7f62b2de4000 r--p 0002d000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2de4000-7f62b2de5000 rw-p 0003f000 00:2f 556953                     /usr/lib64/libfuse.so.2.9.8
7f62b2dfe000-7f62b2efe000 rw-s 124d9b000 00:06 18141                     /dev/dri/renderD128
7f62b2efe000-7f62b30fe000 rw-s 11e1a9000 00:06 18141                     /dev/dri/renderD128
7f62b30fe000-7f62b31fe000 rw-s 124c9b000 00:06 18141                     /dev/dri/renderD128
7f62b31fe000-7f62b33fe000 rw-s 125a91000 00:06 18141                     /dev/dri/renderD128
7f62b33fe000-7f62b35fe000 rw-s 124a9b000 00:06 18141                     /dev/dri/renderD128
7f62b35fe000-7f62b37fe000 rw-p 00000000 00:00 0
7f62b37fe000-7f62b39fe000 rw-p 00000000 00:00 0
7f62b39fe000-7f62b3bfe000 rw-p 00000000 00:00 0
7f62b3bfe000-7f62b3c02000 ---p 00000000 00:00 0
7f62b3c02000-7f62b3dff000 rw-p 00000000 00:00 0
7f62b3dff000-7f62b3e03000 ---p 00000000 00:00 0
7f62b3e03000-7f62b4000000 rw-p 00000000 00:00 0
7f62b4000000-7f62b4021000 rw-p 00000000 00:00 0
7f62b4021000-7f62b8000000 ---p 00000000 00:00 0
7f62b8000000-7f62b8873000 rw-p 00000000 00:00 0
7f62b8873000-7f62bc000000 ---p 00000000 00:00 0
7f62bc000000-7f62bc021000 rw-p 00000000 00:00 0
7f62bc021000-7f62c0000000 ---p 00000000 00:00 0
7f62c0000000-7f62c0021000 rw-p 00000000 00:00 0
7f62c0021000-7f62c4000000 ---p 00000000 00:00 0
7f62c4000000-7f62c4021000 rw-p 00000000 00:00 0
7f62c4021000-7f62c8000000 ---p 00000000 00:00 0
7f62c8000000-7f62c8021000 rw-p 00000000 00:00 0
7f62c8021000-7f62cc000000 ---p 00000000 00:00 0
7f62cc000000-7f62cc021000 rw-p 00000000 00:00 0
7f62cc021000-7f62d0000000 ---p 00000000 00:00 0
7f62d0000000-7f62d0021000 rw-p 00000000 00:00 0
7f62d0021000-7f62d4000000 ---p 00000000 00:00 0
7f62d4000000-7f62d4021000 rw-p 00000000 00:00 0
7f62d4021000-7f62d8000000 ---p 00000000 00:00 0
7f62d8000000-7f62d8021000 rw-p 00000000 00:00 0
7f62d8021000-7f62dc000000 ---p 00000000 00:00 0
7f62dc000000-7f62dc04b000 rw-p 00000000 00:00 0
7f62dc04b000-7f62e0000000 ---p 00000000 00:00 0
7f62e0000000-7f62e0021000 rw-p 00000000 00:00 0
7f62e0021000-7f62e4000000 ---p 00000000 00:00 0
7f62e4000000-7f62e404b000 rw-p 00000000 00:00 0
7f62e404b000-7f62e8000000 ---p 00000000 00:00 0
7f62e8012000-7f62e8082000 r--p 00000000 00:2f 77665                      /usr/share/fonts/truetype/NotoSans-Regular.ttf
7f62e8082000-7f62e80eb000 r--p 00000000 00:44 308454                     /var/cache/libx11/compose/l4_030_313cb605_00280cc0
7f62e80eb000-7f62e81eb000 rw-s 00000000 00:01 163876                     /SYSV00000000 (deleted)
7f62e81eb000-7f62e83eb000 rw-p 00000000 00:00 0
7f62e83eb000-7f62e85eb000 rw-p 00000000 00:00 0
7f62e85eb000-7f62e85ef000 r-xp 00000000 08:05 151354258                  /home/hornet/.openjfx/cache/14/libjavafx_font_pango.so
7f62e85ef000-7f62e87ee000 ---p 00004000 08:05 151354258                  /home/hornet/.openjfx/cache/14/libjavafx_font_pango.so
7f62e87ee000-7f62e87ef000 r--p 00003000 08:05 151354258                  /home/hornet/.openjfx/cache/14/libjavafx_font_pango.so
7f62e87ef000-7f62e87f0000 rw-p 00004000 08:05 151354258                  /home/hornet/.openjfx/cache/14/libjavafx_font_pango.so
7f62e87f0000-7f62e87f5000 r-xp 00000000 08:05 151354257                  /home/hornet/.openjfx/cache/14/libjavafx_font_freetype.so
7f62e87f5000-7f62e89f4000 ---p 00005000 08:05 151354257                  /home/hornet/.openjfx/cache/14/libjavafx_font_freetype.so
7f62e89f4000-7f62e89f5000 r--p 00004000 08:05 151354257                  /home/hornet/.openjfx/cache/14/libjavafx_font_freetype.so
7f62e89f5000-7f62e89f6000 rw-p 00005000 08:05 151354257                  /home/hornet/.openjfx/cache/14/libjavafx_font_freetype.so
7f62e89f6000-7f62e89f9000 r-xp 00000000 08:05 151354256                  /home/hornet/.openjfx/cache/14/libjavafx_font.so
7f62e89f9000-7f62e8bf8000 ---p 00003000 08:05 151354256                  /home/hornet/.openjfx/cache/14/libjavafx_font.so
7f62e8bf8000-7f62e8bf9000 r--p 00002000 08:05 151354256                  /home/hornet/.openjfx/cache/14/libjavafx_font.so
7f62e8bf9000-7f62e8bfa000 rw-p 00003000 08:05 151354256                  /home/hornet/.openjfx/cache/14/libjavafx_font.so
7f62e8bfa000-7f62e8dfa000 rw-p 00000000 00:00 0
7f62e8dfa000-7f62e8ffa000 rw-p 00000000 00:00 0
7f62e8ffa000-7f62e8ffb000 ---p 00000000 00:00 0
7f62e8ffb000-7f62e97fb000 rw-p 00000000 00:00 0
7f62e97fb000-7f62e97fc000 ---p 00000000 00:00 0
7f62e97fc000-7f62e9ffc000 rw-p 00000000 00:00 0
7f62e9ffc000-7f62e9ffd000 ---p 00000000 00:00 0
7f62e9ffd000-7f62ea7fd000 rw-p 00000000 00:00 0
7f62ea7fd000-7f62ea7fe000 ---p 00000000 00:00 0
7f62ea7fe000-7f62eaffe000 rw-p 00000000 00:00 0
7f62eaffe000-7f62eafff000 ---p 00000000 00:00 0
7f62eafff000-7f62eb7ff000 rw-p 00000000 00:00 0
7f62eb7ff000-7f62eb800000 ---p 00000000 00:00 0
7f62eb800000-7f62ec000000 rw-p 00000000 00:00 0
7f62ec000000-7f62ec04a000 rw-p 00000000 00:00 0
7f62ec04a000-7f62f0000000 ---p 00000000 00:00 0
7f62f0000000-7f62f0051000 rw-p 00000000 00:00 0
7f62f0051000-7f62f4000000 ---p 00000000 00:00 0
7f62f4000000-7f62f404d000 rw-p 00000000 00:00 0
7f62f404d000-7f62f8000000 ---p 00000000 00:00 0
7f62f8000000-7f62f804b000 rw-p 00000000 00:00 0
7f62f804b000-7f62fc000000 ---p 00000000 00:00 0
7f62fc000000-7f62fc04d000 rw-p 00000000 00:00 0
7f62fc04d000-7f6300000000 ---p 00000000 00:00 0
7f6300000000-7f630004e000 rw-p 00000000 00:00 0
7f630004e000-7f6304000000 ---p 00000000 00:00 0
7f6304000000-7f6304021000 rw-p 00000000 00:00 0
7f6304021000-7f6308000000 ---p 00000000 00:00 0
7f6308000000-7f6308061000 rw-p 00000000 00:00 0
7f6308061000-7f630c000000 ---p 00000000 00:00 0
7f630c000000-7f630c021000 rw-p 00000000 00:00 0
7f630c021000-7f6310000000 ---p 00000000 00:00 0
7f6310000000-7f6310021000 rw-p 00000000 00:00 0
7f6310021000-7f6314000000 ---p 00000000 00:00 0
7f6314000000-7f63149c1000 rw-p 00000000 00:00 0
7f63149c1000-7f6318000000 ---p 00000000 00:00 0
7f6318000000-7f6318021000 rw-p 00000000 00:00 0
7f6318021000-7f631c000000 ---p 00000000 00:00 0
7f631c000000-7f631c021000 rw-p 00000000 00:00 0
7f631c021000-7f6320000000 ---p 00000000 00:00 0
7f6320000000-7f6320021000 rw-p 00000000 00:00 0
7f6320021000-7f6324000000 ---p 00000000 00:00 0
7f6324000000-7f6324021000 rw-p 00000000 00:00 0
7f6324021000-7f6328000000 ---p 00000000 00:00 0
7f6328015000-7f6328016000 rw-s 00000000 00:01 139035                     /memfd:xshmfence (deleted)
7f6328016000-7f6328018000 rw-p 00000000 00:00 0
7f6328018000-7f632806f000 r--p 00000000 00:2f 77789                      /usr/share/fonts/truetype/Roboto-Regular.ttf
7f632806f000-7f63280f6000 r--p 00000000 00:3c 41362                      /tmp/+JXF2852891076191819330.tmp
7f63280f6000-7f63280fa000 ---p 00000000 00:00 0
7f63280fa000-7f63283f7000 rw-p 00000000 00:00 0
7f63283f7000-7f63283fb000 ---p 00000000 00:00 0
7f63283fb000-7f63285f8000 rw-p 00000000 00:00 0
7f63285f8000-7f63285fc000 ---p 00000000 00:00 0
7f63285fc000-7f63287f9000 rw-p 00000000 00:00 0
7f63287f9000-7f63287fa000 ---p 00000000 00:00 0
7f63287fa000-7f6328ffa000 rw-p 00000000 00:00 0
7f6328ffa000-7f6328ffb000 ---p 00000000 00:00 0
7f6328ffb000-7f63297fb000 rw-p 00000000 00:00 0
7f63297fb000-7f63297fc000 ---p 00000000 00:00 0
7f63297fc000-7f6329ffc000 rw-p 00000000 00:00 0
7f6329ffc000-7f6329ffd000 ---p 00000000 00:00 0
7f6329ffd000-7f632a7fd000 rw-p 00000000 00:00 0
7f632a7fd000-7f632a7fe000 ---p 00000000 00:00 0
7f632a7fe000-7f632affe000 rw-p 00000000 00:00 0
7f632affe000-7f632afff000 ---p 00000000 00:00 0
7f632afff000-7f632b7ff000 rw-p 00000000 00:00 0
7f632b7ff000-7f632b800000 ---p 00000000 00:00 0
7f632b800000-7f632c000000 rw-p 00000000 00:00 0
7f632c000000-7f632c021000 rw-p 00000000 00:00 0
7f632c021000-7f6330000000 ---p 00000000 00:00 0
7f6330000000-7f6330001000 r-xp 00000000 00:00 0
7f6330001000-7f6330024000 r--p 00000000 00:2f 77709                      /usr/share/fonts/truetype/LiberationSans-Regular.ttf
7f6330024000-7f633003e000 r--p 00000000 00:3c 41360                      /tmp/+JXF5790519290227573256.tmp
7f633003e000-7f63300b5000 r--s 00000000 00:44 325769                     /var/cache/fontconfig/313556e5-bc08-4ed4-b1f7-aad3e08c4c9a-x86_64.cache-7
7f63300b5000-7f63300f2000 r--s 00000000 00:44 325767                     /var/cache/fontconfig/83a9dce1-7dd5-45de-9016-3c1e94e2a7f0-x86_64.cache-7
7f63300f2000-7f63300f3000 ---p 00000000 00:00 0
7f63300f3000-7f63301f4000 rw-p 00000000 00:00 0
7f63301f4000-7f63301f8000 ---p 00000000 00:00 0
7f63301f8000-7f63303f5000 rw-p 00000000 00:00 0
7f63303f5000-7f63303f8000 r-xp 00000000 00:3c 41357                      /tmp/libunix-java12213247515911476713so
7f63303f8000-7f63305f7000 ---p 00003000 00:3c 41357                      /tmp/libunix-java12213247515911476713so
7f63305f7000-7f63305f8000 r--p 00002000 00:3c 41357                      /tmp/libunix-java12213247515911476713so
7f63305f8000-7f63305f9000 rw-p 00003000 00:3c 41357                      /tmp/libunix-java12213247515911476713so
7f63305f9000-7f63305fa000 ---p 00000000 00:00 0
7f63305fa000-7f6330dfa000 rw-p 00000000 00:00 0
7f6330dfa000-7f6330dfb000 ---p 00000000 00:00 0
7f6330dfb000-7f63315fb000 rw-p 00000000 00:00 0
7f63315fb000-7f63315fc000 ---p 00000000 00:00 0
7f63315fc000-7f6331dfc000 rw-p 00000000 00:00 0
7f6331dfc000-7f6331dfd000 ---p 00000000 00:00 0
7f6331dfd000-7f63325fd000 rw-p 00000000 00:00 0
7f63325fd000-7f63325fe000 ---p 00000000 00:00 0
7f63325fe000-7f6332ffe000 rw-p 00000000 00:00 0
7f6332ffe000-7f6332fff000 ---p 00000000 00:00 0
7f6332fff000-7f63337ff000 rw-p 00000000 00:00 0
7f63337ff000-7f6333800000 ---p 00000000 00:00 0
7f6333800000-7f6334000000 rw-p 00000000 00:00 0
7f6334000000-7f6334021000 rw-p 00000000 00:00 0
7f6334021000-7f6338000000 ---p 00000000 00:00 0
7f6338000000-7f6338021000 rw-p 00000000 00:00 0
7f6338021000-7f633c000000 ---p 00000000 00:00 0
7f633c000000-7f633c021000 rw-p 00000000 00:00 0
7f633c021000-7f6340000000 ---p 00000000 00:00 0
7f6340000000-7f6340021000 rw-p 00000000 00:00 0
7f6340021000-7f6344000000 ---p 00000000 00:00 0
7f6344000000-7f6344021000 rw-p 00000000 00:00 0
7f6344021000-7f6348000000 ---p 00000000 00:00 0
7f6348000000-7f6348021000 rw-p 00000000 00:00 0
7f6348021000-7f634c000000 ---p 00000000 00:00 0
7f634c000000-7f634c021000 rw-p 00000000 00:00 0
7f634c021000-7f6350000000 ---p 00000000 00:00 0
7f6350000000-7f6350002000 r-xp 00000000 00:00 0
7f6350002000-7f6350015000 r--p 00000000 00:3c 41361                      /tmp/+JXF10033816644856741549.tmp
7f6350015000-7f635002e000 r--p 00000000 00:3c 41359                      /tmp/+JXF17002346088246972409.tmp
7f635002e000-7f63500ae000 r--s 00000000 00:44 325757                     /var/cache/fontconfig/ba321c87-97d0-4411-806e-f5e83b63c040-x86_64.cache-7
7f63500ae000-7f63500af000 ---p 00000000 00:00 0
7f63500af000-7f63501b0000 rw-p 00000000 00:00 0
7f63501b0000-7f63501b4000 ---p 00000000 00:00 0
7f63501b4000-7f63503b1000 rw-p 00000000 00:00 0
7f63503b1000-7f63503b5000 ---p 00000000 00:00 0
7f63503b5000-7f63505b2000 rw-p 00000000 00:00 0
7f63505b2000-7f63505f5000 r-xp 00000000 08:05 151354250                  /home/hornet/.openjfx/cache/14/libglassgtk3.so
7f63505f5000-7f63507f5000 ---p 00043000 08:05 151354250                  /home/hornet/.openjfx/cache/14/libglassgtk3.so
7f63507f5000-7f63507f7000 r--p 00043000 08:05 151354250                  /home/hornet/.openjfx/cache/14/libglassgtk3.so
7f63507f7000-7f63507f8000 rw-p 00045000 08:05 151354250                  /home/hornet/.openjfx/cache/14/libglassgtk3.so
7f63507f8000-7f63507f9000 rw-p 00000000 00:00 0
7f63507f9000-7f63507fa000 ---p 00000000 00:00 0
7f63507fa000-7f6350ffa000 rw-p 00000000 00:00 0
7f6350ffa000-7f6350ffb000 ---p 00000000 00:00 0
7f6350ffb000-7f63517fb000 rw-p 00000000 00:00 0
7f63517fb000-7f63517fc000 ---p 00000000 00:00 0
7f63517fc000-7f6351ffc000 rw-p 00000000 00:00 0
7f6351ffc000-7f6351ffd000 ---p 00000000 00:00 0
7f6351ffd000-7f63527fd000 rw-p 00000000 00:00 0
7f63527fd000-7f63527fe000 ---p 00000000 00:00 0
7f63527fe000-7f6352ffe000 rw-p 00000000 00:00 0
7f6352ffe000-7f6352fff000 ---p 00000000 00:00 0
7f6352fff000-7f63537ff000 rw-p 00000000 00:00 0
7f63537ff000-7f6353800000 ---p 00000000 00:00 0
7f6353800000-7f6354000000 rw-p 00000000 00:00 0
7f6354000000-7f6354021000 rw-p 00000000 00:00 0
7f6354021000-7f6358000000 ---p 00000000 00:00 0
7f6358000000-7f6358021000 rw-p 00000000 00:00 0
7f6358021000-7f635c000000 ---p 00000000 00:00 0
7f635c000000-7f635c021000 rw-p 00000000 00:00 0
7f635c021000-7f6360000000 ---p 00000000 00:00 0
7f6360000000-7f6360021000 rw-p 00000000 00:00 0
7f6360021000-7f6364000000 ---p 00000000 00:00 0
7f6364000000-7f6364021000 rw-p 00000000 00:00 0
7f6364021000-7f6368000000 ---p 00000000 00:00 0
7f6368000000-7f6368021000 rw-p 00000000 00:00 0
7f6368021000-7f636c000000 ---p 00000000 00:00 0
7f636c000000-7f636c021000 rw-p 00000000 00:00 0
7f636c021000-7f6370000000 ---p 00000000 00:00 0
7f6370000000-7f6370008000 r-xp 00000000 00:00 0
7f6370008000-7f6370009000 rw-p 00000000 00:00 0
7f6370009000-7f637000c000 r-xp 00000000 00:00 0
7f637000c000-7f6370050000 r--s 00000000 00:44 325765                     /var/cache/fontconfig/d28f3b7a-0cf5-4f03-b9ab-06d0cd192567-x86_64.cache-7
7f6370050000-7f6370060000 r--s 00000000 00:44 325763                     /var/cache/fontconfig/290c294d-f1ee-415d-af53-2958e226234e-x86_64.cache-7
7f6370060000-7f6370069000 r--s 00000000 00:44 325759                     /var/cache/fontconfig/86762838-277f-44cf-8c44-ef9d74020d75-x86_64.cache-7
7f6370069000-7f63701aa000 rw-s 00000000 08:05 468299685                  /home/hornet/.cache/mesa_shader_cache/index
7f63701aa000-7f63701ab000 ---p 00000000 00:00 0
7f63701ab000-7f63709ab000 rw-p 00000000 00:00 0
7f63709ab000-7f63709ac000 ---p 00000000 00:00 0
7f63709ac000-7f63711ac000 rw-p 00000000 00:00 0
7f63711ac000-7f63711ad000 ---p 00000000 00:00 0
7f63711ad000-7f63719ad000 rw-p 00000000 00:00 0
7f63719ad000-7f63719ae000 ---p 00000000 00:00 0
7f63719ae000-7f63721ae000 rw-p 00000000 00:00 0
7f63721ae000-7f63721af000 ---p 00000000 00:00 0
7f63721af000-7f63729af000 rw-p 00000000 00:00 0
7f63729af000-7f63729b0000 ---p 00000000 00:00 0
7f63729b0000-7f63731b0000 rw-p 00000000 00:00 0
7f63731b0000-7f6377930000 r-xp 00000000 00:2f 563619                     /usr/lib64/libLLVM.so.10
7f6377930000-7f6377e0e000 r--p 0477f000 00:2f 563619                     /usr/lib64/libLLVM.so.10
7f6377e0e000-7f6377faa000 rw-p 04c5d000 00:2f 563619                     /usr/lib64/libLLVM.so.10
7f6377faa000-7f6378000000 rw-p 00000000 00:00 0
7f6378000000-7f6378af9000 rw-p 00000000 00:00 0
7f6378af9000-7f637c000000 ---p 00000000 00:00 0
7f637c000000-7f637c021000 rw-p 00000000 00:00 0
7f637c021000-7f6380000000 ---p 00000000 00:00 0
7f6380000000-7f6380021000 rw-p 00000000 00:00 0
7f6380021000-7f6384000000 ---p 00000000 00:00 0
7f6384000000-7f6384008000 r-xp 00000000 00:00 0
7f6384008000-7f6384088000 r--s 00000000 00:44 325755                     /var/cache/fontconfig/58cc3765-9ece-41ed-a7f3-ab63a47b67ca-x86_64.cache-7
7f6384088000-7f6384089000 r-xp 00000000 08:05 151354254                  /home/hornet/.openjfx/cache/14/libglass.so
7f6384089000-7f6384289000 ---p 00001000 08:05 151354254                  /home/hornet/.openjfx/cache/14/libglass.so
7f6384289000-7f638428a000 r--p 00001000 08:05 151354254                  /home/hornet/.openjfx/cache/14/libglass.so
7f638428a000-7f638428b000 rw-p 00002000 08:05 151354254                  /home/hornet/.openjfx/cache/14/libglass.so
7f638428b000-7f638448b000 rw-s 124492000 00:06 18141                     /dev/dri/renderD128
7f638448b000-7f638468b000 rw-s 11c1bb000 00:06 18141                     /dev/dri/renderD128
7f638468b000-7f638468c000 ---p 00000000 00:00 0
7f638468c000-7f6384e8c000 rw-p 00000000 00:00 0
7f6384e8c000-7f6384e8d000 ---p 00000000 00:00 0
7f6384e8d000-7f638568d000 rw-p 00000000 00:00 0
7f638568d000-7f63857ce000 rw-s 00000000 08:05 468299685                  /home/hornet/.cache/mesa_shader_cache/index
7f63857ce000-7f63857cf000 ---p 00000000 00:00 0
7f63857cf000-7f6385fcf000 rw-p 00000000 00:00 0
7f6385fcf000-7f6386000000 r--p 00000000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f6386000000-7f63860e2000 r-xp 00031000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f63860e2000-7f638612c000 r--p 00113000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f638612c000-7f638612d000 ---p 0015d000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f638612d000-7f6386135000 r--p 0015d000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f6386135000-7f6386137000 rw-p 00165000 00:2f 557716                     /usr/lib64/libxml2.so.2.9.10
7f6386137000-7f6386138000 rw-p 00000000 00:00 0
7f6386138000-7f6386142000 r--p 00000000 00:2f 558599                     /lib64/libtinfo.so.6.2
7f6386142000-7f6386151000 r-xp 0000a000 00:2f 558599                     /lib64/libtinfo.so.6.2
7f6386151000-7f6386160000 r--p 00019000 00:2f 558599                     /lib64/libtinfo.so.6.2
7f6386160000-7f6386161000 r--p 00027000 00:2f 558599                     /lib64/libtinfo.so.6.2
7f6386161000-7f6386169000 rw-p 00028000 00:2f 558599                     /lib64/libtinfo.so.6.2
7f6386169000-7f6386172000 r--p 00000000 00:2f 563321                     /usr/lib64/libedit.so.0.0.60
7f6386172000-7f638618e000 r-xp 00009000 00:2f 563321                     /usr/lib64/libedit.so.0.0.60
7f638618e000-7f638619c000 r--p 00025000 00:2f 563321                     /usr/lib64/libedit.so.0.0.60
7f638619c000-7f638619e000 r--p 00032000 00:2f 563321                     /usr/lib64/libedit.so.0.0.60
7f638619e000-7f638619f000 rw-p 00034000 00:2f 563321                     /usr/lib64/libedit.so.0.0.60
7f638619f000-7f63861a3000 rw-p 00000000 00:00 0
7f63861a3000-7f63861a6000 r--p 00000000 00:2f 556941                     /lib64/libgcc_s.so.1
7f63861a6000-7f63861b7000 r-xp 00003000 00:2f 556941                     /lib64/libgcc_s.so.1
7f63861b7000-7f63861bb000 r--p 00014000 00:2f 556941                     /lib64/libgcc_s.so.1
7f63861bb000-7f63861bc000 r--p 00017000 00:2f 556941                     /lib64/libgcc_s.so.1
7f63861bc000-7f63861bd000 rw-p 00018000 00:2f 556941                     /lib64/libgcc_s.so.1
7f63861bd000-7f638625b000 r--p 00000000 00:2f 557920                     /usr/lib64/libstdc++.so.6.0.28
7f638625b000-7f6386338000 r-xp 0009e000 00:2f 557920                     /usr/lib64/libstdc++.so.6.0.28
7f6386338000-7f6386382000 r--p 0017b000 00:2f 557920                     /usr/lib64/libstdc++.so.6.0.28
7f6386382000-7f638638d000 r--p 001c4000 00:2f 557920                     /usr/lib64/libstdc++.so.6.0.28
7f638638d000-7f6386390000 rw-p 001cf000 00:2f 557920                     /usr/lib64/libstdc++.so.6.0.28
7f6386390000-7f6386393000 rw-p 00000000 00:00 0
7f6386393000-7f6386395000 r--p 00000000 00:2f 557991                     /usr/lib64/libdrm_nouveau.so.2.0.0
7f6386395000-7f6386399000 r-xp 00002000 00:2f 557991                     /usr/lib64/libdrm_nouveau.so.2.0.0
7f6386399000-7f638639b000 r--p 00006000 00:2f 557991                     /usr/lib64/libdrm_nouveau.so.2.0.0
7f638639b000-7f638639c000 r--p 00007000 00:2f 557991                     /usr/lib64/libdrm_nouveau.so.2.0.0
7f638639c000-7f638639d000 rw-p 00008000 00:2f 557991                     /usr/lib64/libdrm_nouveau.so.2.0.0
7f638639d000-7f63863a0000 r--p 00000000 00:2f 557997                     /usr/lib64/libdrm_amdgpu.so.1.0.0
7f63863a0000-7f63863a5000 r-xp 00003000 00:2f 557997                     /usr/lib64/libdrm_amdgpu.so.1.0.0
7f63863a5000-7f63863a7000 r--p 00008000 00:2f 557997                     /usr/lib64/libdrm_amdgpu.so.1.0.0
7f63863a7000-7f63863a8000 r--p 00009000 00:2f 557997                     /usr/lib64/libdrm_amdgpu.so.1.0.0
7f63863a8000-7f63863a9000 rw-p 0000a000 00:2f 557997                     /usr/lib64/libdrm_amdgpu.so.1.0.0
7f63863a9000-7f63863ad000 r--p 00000000 00:2f 557342                     /usr/lib64/libelf-0.179.so
7f63863ad000-7f63863bd000 r-xp 00004000 00:2f 557342                     /usr/lib64/libelf-0.179.so
7f63863bd000-7f63863c2000 r--p 00014000 00:2f 557342                     /usr/lib64/libelf-0.179.so
7f63863c2000-7f63863c3000 r--p 00018000 00:2f 557342                     /usr/lib64/libelf-0.179.so
7f63863c3000-7f63863c4000 rw-p 00019000 00:2f 557342                     /usr/lib64/libelf-0.179.so
7f63863c4000-7f63863c6000 r--p 00000000 00:2f 557988                     /usr/lib64/libdrm_radeon.so.1.0.1
7f63863c6000-7f63863cd000 r-xp 00002000 00:2f 557988                     /usr/lib64/libdrm_radeon.so.1.0.1
7f63863cd000-7f63863d1000 r--p 00009000 00:2f 557988                     /usr/lib64/libdrm_radeon.so.1.0.1
7f63863d1000-7f63863d2000 r--p 0000c000 00:2f 557988                     /usr/lib64/libdrm_radeon.so.1.0.1
7f63863d2000-7f63863d3000 rw-p 0000d000 00:2f 557988                     /usr/lib64/libdrm_radeon.so.1.0.1
7f63863d3000-7f63864bd000 r--p 00000000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f63864bd000-7f63871b8000 r-xp 000ea000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f63871b8000-7f6387577000 r--p 00de5000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f6387577000-7f6387578000 ---p 011a4000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f6387578000-7f638764c000 r--p 011a4000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f638764c000-7f63876c3000 rw-p 01278000 00:2f 564414                     /usr/lib64/dri/radeonsi_dri.so
7f63876c3000-7f63879a4000 rw-p 00000000 00:00 0
7f63879a4000-7f63879a5000 r--p 00000000 00:2f 556491                     /usr/lib64/libxshmfence.so.1.0.0
7f63879a5000-7f63879a6000 r-xp 00001000 00:2f 556491                     /usr/lib64/libxshmfence.so.1.0.0
7f63879a6000-7f63879a7000 r--p 00002000 00:2f 556491                     /usr/lib64/libxshmfence.so.1.0.0
7f63879a7000-7f63879a8000 r--p 00002000 00:2f 556491                     /usr/lib64/libxshmfence.so.1.0.0
7f63879a8000-7f63879a9000 rw-p 00003000 00:2f 556491                     /usr/lib64/libxshmfence.so.1.0.0
7f63879a9000-7f63879ac000 r--p 00000000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879ac000-7f63879af000 r-xp 00003000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879af000-7f63879b0000 r--p 00006000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879b0000-7f63879b1000 ---p 00007000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879b1000-7f63879b2000 r--p 00007000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879b2000-7f63879b3000 rw-p 00008000 00:2f 556512                     /usr/lib64/libxcb-sync.so.1.0.0
7f63879b3000-7f63879b4000 r--p 00000000 00:2f 556527                     /usr/lib64/libxcb-present.so.0.0.0
7f63879b4000-7f63879b5000 r-xp 00001000 00:2f 556527                     /usr/lib64/libxcb-present.so.0.0.0
7f63879b5000-7f63879b6000 r--p 00002000 00:2f 556527                     /usr/lib64/libxcb-present.so.0.0.0
7f63879b6000-7f63879b7000 r--p 00002000 00:2f 556527                     /usr/lib64/libxcb-present.so.0.0.0
7f63879b7000-7f63879b8000 rw-p 00003000 00:2f 556527                     /usr/lib64/libxcb-present.so.0.0.0
7f63879b8000-7f63879ba000 r--p 00000000 00:2f 556539                     /usr/lib64/libxcb-dri3.so.0.0.0
7f63879ba000-7f63879bb000 r-xp 00002000 00:2f 556539                     /usr/lib64/libxcb-dri3.so.0.0.0
7f63879bb000-7f63879bc000 r--p 00003000 00:2f 556539                     /usr/lib64/libxcb-dri3.so.0.0.0
7f63879bc000-7f63879bd000 r--p 00003000 00:2f 556539                     /usr/lib64/libxcb-dri3.so.0.0.0
7f63879bd000-7f63879be000 rw-p 00004000 00:2f 556539                     /usr/lib64/libxcb-dri3.so.0.0.0
7f63879be000-7f63879ca000 r--p 00000000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879ca000-7f63879d3000 r-xp 0000c000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879d3000-7f63879d8000 r--p 00015000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879d8000-7f63879d9000 ---p 0001a000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879d9000-7f63879db000 r--p 0001a000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879db000-7f63879dc000 rw-p 0001c000 00:2f 556536                     /usr/lib64/libxcb-glx.so.0.0.0
7f63879dc000-7f63879e1000 r--p 00000000 00:2f 556979                     /usr/lib64/libdrm.so.2.4.0
7f63879e1000-7f63879eb000 r-xp 00005000 00:2f 556979                     /usr/lib64/libdrm.so.2.4.0
7f63879eb000-7f63879ef000 r--p 0000f000 00:2f 556979                     /usr/lib64/libdrm.so.2.4.0
7f63879ef000-7f63879f0000 r--p 00012000 00:2f 556979                     /usr/lib64/libdrm.so.2.4.0
7f63879f0000-7f63879f1000 rw-p 00013000 00:2f 556979                     /usr/lib64/libdrm.so.2.4.0
7f63879f1000-7f63879fd000 r-xp 00000000 08:05 151354253                  /home/hornet/.openjfx/cache/14/libprism_es2.so
7f63879fd000-7f6387bfc000 ---p 0000c000 08:05 151354253                  /home/hornet/.openjfx/cache/14/libprism_es2.so
7f6387bfc000-7f6387bfd000 r--p 0000b000 08:05 151354253                  /home/hornet/.openjfx/cache/14/libprism_es2.so
7f6387bfd000-7f6387bfe000 rw-p 0000c000 08:05 151354253                  /home/hornet/.openjfx/cache/14/libprism_es2.so
7f6387bfe000-7f6387c02000 ---p 00000000 00:00 0
7f6387c02000-7f6387dff000 rw-p 00000000 00:00 0
7f6387dff000-7f6387e03000 ---p 00000000 00:00 0
7f6387e03000-7f6388000000 rw-p 00000000 00:00 0
7f6388000000-7f6388021000 rw-p 00000000 00:00 0
7f6388021000-7f638c000000 ---p 00000000 00:00 0
7f638c000000-7f638c092000 rw-p 00000000 00:00 0
7f638c092000-7f6390000000 ---p 00000000 00:00 0
7f6390000000-7f6390021000 rw-p 00000000 00:00 0
7f6390021000-7f6394000000 ---p 00000000 00:00 0
7f6394000000-7f6394021000 rw-p 00000000 00:00 0
7f6394021000-7f6398000000 ---p 00000000 00:00 0
7f6398000000-7f6398021000 rw-p 00000000 00:00 0
7f6398021000-7f639c000000 ---p 00000000 00:00 0
7f639c000000-7f639c021000 rw-p 00000000 00:00 0
7f639c021000-7f63a0000000 ---p 00000000 00:00 0
7f63a0000000-7f63a0021000 rw-p 00000000 00:00 0
7f63a0021000-7f63a4000000 ---p 00000000 00:00 0
7f63a4000000-7f63a4021000 rw-p 00000000 00:00 0
7f63a4021000-7f63a8000000 ---p 00000000 00:00 0
7f63a8000000-7f63a8021000 rw-p 00000000 00:00 0
7f63a8021000-7f63ac000000 ---p 00000000 00:00 0
7f63ac000000-7f63ac021000 rw-p 00000000 00:00 0
7f63ac021000-7f63b0000000 ---p 00000000 00:00 0
7f63b0000000-7f63b0021000 rw-p 00000000 00:00 0
7f63b0021000-7f63b4000000 ---p 00000000 00:00 0
7f63b4000000-7f63b4021000 rw-p 00000000 00:00 0
7f63b4021000-7f63b8000000 ---p 00000000 00:00 0
7f63b8000000-7f63b8021000 rw-p 00000000 00:00 0
7f63b8021000-7f63bc000000 ---p 00000000 00:00 0
7f63bc000000-7f63bc021000 rw-p 00000000 00:00 0
7f63bc021000-7f63c0000000 ---p 00000000 00:00 0
7f63c0000000-7f63c0811000 rw-p 00000000 00:00 0
7f63c0811000-7f63c4000000 ---p 00000000 00:00 0
7f63c4000000-7f63c4021000 rw-p 00000000 00:00 0
7f63c4021000-7f63c8000000 ---p 00000000 00:00 0
7f63c8000000-7f63c8021000 rw-p 00000000 00:00 0
7f63c8021000-7f63cc000000 ---p 00000000 00:00 0
7f63cc000000-7f63cc021000 rw-p 00000000 00:00 0
7f63cc021000-7f63d0000000 ---p 00000000 00:00 0
7f63d0000000-7f63d0021000 rw-p 00000000 00:00 0
7f63d0021000-7f63d4000000 ---p 00000000 00:00 0
7f63d4000000-7f63d4001000 r-xp 00000000 00:00 0
7f63d4001000-7f63d4002000 r--s 00000000 00:44 96906                      /var/cache/fontconfig/bae22641-418e-4e1f-8925-11fc7a60a696-x86_64.cache-7
7f63d4002000-7f63d4003000 r--p 00000000 00:2f 557158                     /usr/lib64/libXxf86vm.so.1.0.0
7f63d4003000-7f63d4006000 r-xp 00001000 00:2f 557158                     /usr/lib64/libXxf86vm.so.1.0.0
7f63d4006000-7f63d4007000 r--p 00004000 00:2f 557158                     /usr/lib64/libXxf86vm.so.1.0.0
7f63d4007000-7f63d4008000 r--p 00004000 00:2f 557158                     /usr/lib64/libXxf86vm.so.1.0.0
7f63d4008000-7f63d4009000 rw-p 00005000 00:2f 557158                     /usr/lib64/libXxf86vm.so.1.0.0
7f63d4009000-7f63d400b000 r--p 00000000 00:2f 556542                     /usr/lib64/libxcb-dri2.so.0.0.0
7f63d400b000-7f63d400d000 r-xp 00002000 00:2f 556542                     /usr/lib64/libxcb-dri2.so.0.0.0
7f63d400d000-7f63d400e000 r--p 00004000 00:2f 556542                     /usr/lib64/libxcb-dri2.so.0.0.0
7f63d400e000-7f63d400f000 r--p 00004000 00:2f 556542                     /usr/lib64/libxcb-dri2.so.0.0.0
7f63d400f000-7f63d4010000 rw-p 00005000 00:2f 556542                     /usr/lib64/libxcb-dri2.so.0.0.0
7f63d4010000-7f63d401c000 r--p 00000000 00:2f 557310                     /usr/lib64/libglapi.so.0.0.0
7f63d401c000-7f63d402a000 r-xp 0000c000 00:2f 557310                     /usr/lib64/libglapi.so.0.0.0
7f63d402a000-7f63d4043000 r--p 0001a000 00:2f 557310                     /usr/lib64/libglapi.so.0.0.0
7f63d4043000-7f63d4047000 r--p 00032000 00:2f 557310                     /usr/lib64/libglapi.so.0.0.0
7f63d4047000-7f63d4048000 rw-p 00036000 00:2f 557310                     /usr/lib64/libglapi.so.0.0.0
7f63d4048000-7f63d4049000 rw-p 00000000 00:00 0
7f63d4049000-7f63d4065000 r--p 00000000 00:2f 564268                     /usr/lib64/libGLX_mesa.so.0.0.0
7f63d4065000-7f63d40a7000 r-xp 0001c000 00:2f 564268                     /usr/lib64/libGLX_mesa.so.0.0.0
7f63d40a7000-7f63d40be000 r--p 0005e000 00:2f 564268                     /usr/lib64/libGLX_mesa.so.0.0.0
7f63d40be000-7f63d40c1000 r--p 00074000 00:2f 564268                     /usr/lib64/libGLX_mesa.so.0.0.0
7f63d40c1000-7f63d40c2000 rw-p 00077000 00:2f 564268                     /usr/lib64/libGLX_mesa.so.0.0.0
7f63d40c2000-7f63d40c3000 rw-p 00000000 00:00 0
7f63d40c3000-7f63d40c7000 ---p 00000000 00:00 0
7f63d40c7000-7f63d42c4000 rw-p 00000000 00:00 0
7f63d42c4000-7f63d42c8000 ---p 00000000 00:00 0
7f63d42c8000-7f63d44c5000 rw-p 00000000 00:00 0
7f63d44c5000-7f63d44c6000 r-xp 00000000 00:85 182517867                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/librmi.so
7f63d44c6000-7f63d46c5000 ---p 00001000 00:85 182517867                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/librmi.so
7f63d46c5000-7f63d46c6000 r--p 00000000 00:85 182517867                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/librmi.so
7f63d46c6000-7f63d46c7000 rw-p 00001000 00:85 182517867                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/librmi.so
7f63d46c7000-7f63d46cb000 ---p 00000000 00:00 0
7f63d46cb000-7f63d48c8000 rw-p 00000000 00:00 0
7f63d48c8000-7f63d48cc000 ---p 00000000 00:00 0
7f63d48cc000-7f63d4ac9000 rw-p 00000000 00:00 0
7f63d4ac9000-7f63d4acd000 ---p 00000000 00:00 0
7f63d4acd000-7f63d4eca000 rw-p 00000000 00:00 0
7f63d4eca000-7f63d4eff000 r--s 00000000 00:18 41011                      /run/nscd/dblgVjWj (deleted)
7f63d4eff000-7f63d4f00000 ---p 00000000 00:00 0
7f63d4f00000-7f63d5001000 rw-p 00000000 00:00 0
7f63d5001000-7f63d5002000 ---p 00000000 00:00 0
7f63d5002000-7f63d5103000 rw-p 00000000 00:00 0
7f63d5103000-7f63d5104000 ---p 00000000 00:00 0
7f63d5104000-7f63d5205000 rw-p 00000000 00:00 0
7f63d5205000-7f63d5206000 ---p 00000000 00:00 0
7f63d5206000-7f63d5307000 rw-p 00000000 00:00 0
7f63d5307000-7f63d5308000 ---p 00000000 00:00 0
7f63d5308000-7f63d5409000 rw-p 00000000 00:00 0
7f63d5409000-7f63d540a000 ---p 00000000 00:00 0
7f63d540a000-7f63d550b000 rw-p 00000000 00:00 0
7f63d550b000-7f63d550c000 ---p 00000000 00:00 0
7f63d550c000-7f63d560d000 rw-p 00000000 00:00 0
7f63d560d000-7f63d560e000 ---p 00000000 00:00 0
7f63d560e000-7f63d570f000 rw-p 00000000 00:00 0
7f63d570f000-7f63d5710000 ---p 00000000 00:00 0
7f63d5710000-7f63d5811000 rw-p 00000000 00:00 0
7f63d5811000-7f63d5815000 ---p 00000000 00:00 0
7f63d5815000-7f63d5a12000 rw-p 00000000 00:00 0
7f63d5a12000-7f63d5a52000 r-xp 00000000 00:85 182517943                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libsunec.so
7f63d5a52000-7f63d5c52000 ---p 00040000 00:85 182517943                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libsunec.so
7f63d5c52000-7f63d5c57000 r--p 00040000 00:85 182517943                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libsunec.so
7f63d5c57000-7f63d5c59000 rw-p 00045000 00:85 182517943                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libsunec.so
7f63d5c59000-7f63d5e59000 rw-p 00000000 00:00 0
7f63d5e59000-7f63d5e6d000 r--p 00000000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e6d000-7f63d5e87000 r-xp 00014000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e87000-7f63d5e94000 r--p 0002e000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e94000-7f63d5e95000 ---p 0003b000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e95000-7f63d5e9a000 r--p 0003b000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e9a000-7f63d5e9b000 rw-p 00040000 00:2f 589924                     /usr/lib64/gvfs/libgvfscommon.so
7f63d5e9b000-7f63d5ea6000 r--p 00000000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5ea6000-7f63d5ec0000 r-xp 0000b000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5ec0000-7f63d5ec9000 r--p 00025000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5ec9000-7f63d5eca000 ---p 0002e000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5eca000-7f63d5ecb000 r--p 0002e000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5ecb000-7f63d5ecc000 rw-p 0002f000 00:2f 589923                     /usr/lib64/gio/modules/libgvfsdbus.so
7f63d5ecc000-7f63d5ecd000 rw-p 00000000 00:00 0
7f63d5ecd000-7f63d5ecf000 r--p 00000000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ecf000-7f63d5ed2000 r-xp 00002000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ed2000-7f63d5ed5000 r--p 00005000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ed5000-7f63d5ed6000 ---p 00008000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ed6000-7f63d5ed7000 r--p 00008000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ed7000-7f63d5ed8000 rw-p 00009000 00:2f 511541                     /usr/lib64/libogg.so.0.8.4
7f63d5ed8000-7f63d5edc000 r--p 00000000 00:2f 511853                     /usr/lib64/libvorbis.so.0.4.8
7f63d5edc000-7f63d5ef3000 r-xp 00004000 00:2f 511853                     /usr/lib64/libvorbis.so.0.4.8
7f63d5ef3000-7f63d5f04000 r--p 0001b000 00:2f 511853                     /usr/lib64/libvorbis.so.0.4.8
7f63d5f04000-7f63d5f05000 r--p 0002b000 00:2f 511853                     /usr/lib64/libvorbis.so.0.4.8
7f63d5f05000-7f63d5f06000 rw-p 0002c000 00:2f 511853                     /usr/lib64/libvorbis.so.0.4.8
7f63d5f06000-7f63d5f09000 r--p 00000000 00:2f 556848                     /usr/lib64/libltdl.so.7.3.1
7f63d5f09000-7f63d5f0e000 r-xp 00003000 00:2f 556848                     /usr/lib64/libltdl.so.7.3.1
7f63d5f0e000-7f63d5f10000 r--p 00008000 00:2f 556848                     /usr/lib64/libltdl.so.7.3.1
7f63d5f10000-7f63d5f11000 r--p 00009000 00:2f 556848                     /usr/lib64/libltdl.so.7.3.1
7f63d5f11000-7f63d5f12000 rw-p 0000a000 00:2f 556848                     /usr/lib64/libltdl.so.7.3.1
7f63d5f12000-7f63d5f14000 r--p 00000000 00:2f 556570                     /usr/lib64/libvorbisfile.so.3.3.7
7f63d5f14000-7f63d5f19000 r-xp 00002000 00:2f 556570                     /usr/lib64/libvorbisfile.so.3.3.7
7f63d5f19000-7f63d5f1a000 r--p 00007000 00:2f 556570                     /usr/lib64/libvorbisfile.so.3.3.7
7f63d5f1a000-7f63d5f1b000 r--p 00007000 00:2f 556570                     /usr/lib64/libvorbisfile.so.3.3.7
7f63d5f1b000-7f63d5f1c000 rw-p 00008000 00:2f 556570                     /usr/lib64/libvorbisfile.so.3.3.7
7f63d5f1c000-7f63d5f1f000 r--p 00000000 00:2f 559091                     /usr/lib64/libcanberra.so.0.2.5
7f63d5f1f000-7f63d5f28000 r-xp 00003000 00:2f 559091                     /usr/lib64/libcanberra.so.0.2.5
7f63d5f28000-7f63d5f2c000 r--p 0000c000 00:2f 559091                     /usr/lib64/libcanberra.so.0.2.5
7f63d5f2c000-7f63d5f2d000 r--p 0000f000 00:2f 559091                     /usr/lib64/libcanberra.so.0.2.5
7f63d5f2d000-7f63d5f2e000 rw-p 00010000 00:2f 559091                     /usr/lib64/libcanberra.so.0.2.5
7f63d5f2e000-7f63d5f46000 r--p 00000000 00:3c 41358                      /tmp/+JXF3133700705076753235.tmp
7f63d5f46000-7f63d5f47000 r-xp 00000000 00:00 0
7f63d5f47000-7f63d5f48000 r--p 00000000 00:2f 557814                     /usr/lib64/libgthread-2.0.so.0.6400.2
7f63d5f48000-7f63d5f49000 r-xp 00001000 00:2f 557814                     /usr/lib64/libgthread-2.0.so.0.6400.2
7f63d5f49000-7f63d5f4a000 r--p 00002000 00:2f 557814                     /usr/lib64/libgthread-2.0.so.0.6400.2
7f63d5f4a000-7f63d5f4b000 r--p 00002000 00:2f 557814                     /usr/lib64/libgthread-2.0.so.0.6400.2
7f63d5f4b000-7f63d5f4c000 rw-p 00003000 00:2f 557814                     /usr/lib64/libgthread-2.0.so.0.6400.2
7f63d5f4c000-7f63d5f50000 r--p 00000000 00:2f 511567                     /usr/lib64/libgpg-error.so.0.28.0
7f63d5f50000-7f63d5f61000 r-xp 00004000 00:2f 511567                     /usr/lib64/libgpg-error.so.0.28.0
7f63d5f61000-7f63d5f6a000 r--p 00015000 00:2f 511567                     /usr/lib64/libgpg-error.so.0.28.0
7f63d5f6a000-7f63d5f6b000 r--p 0001d000 00:2f 511567                     /usr/lib64/libgpg-error.so.0.28.0
7f63d5f6b000-7f63d5f6c000 rw-p 0001e000 00:2f 511567                     /usr/lib64/libgpg-error.so.0.28.0
7f63d5f6c000-7f63d5f79000 r--p 00000000 00:2f 556937                     /usr/lib64/libgcrypt.so.20.2.5
7f63d5f79000-7f63d6045000 r-xp 0000d000 00:2f 556937                     /usr/lib64/libgcrypt.so.20.2.5
7f63d6045000-7f63d607e000 r--p 000d9000 00:2f 556937                     /usr/lib64/libgcrypt.so.20.2.5
7f63d607e000-7f63d6080000 r--p 00111000 00:2f 556937                     /usr/lib64/libgcrypt.so.20.2.5
7f63d6080000-7f63d6086000 rw-p 00113000 00:2f 556937                     /usr/lib64/libgcrypt.so.20.2.5
7f63d6086000-7f63d6089000 r--p 00000000 00:2f 556844                     /usr/lib64/liblz4.so.1.9.2
7f63d6089000-7f63d60a1000 r-xp 00003000 00:2f 556844                     /usr/lib64/liblz4.so.1.9.2
7f63d60a1000-7f63d60a4000 r--p 0001b000 00:2f 556844                     /usr/lib64/liblz4.so.1.9.2
7f63d60a4000-7f63d60a5000 r--p 0001d000 00:2f 556844                     /usr/lib64/liblz4.so.1.9.2
7f63d60a5000-7f63d60a6000 rw-p 0001e000 00:2f 556844                     /usr/lib64/liblz4.so.1.9.2
7f63d60a6000-7f63d60a9000 r--p 00000000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60a9000-7f63d60d4000 r-xp 00003000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60d4000-7f63d60df000 r--p 0002e000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60df000-7f63d60e0000 ---p 00039000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60e0000-7f63d60e1000 r--p 00039000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60e1000-7f63d60e2000 rw-p 0003a000 00:2f 556840                     /usr/lib64/liblzma.so.5.2.5
7f63d60e2000-7f63d60e4000 r--p 00000000 00:2f 530923                     /usr/lib64/libdatrie.so.1.3.3
7f63d60e4000-7f63d60e7000 r-xp 00002000 00:2f 530923                     /usr/lib64/libdatrie.so.1.3.3
7f63d60e7000-7f63d60e8000 r--p 00005000 00:2f 530923                     /usr/lib64/libdatrie.so.1.3.3
7f63d60e8000-7f63d60e9000 r--p 00005000 00:2f 530923                     /usr/lib64/libdatrie.so.1.3.3
7f63d60e9000-7f63d60ea000 rw-p 00006000 00:2f 530923                     /usr/lib64/libdatrie.so.1.3.3
7f63d60ea000-7f63d60fd000 r--p 00000000 00:2f 557916                     /usr/lib64/libsystemd.so.0.28.0
7f63d60fd000-7f63d6171000 r-xp 00013000 00:2f 557916                     /usr/lib64/libsystemd.so.0.28.0
7f63d6171000-7f63d6196000 r--p 00087000 00:2f 557916                     /usr/lib64/libsystemd.so.0.28.0
7f63d6196000-7f63d619a000 r--p 000ab000 00:2f 557916                     /usr/lib64/libsystemd.so.0.28.0
7f63d619a000-7f63d619b000 rw-p 000af000 00:2f 557916                     /usr/lib64/libsystemd.so.0.28.0
7f63d619b000-7f63d619c000 rw-p 00000000 00:00 0
7f63d619c000-7f63d619f000 r--p 00000000 00:2f 512850                     /usr/lib64/libGLX.so.0.0.0
7f63d619f000-7f63d61a9000 r-xp 00003000 00:2f 512850                     /usr/lib64/libGLX.so.0.0.0
7f63d61a9000-7f63d61ac000 r--p 0000d000 00:2f 512850                     /usr/lib64/libGLX.so.0.0.0
7f63d61ac000-7f63d61ad000 r--p 0000f000 00:2f 512850                     /usr/lib64/libGLX.so.0.0.0
7f63d61ad000-7f63d61ae000 rw-p 00010000 00:2f 512850                     /usr/lib64/libGLX.so.0.0.0
7f63d61ae000-7f63d61ce000 rw-p 00000000 00:00 0
7f63d61ce000-7f63d620f000 r--p 00000000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d620f000-7f63d622e000 r-xp 00041000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d622e000-7f63d6241000 r--p 00060000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d6241000-7f63d6242000 ---p 00073000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d6242000-7f63d626b000 r--p 00073000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d626b000-7f63d626c000 rw-p 0009c000 00:2f 512852                     /usr/lib64/libGLdispatch.so.0.0.0
7f63d626c000-7f63d628c000 rw-p 00000000 00:00 0
7f63d628c000-7f63d628e000 r--p 00000000 00:2f 511639                     /usr/lib64/libbz2.so.1.0.6
7f63d628e000-7f63d62a7000 r-xp 00002000 00:2f 511639                     /usr/lib64/libbz2.so.1.0.6
7f63d62a7000-7f63d62aa000 r--p 0001b000 00:2f 511639                     /usr/lib64/libbz2.so.1.0.6
7f63d62aa000-7f63d62ab000 r--p 0001d000 00:2f 511639                     /usr/lib64/libbz2.so.1.0.6
7f63d62ab000-7f63d62ac000 rw-p 0001e000 00:2f 511639                     /usr/lib64/libbz2.so.1.0.6
7f63d62ac000-7f63d62b0000 r--p 00000000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62b0000-7f63d62d3000 r-xp 00004000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62d3000-7f63d62dd000 r--p 00027000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62dd000-7f63d62de000 ---p 00031000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62de000-7f63d62e0000 r--p 00031000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62e0000-7f63d62e1000 rw-p 00033000 00:2f 511597                     /usr/lib64/libexpat.so.1.6.11
7f63d62e1000-7f63d62e4000 r--p 00000000 00:2f 530992                     /usr/lib64/libgraphite2.so.3.2.1
7f63d62e4000-7f63d62fc000 r-xp 00003000 00:2f 530992                     /usr/lib64/libgraphite2.so.3.2.1
7f63d62fc000-7f63d6300000 r--p 0001b000 00:2f 530992                     /usr/lib64/libgraphite2.so.3.2.1
7f63d6300000-7f63d6302000 r--p 0001e000 00:2f 530992                     /usr/lib64/libgraphite2.so.3.2.1
7f63d6302000-7f63d6303000 rw-p 00020000 00:2f 530992                     /usr/lib64/libgraphite2.so.3.2.1
7f63d6303000-7f63d6305000 r--p 00000000 00:2f 531707                     /usr/lib64/libthai.so.0.3.0
7f63d6305000-7f63d6309000 r-xp 00002000 00:2f 531707                     /usr/lib64/libthai.so.0.3.0
7f63d6309000-7f63d630c000 r--p 00006000 00:2f 531707                     /usr/lib64/libthai.so.0.3.0
7f63d630c000-7f63d630d000 r--p 00008000 00:2f 531707                     /usr/lib64/libthai.so.0.3.0
7f63d630d000-7f63d630e000 rw-p 00009000 00:2f 531707                     /usr/lib64/libthai.so.0.3.0
7f63d630e000-7f63d631e000 r--p 00000000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d631e000-7f63d6334000 r-xp 00010000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d6334000-7f63d6341000 r--p 00026000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d6341000-7f63d6342000 ---p 00033000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d6342000-7f63d6345000 r--p 00033000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d6345000-7f63d6346000 rw-p 00036000 00:2f 558759                     /usr/lib64/libatspi.so.0.0.1
7f63d6346000-7f63d6354000 r--p 00000000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6354000-7f63d6380000 r-xp 0000e000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6380000-7f63d6392000 r--p 0003a000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6392000-7f63d6393000 ---p 0004c000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6393000-7f63d6394000 r--p 0004c000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6394000-7f63d6395000 rw-p 0004d000 00:2f 11759                      /usr/lib64/libdbus-1.so.3.19.11
7f63d6395000-7f63d6396000 rw-p 00000000 00:00 0
7f63d6396000-7f63d63de000 r--p 00000000 00:2f 512844                     /usr/lib64/libGL.so.1.7.0
7f63d63de000-7f63d63fd000 r-xp 00048000 00:2f 512844                     /usr/lib64/libGL.so.1.7.0
7f63d63fd000-7f63d6412000 r--p 00067000 00:2f 512844                     /usr/lib64/libGL.so.1.7.0
7f63d6412000-7f63d642d000 r--p 0007b000 00:2f 512844                     /usr/lib64/libGL.so.1.7.0
7f63d642d000-7f63d642e000 rw-p 00096000 00:2f 512844                     /usr/lib64/libGL.so.1.7.0
7f63d642e000-7f63d642f000 rw-p 00000000 00:00 0
7f63d642f000-7f63d6435000 r--p 00000000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d6435000-7f63d643a000 r-xp 00006000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d643a000-7f63d643c000 r--p 0000b000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d643c000-7f63d643d000 ---p 0000d000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d643d000-7f63d643e000 r--p 0000d000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d643e000-7f63d643f000 rw-p 0000e000 00:2f 521720                     /usr/lib64/libxcb-render.so.0.0.0
7f63d643f000-7f63d6445000 r--p 00000000 00:2f 511762                     /usr/lib64/libpng16.so.16.37.0
7f63d6445000-7f63d647b000 r-xp 00006000 00:2f 511762                     /usr/lib64/libpng16.so.16.37.0
7f63d647b000-7f63d6485000 r--p 0003c000 00:2f 511762                     /usr/lib64/libpng16.so.16.37.0
7f63d6485000-7f63d6486000 r--p 00045000 00:2f 511762                     /usr/lib64/libpng16.so.16.37.0
7f63d6486000-7f63d6487000 rw-p 00046000 00:2f 511762                     /usr/lib64/libpng16.so.16.37.0
7f63d6487000-7f63d6492000 r--p 00000000 00:2f 556697                     /usr/lib64/libpixman-1.so.0.40.0
7f63d6492000-7f63d6514000 r-xp 0000b000 00:2f 556697                     /usr/lib64/libpixman-1.so.0.40.0
7f63d6514000-7f63d6526000 r--p 0008d000 00:2f 556697                     /usr/lib64/libpixman-1.so.0.40.0
7f63d6526000-7f63d652e000 r--p 0009e000 00:2f 556697                     /usr/lib64/libpixman-1.so.0.40.0
7f63d652e000-7f63d652f000 rw-p 000a6000 00:2f 556697                     /usr/lib64/libpixman-1.so.0.40.0
7f63d652f000-7f63d6534000 r--p 00000000 00:2f 531751                     /usr/lib64/libxkbcommon.so.0.0.0
7f63d6534000-7f63d6550000 r-xp 00005000 00:2f 531751                     /usr/lib64/libxkbcommon.so.0.0.0
7f63d6550000-7f63d656e000 r--p 00021000 00:2f 531751                     /usr/lib64/libxkbcommon.so.0.0.0
7f63d656e000-7f63d6570000 r--p 0003e000 00:2f 531751                     /usr/lib64/libxkbcommon.so.0.0.0
7f63d6570000-7f63d6571000 rw-p 00040000 00:2f 531751                     /usr/lib64/libxkbcommon.so.0.0.0
7f63d6571000-7f63d657e000 r--p 00000000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d657e000-7f63d65ef000 r-xp 0000d000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d65ef000-7f63d6623000 r--p 0007e000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d6623000-7f63d6624000 ---p 000b2000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d6624000-7f63d662b000 r--p 000b2000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d662b000-7f63d662c000 rw-p 000b9000 00:2f 521668                     /usr/lib64/libfreetype.so.6.17.1
7f63d662c000-7f63d6634000 r--p 00000000 00:2f 522053                     /usr/lib64/libfontconfig.so.1.12.0
7f63d6634000-7f63d6657000 r-xp 00008000 00:2f 522053                     /usr/lib64/libfontconfig.so.1.12.0
7f63d6657000-7f63d666e000 r--p 0002b000 00:2f 522053                     /usr/lib64/libfontconfig.so.1.12.0
7f63d666e000-7f63d6670000 r--p 00041000 00:2f 522053                     /usr/lib64/libfontconfig.so.1.12.0
7f63d6670000-7f63d6671000 rw-p 00043000 00:2f 522053                     /usr/lib64/libfontconfig.so.1.12.0
7f63d6671000-7f63d667b000 r--p 00000000 00:2f 557805                     /usr/lib64/libharfbuzz.so.0.20600.5
7f63d667b000-7f63d6718000 r-xp 0000a000 00:2f 557805                     /usr/lib64/libharfbuzz.so.0.20600.5
7f63d6718000-7f63d6748000 r--p 000a7000 00:2f 557805                     /usr/lib64/libharfbuzz.so.0.20600.5
7f63d6748000-7f63d6749000 r--p 000d6000 00:2f 557805                     /usr/lib64/libharfbuzz.so.0.20600.5
7f63d6749000-7f63d674a000 rw-p 000d7000 00:2f 557805                     /usr/lib64/libharfbuzz.so.0.20600.5
7f63d674a000-7f63d674b000 rw-p 00000000 00:00 0
7f63d674b000-7f63d67b0000 r--p 00000000 00:2f 530930                     /usr/lib64/libepoxy.so.0.0.0
7f63d67b0000-7f63d6813000 r-xp 00065000 00:2f 530930                     /usr/lib64/libepoxy.so.0.0.0
7f63d6813000-7f63d686e000 r--p 000c8000 00:2f 530930                     /usr/lib64/libepoxy.so.0.0.0
7f63d686e000-7f63d6876000 r--p 00122000 00:2f 530930                     /usr/lib64/libepoxy.so.0.0.0
7f63d6876000-7f63d687d000 rw-p 0012a000 00:2f 530930                     /usr/lib64/libepoxy.so.0.0.0
7f63d687d000-7f63d687e000 rw-p 00000000 00:00 0
7f63d687e000-7f63d690e000 r--p 00000000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d690e000-7f63d6c55000 r-xp 00090000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d6c55000-7f63d6fe6000 r--p 003d7000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d6fe6000-7f63d6fe7000 ---p 00768000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d6fe7000-7f63d6ff2000 r--p 00768000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d6ff2000-7f63d6ff9000 rw-p 00773000 00:2f 589345                     /usr/lib64/libgtk-3.so.0.2404.16
7f63d6ff9000-7f63d6ffe000 rw-p 00000000 00:00 0
7f63d6ffe000-7f63d6fff000 ---p 00000000 00:00 0
7f63d6fff000-7f63d77ff000 rw-p 00000000 00:00 0
7f63d77ff000-7f63d7800000 ---p 00000000 00:00 0
7f63d7800000-7f63d8000000 rw-p 00000000 00:00 0
7f63d8000000-7f63d81d6000 rw-p 00000000 00:00 0
7f63d81d6000-7f63dc000000 ---p 00000000 00:00 0
7f63dc000000-7f63dc021000 rw-p 00000000 00:00 0
7f63dc021000-7f63e0000000 ---p 00000000 00:00 0
7f63e0000000-7f63e0021000 rw-p 00000000 00:00 0
7f63e0021000-7f63e4000000 ---p 00000000 00:00 0
7f63e4000000-7f63e4021000 rw-p 00000000 00:00 0
7f63e4021000-7f63e8000000 ---p 00000000 00:00 0
7f63e8000000-7f63e8021000 rw-p 00000000 00:00 0
7f63e8021000-7f63ec000000 ---p 00000000 00:00 0
7f63ec000000-7f63ec021000 rw-p 00000000 00:00 0
7f63ec021000-7f63f0000000 ---p 00000000 00:00 0
7f63f0000000-7f63f1277000 rw-p 00000000 00:00 0
7f63f1277000-7f63f4000000 ---p 00000000 00:00 0
7f63f4000000-7f63f470e000 rw-p 00000000 00:00 0
7f63f470e000-7f63f8000000 ---p 00000000 00:00 0
7f63f8000000-7f63f8021000 rw-p 00000000 00:00 0
7f63f8021000-7f63fc000000 ---p 00000000 00:00 0
7f63fc000000-7f63fc021000 rw-p 00000000 00:00 0
7f63fc021000-7f6400000000 ---p 00000000 00:00 0
7f6400000000-7f6400021000 rw-p 00000000 00:00 0
7f6400021000-7f6404000000 ---p 00000000 00:00 0
7f6404000000-7f6404021000 rw-p 00000000 00:00 0
7f6404021000-7f6408000000 ---p 00000000 00:00 0
7f6408000000-7f6408021000 rw-p 00000000 00:00 0
7f6408021000-7f640c000000 ---p 00000000 00:00 0
7f640c000000-7f640c001000 rw-s 1066ed000 00:06 18141                     /dev/dri/renderD128
7f640c001000-7f640c003000 r--p 00000000 00:2f 556587                     /usr/lib64/libuuid.so.1.3.0
7f640c003000-7f640c007000 r-xp 00002000 00:2f 556587                     /usr/lib64/libuuid.so.1.3.0
7f640c007000-7f640c008000 r--p 00006000 00:2f 556587                     /usr/lib64/libuuid.so.1.3.0
7f640c008000-7f640c009000 r--p 00006000 00:2f 556587                     /usr/lib64/libuuid.so.1.3.0
7f640c009000-7f640c00a000 rw-p 00007000 00:2f 556587                     /usr/lib64/libuuid.so.1.3.0
7f640c00a000-7f640c00b000 r--p 00000000 00:2f 521723                     /usr/lib64/libxcb-shm.so.0.0.0
7f640c00b000-7f640c00c000 r-xp 00001000 00:2f 521723                     /usr/lib64/libxcb-shm.so.0.0.0
7f640c00c000-7f640c00d000 r--p 00002000 00:2f 521723                     /usr/lib64/libxcb-shm.so.0.0.0
7f640c00d000-7f640c00e000 r--p 00002000 00:2f 521723                     /usr/lib64/libxcb-shm.so.0.0.0
7f640c00e000-7f640c00f000 rw-p 00003000 00:2f 521723                     /usr/lib64/libxcb-shm.so.0.0.0
7f640c00f000-7f640c012000 r--p 00000000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c012000-7f640c01a000 r-xp 00003000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c01a000-7f640c01d000 r--p 0000b000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c01d000-7f640c01e000 ---p 0000e000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c01e000-7f640c01f000 r--p 0000e000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c01f000-7f640c020000 rw-p 0000f000 00:2f 512842                     /usr/lib64/libEGL.so.1.1.0
7f640c020000-7f640c026000 r--p 00000000 00:2f 557956                     /usr/lib64/libwayland-client.so.0.3.0
7f640c026000-7f640c02b000 r-xp 00006000 00:2f 557956                     /usr/lib64/libwayland-client.so.0.3.0
7f640c02b000-7f640c02e000 r--p 0000b000 00:2f 557956                     /usr/lib64/libwayland-client.so.0.3.0
7f640c02e000-7f640c030000 r--p 0000d000 00:2f 557956                     /usr/lib64/libwayland-client.so.0.3.0
7f640c030000-7f640c031000 rw-p 0000f000 00:2f 557956                     /usr/lib64/libwayland-client.so.0.3.0
7f640c031000-7f640c032000 r--p 00000000 00:2f 556559                     /usr/lib64/libwayland-egl.so.1.0.0
7f640c032000-7f640c033000 r-xp 00001000 00:2f 556559                     /usr/lib64/libwayland-egl.so.1.0.0
7f640c033000-7f640c034000 r--p 00002000 00:2f 556559                     /usr/lib64/libwayland-egl.so.1.0.0
7f640c034000-7f640c035000 r--p 00002000 00:2f 556559                     /usr/lib64/libwayland-egl.so.1.0.0
7f640c035000-7f640c036000 rw-p 00003000 00:2f 556559                     /usr/lib64/libwayland-egl.so.1.0.0
7f640c036000-7f640c038000 r--p 00000000 00:2f 558717                     /usr/lib64/libwayland-cursor.so.0.0.0
7f640c038000-7f640c03a000 r-xp 00002000 00:2f 558717                     /usr/lib64/libwayland-cursor.so.0.0.0
7f640c03a000-7f640c03b000 r--p 00004000 00:2f 558717                     /usr/lib64/libwayland-cursor.so.0.0.0
7f640c03b000-7f640c03c000 r--p 00004000 00:2f 558717                     /usr/lib64/libwayland-cursor.so.0.0.0
7f640c03c000-7f640c040000 rw-p 00005000 00:2f 558717                     /usr/lib64/libwayland-cursor.so.0.0.0
7f640c040000-7f640c04f000 r--p 00000000 00:2f 531877                     /usr/lib64/libpango-1.0.so.0.4400.7
7f640c04f000-7f640c073000 r-xp 0000f000 00:2f 531877                     /usr/lib64/libpango-
7f640c073000-7f640c08a000 r--p 00033000 00:2f 531877                     /usr/lib64/libpango-1.0.so.0.4400.7
7f640c08a000-7f640c08d000 r--p 00049000 00:2f 531877                     /usr/lib64/libpango-1.0.so.0.4400.7
7f640c08d000-7f640c08e000 rw-p 0004c000 00:2f 531877                     /usr/lib64/libpango-1.0.so.0.4400.7
7f640c08e000-7f640c095000 r--p 00000000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c095000-7f640c09f000 r-xp 00007000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c09f000-7f640c0a3000 r--p 00011000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c0a3000-7f640c0a4000 ---p 00015000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c0a4000-7f640c0a5000 r--p 00015000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c0a5000-7f640c0a6000 rw-p 00016000 00:2f 531881                     /usr/lib64/libpangoft2-1.0.so.0.4400.7
7f640c0a6000-7f640c0a8000 r--p 00000000 00:2f 530970                     /usr/lib64/libfribidi.so.0.4.0
7f640c0a8000-7f640c0ad000 r-xp 00002000 00:2f 530970                     /usr/lib64/libfribidi.so.0.4.0
7f640c0ad000-7f640c0c2000 r--p 00007000 00:2f 530970                     /usr/lib64/libfribidi.so.0.4.0
7f640c0c2000-7f640c0c3000 r--p 0001b000 00:2f 530970                     /usr/lib64/libfribidi.so.0.4.0
7f640c0c3000-7f640c0c4000 rw-p 0001c000 00:2f 530970                     /usr/lib64/libfribidi.so.0.4.0
7f640c0c4000-7f640c0d1000 r--p 00000000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0d1000-7f640c0e8000 r-xp 0000d000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0e8000-7f640c0f6000 r--p 00024000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0f6000-7f640c0f7000 ---p 00032000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0f7000-7f640c0f8000 r--p 00032000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0f8000-7f640c0fa000 rw-p 00033000 00:2f 531833                     /usr/lib64/libatk-bridge-2.0.so.0.0.0
7f640c0fa000-7f640c0fb000 rw-p 00000000 00:00 0
7f640c0fb000-7f640c106000 r--p 00000000 00:2f 558763                     /usr/lib64/libatk-1.0.so.0.23609.1
7f640c106000-7f640c114000 r-xp 0000b000 00:2f 558763                     /usr/lib64/libatk-1.0.so.0.23609.1
7f640c114000-7f640c120000 r--p 00019000 00:2f 558763                     /usr/lib64/libatk-1.0.so.0.23609.1
7f640c120000-7f640c123000 r--p 00024000 00:2f 558763                     /usr/lib64/libatk-1.0.so.0.23609.1
7f640c123000-7f640c124000 rw-p 00027000 00:2f 558763                     /usr/lib64/libatk-1.0.so.0.23609.1
7f640c124000-7f640c12b000 r--p 00000000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c12b000-7f640c141000 r-xp 00007000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c141000-7f640c149000 r--p 0001d000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c149000-7f640c14a000 ---p 00025000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c14a000-7f640c14b000 r--p 00025000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c14b000-7f640c14c000 rw-p 00026000 00:2f 531498                     /usr/lib64/libgdk_pixbuf-2.0.so.0.4000.0
7f640c14c000-7f640c161000 r--p 00000000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c161000-7f640c22d000 r-xp 00015000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c22d000-7f640c267000 r--p 000e1000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c267000-7f640c268000 ---p 0011b000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c268000-7f640c26b000 r--p 0011b000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c26b000-7f640c26d000 rw-p 0011e000 00:2f 522382                     /usr/lib64/libcairo.so.2.11600.0
7f640c26d000-7f640c26e000 rw-p 00000000 00:00 0
7f640c26e000-7f640c272000 r--p 00000000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c272000-7f640c274000 r-xp 00004000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c274000-7f640c276000 r--p 00006000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c276000-7f640c277000 ---p 00008000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c277000-7f640c279000 r--p 00008000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c279000-7f640c27a000 rw-p 0000a000 00:2f 530909                     /usr/lib64/libcairo-gobject.so.2.11600.0
7f640c27a000-7f640c27f000 r--p 00000000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c27f000-7f640c286000 r-xp 00005000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c286000-7f640c288000 r--p 0000c000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c288000-7f640c289000 ---p 0000e000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c289000-7f640c28a000 r--p 0000e000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c28a000-7f640c28b000 rw-p 0000f000 00:2f 531879                     /usr/lib64/libpangocairo-1.0.so.0.4400.7
7f640c28b000-7f640c2b7000 r--p 00000000 00:2f 589343                     /usr/lib64/libgdk-3.so.0.2404.16
7f640c2b7000-7f640c330000 r-xp 0002c000 00:2f 589343                     /usr/lib64/libgdk-3.so.0.2404.16
7f640c330000-7f640c37c000 r--p 000a5000 00:2f 589343                     /usr/lib64/libgdk-3.so.0.2404.16
7f640c37c000-7f640c383000 r--p 000f0000 00:2f 589343                     /usr/lib64/libgdk-3.so.0.2404.16
7f640c383000-7f640c386000 rw-p 000f7000 00:2f 589343                     /usr/lib64/libgdk-3.so.0.2404.16
7f640c386000-7f640c387000 rw-p 00000000 00:00 0
7f640c387000-7f640c38b000 ---p 00000000 00:00 0
7f640c38b000-7f640c588000 rw-p 00000000 00:00 0
7f640c588000-7f640c58c000 ---p 00000000 00:00 0
7f640c58c000-7f640c789000 rw-p 00000000 00:00 0
7f640c789000-7f640c78c000 r--p 00000000 00:2f 512936                     /usr/lib64/libXcursor.so.1.0.2
7f640c78c000-7f640c792000 r-xp 00003000 00:2f 512936                     /usr/lib64/libXcursor.so.1.0.2
7f640c792000-7f640c794000 r--p 00009000 00:2f 512936                     /usr/lib64/libXcursor.so.1.0.2
7f640c794000-7f640c795000 r--p 0000a000 00:2f 512936                     /usr/lib64/libXcursor.so.1.0.2
7f640c795000-7f640c796000 rw-p 0000b000 00:2f 512936                     /usr/lib64/libXcursor.so.1.0.2
7f640c796000-7f640c797000 rwxp 00000000 00:00 0
7f640c797000-7f640c798000 rw-s 1066ec000 00:06 18141                     /dev/dri/renderD128
7f640c798000-7f640c799000 rw-s 118919000 00:06 18141                     /dev/dri/renderD128
7f640c799000-7f640c79a000 r--p 00000000 00:2f 557184                     /usr/lib64/libX11-xcb.so.1.0.0
7f640c79a000-7f640c79b000 r-xp 00001000 00:2f 557184                     /usr/lib64/libX11-xcb.so.1.0.0
7f640c79b000-7f640c79c000 r--p 00002000 00:2f 557184                     /usr/lib64/libX11-xcb.so.1.0.0
7f640c79c000-7f640c79d000 r--p 00002000 00:2f 557184                     /usr/lib64/libX11-xcb.so.1.0.0
7f640c79d000-7f640c79e000 rw-p 00003000 00:2f 557184                     /usr/lib64/libX11-xcb.so.1.0.0
7f640c79e000-7f640c7a0000 r--p 00000000 00:2f 239363                     /usr/lib64/libcanberra-gtk3.so.0.1.9
7f640c7a0000-7f640c7a2000 r-xp 00002000 00:2f 239363                     /usr/lib64/libcanberra-gtk3.so.0.1.9
7f640c7a2000-7f640c7a3000 r--p 00004000 00:2f 239363                     /usr/lib64/libcanberra-gtk3.so.0.1.9
7f640c7a3000-7f640c7a4000 r--p 00004000 00:2f 239363                     /usr/lib64/libcanberra-gtk3.so.0.1.9
7f640c7a4000-7f640c7a5000 rw-p 00005000 00:2f 239363                     /usr/lib64/libcanberra-gtk3.so.0.1.9
7f640c7a5000-7f640c7a7000 r--p 00000000 00:2f 246180                     /usr/lib64/gtk-3.0/modules/libcanberra-gtk3-module.so
7f640c7a7000-7f640c7aa000 r-xp 00002000 00:2f 246180                     /usr/lib64/gtk-3.0/modules/libcanberra-gtk3-module.so
7f640c7aa000-7f640c7ab000 r--p 00005000 00:2f 246180                     /usr/lib64/gtk-3.0/modules/libcanberra-gtk3-module.so
7f640c7ab000-7f640c7ac000 r--p 00005000 00:2f 246180                     /usr/lib64/gtk-3.0/modules/libcanberra-gtk3-module.so
7f640c7ac000-7f640c7ad000 rw-p 00006000 00:2f 246180                     /usr/lib64/gtk-3.0/modules/libcanberra-gtk3-module.so
7f640c7ad000-7f640c7ae000 r--p 00000000 00:2f 544713                     /usr/share/locale/en/LC_MESSAGES/gtk30-properties.mo
7f640c7ae000-7f640c7af000 r--p 00000000 00:2f 544714                     /usr/share/locale/en/LC_MESSAGES/gtk30.mo
7f640c7af000-7f640c7b0000 ---p 00000000 00:00 0
7f640c7b0000-7f640cfb0000 rw-p 00000000 00:00 0
7f640cfb0000-7f640cfe3000 r--p 00000000 00:2f 600340                     /usr/share/glib-2.0/schemas/gschemas.compiled
7f640cfe3000-7f640cfeb000 r--p 00000000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640cfeb000-7f640d008000 r-xp 00008000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640d008000-7f640d011000 r--p 00025000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640d011000-7f640d012000 ---p 0002e000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640d012000-7f640d016000 r--p 0002e000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640d016000-7f640d017000 rw-p 00032000 00:2f 557043                     /usr/lib64/libblkid.so.1.1.0
7f640d017000-7f640d019000 r--p 00000000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d019000-7f640d01f000 r-xp 00002000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d01f000-7f640d020000 r--p 00008000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d020000-7f640d021000 ---p 00009000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d021000-7f640d022000 r--p 00009000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d022000-7f640d023000 rw-p 0000a000 00:2f 556960                     /usr/lib64/libffi.so.8.1.0
7f640d023000-7f640d025000 r--p 00000000 00:2f 554222                     /usr/lib64/libpcre.so.1.2.12
7f640d025000-7f640d098000 r-xp 00002000 00:2f 554222                     /usr/lib64/libpcre.so.1.2.12
7f640d098000-7f640d0b9000 r--p 00075000 00:2f 554222                     /usr/lib64/libpcre.so.1.2.12
7f640d0b9000-7f640d0ba000 r--p 00095000 00:2f 554222                     /usr/lib64/libpcre.so.1.2.12
7f640d0ba000-7f640d0bb000 rw-p 00096000 00:2f 554222                     /usr/lib64/libpcre.so.1.2.12
7f640d0bb000-7f640d0bf000 r--p 00000000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0bf000-7f640d0cb000 r-xp 00004000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0cb000-7f640d0ce000 r--p 00010000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0ce000-7f640d0cf000 ---p 00013000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0cf000-7f640d0d0000 r--p 00013000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0d0000-7f640d0d1000 rw-p 00014000 00:2f 544602                     /lib64/libresolv-2.31.so
7f640d0d1000-7f640d0d3000 rw-p 00000000 00:00 0
7f640d0d3000-7f640d0da000 r--p 00000000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0da000-7f640d0f2000 r-xp 00007000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0f2000-7f640d0f9000 r--p 0001f000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0f9000-7f640d0fa000 ---p 00026000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0fa000-7f640d0fb000 r--p 00026000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0fb000-7f640d0fc000 rw-p 00027000 00:2f 556310                     /lib64/libselinux.so.1
7f640d0fc000-7f640d0fe000 rw-p 00000000 00:00 0
7f640d0fe000-7f640d109000 r--p 00000000 00:2f 558042                     /usr/lib64/libmount.so.1.1.0
7f640d109000-7f640d133000 r-xp 0000b000 00:2f 558042                     /usr/lib64/libmount.so.1.1.0
7f640d133000-7f640d13f000 r--p 00035000 00:2f 558042                     /usr/lib64/libmount.so.1.1.0
7f640d13f000-7f640d141000 r--p 00040000 00:2f 558042                     /usr/lib64/libmount.so.1.1.0
7f640d141000-7f640d142000 rw-p 00042000 00:2f 558042                     /usr/lib64/libmount.so.1.1.0
7f640d142000-7f640d143000 r--p 00000000 00:2f 557818                     /usr/lib64/libgmodule-2.0.so.0.6400.2
7f640d143000-7f640d145000 r-xp 00001000 00:2f 557818                     /usr/lib64/libgmodule-2.0.so.0.6400.2
7f640d145000-7f640d146000 r--p 00003000 00:2f 557818                     /usr/lib64/libgmodule-2.0.so.0.6400.2
7f640d146000-7f640d147000 r--p 00003000 00:2f 557818                     /usr/lib64/libgmodule-2.0.so.0.6400.2
7f640d147000-7f640d148000 rw-p 00004000 00:2f 557818                     /usr/lib64/libgmodule-2.0.so.0.6400.2
7f640d148000-7f640d156000 r--p 00000000 00:2f 557972                     /usr/lib64/libgobject-2.0.so.0.6400.2
7f640d156000-7f640d18b000 r-xp 0000e000 00:2f 557972                     /usr/lib64/libgobject-2.0.so.0.6400.2
7f640d18b000-7f640d1a3000 r--p 00043000 00:2f 557972                     /usr/lib64/libgobject-2.0.so.0.6400.2
7f640d1a3000-7f640d1a6000 r--p 0005a000 00:2f 557972                     /usr/lib64/libgobject-2.0.so.0.6400.2
7f640d1a6000-7f640d1a7000 rw-p 0005d000 00:2f 557972                     /usr/lib64/libgobject-2.0.so.0.6400.2
7f640d1a7000-7f640d1c6000 r--p 00000000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d1c6000-7f640d248000 r-xp 0001f000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d248000-7f640d2cd000 r--p 000a1000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d2cd000-7f640d2ce000 ---p 00126000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d2ce000-7f640d2cf000 r--p 00126000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d2cf000-7f640d2d0000 rw-p 00127000 00:2f 556920                     /usr/lib64/libglib-2.0.so.0.6400.2
7f640d2d0000-7f640d2d1000 rw-p 00000000 00:00 0
7f640d2d1000-7f640d30e000 r--p 00000000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d30e000-7f640d418000 r-xp 0003d000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d418000-7f640d4a1000 r--p 00147000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d4a1000-7f640d4a2000 ---p 001d0000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d4a2000-7f640d4a9000 r--p 001d0000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d4a9000-7f640d4ac000 rw-p 001d7000 00:2f 581162                     /usr/lib64/libgio-2.0.so.0.6400.2
7f640d4ac000-7f640d4ad000 rw-p 00000000 00:00 0
7f640d4ad000-7f640d4af000 r--p 00000000 00:2f 512939                     /usr/lib64/libXrandr.so.2.2.0
7f640d4af000-7f640d4b6000 r-xp 00002000 00:2f 512939                     /usr/lib64/libXrandr.so.2.2.0
7f640d4b6000-7f640d4b8000 r--p 00009000 00:2f 512939                     /usr/lib64/libXrandr.so.2.2.0
7f640d4b8000-7f640d4b9000 r--p 0000a000 00:2f 512939                     /usr/lib64/libXrandr.so.2.2.0
7f640d4b9000-7f640d4ba000 rw-p 0000b000 00:2f 512939                     /usr/lib64/libXrandr.so.2.2.0
7f640d4ba000-7f640d566000 r-xp 00000000 00:85 7727                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfreetype.so
7f640d566000-7f640d765000 ---p 000ac000 00:85 7727                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfreetype.so
7f640d765000-7f640d76b000 r--p 000ab000 00:85 7727                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfreetype.so
7f640d76b000-7f640d76c000 rw-p 000b1000 00:85 7727                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfreetype.so
7f640d76c000-7f640d8b6000 r-xp 00000000 00:85 7647                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfontmanager.so
7f640d8b6000-7f640dab6000 ---p 0014a000 00:85 7647                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfontmanager.so
7f640dab6000-7f640dab8000 r--p 0014a000 00:85 7647                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfontmanager.so
7f640dab8000-7f640dab9000 rw-p 0014c000 00:85 7647                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libfontmanager.so
7f640dab9000-7f640dcbd000 rw-p 00000000 00:00 0
7f640dcbd000-7f640dcca000 r--p 00000000 00:2f 512021                     /usr/lib64/libxcb.so.1.1.0
7f640dcca000-7f640dcdd000 r-xp 0000d000 00:2f 512021                     /usr/lib64/libxcb.so.1.1.0
7f640dcdd000-7f640dce6000 r--p 00020000 00:2f 512021                     /usr/lib64/libxcb.so.1.1.0
7f640dce6000-7f640dce7000 r--p 00028000 00:2f 512021                     /usr/lib64/libxcb.so.1.1.0
7f640dce7000-7f640dce8000 rw-p 00029000 00:2f 512021                     /usr/lib64/libxcb.so.1.1.0
7f640dce8000-7f640dceb000 r--p 00000000 00:2f 530866                     /usr/lib64/libXi.so.6.1.0
7f640dceb000-7f640dcf6000 r-xp 00003000 00:2f 530866                     /usr/lib64/libXi.so.6.1.0
7f640dcf6000-7f640dcf9000 r--p 0000e000 00:2f 530866                     /usr/lib64/libXi.so.6.1.0
7f640dcf9000-7f640dcfa000 r--p 00010000 00:2f 530866                     /usr/lib64/libXi.so.6.1.0
7f640dcfa000-7f640dcfb000 rw-p 00011000 00:2f 530866                     /usr/lib64/libXi.so.6.1.0
7f640dcfb000-7f640dcfd000 r--p 00000000 00:2f 530878                     /usr/lib64/libXtst.so.6.1.0
7f640dcfd000-7f640dd00000 r-xp 00002000 00:2f 530878                     /usr/lib64/libXtst.so.6.1.0
7f640dd00000-7f640dd01000 r--p 00005000 00:2f 530878                     /usr/lib64/libXtst.so.6.1.0
7f640dd01000-7f640dd02000 r--p 00005000 00:2f 530878                     /usr/lib64/libXtst.so.6.1.0
7f640dd02000-7f640dd03000 rw-p 00006000 00:2f 530878                     /usr/lib64/libXtst.so.6.1.0
7f640dd03000-7f640dd21000 r--p 00000000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640dd21000-7f640ddac000 r-xp 0001e000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640ddac000-7f640de40000 r--p 000a9000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640de40000-7f640de41000 ---p 0013d000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640de41000-7f640de42000 r--p 0013d000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640de42000-7f640de47000 rw-p 0013e000 00:2f 512309                     /usr/lib64/libX11.so.6.3.0
7f640de47000-7f640de4b000 r--p 00000000 00:2f 512871                     /usr/lib64/libXext.so.6.4.0
7f640de4b000-7f640de56000 r-xp 00004000 00:2f 512871                     /usr/lib64/libXext.so.6.4.0
7f640de56000-7f640de5a000 r--p 0000f000 00:2f 512871                     /usr/lib64/libXext.so.6.4.0
7f640de5a000-7f640de5b000 r--p 00012000 00:2f 512871                     /usr/lib64/libXext.so.6.4.0
7f640de5b000-7f640de5c000 rw-p 00013000 00:2f 512871                     /usr/lib64/libXext.so.6.4.0
7f640de5c000-7f640deb8000 r-xp 00000000 00:85 7599                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt_xawt.so
7f640deb8000-7f640e0b7000 ---p 0005c000 00:85 7599                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt_xawt.so
7f640e0b7000-7f640e0b8000 r--p 0005b000 00:85 7599                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt_xawt.so
7f640e0b8000-7f640e0bb000 rw-p 0005c000 00:85 7599                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt_xawt.so
7f640e0bb000-7f640e0bd000 rw-p 00000000 00:00 0
7f640e0bd000-7f640e15e000 r-xp 00000000 00:85 7511                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt.so
7f640e15e000-7f640e35d000 ---p 000a1000 00:85 7511                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt.so
7f640e35d000-7f640e35e000 r--p 000a0000 00:85 7511                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt.so
7f640e35e000-7f640e369000 rw-p 000a1000 00:85 7511                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libawt.so
7f640e369000-7f640e58e000 rw-p 00000000 00:00 0
7f640e58e000-7f640e592000 ---p 00000000 00:00 0
7f640e592000-7f640e68f000 rw-p 00000000 00:00 0
7f640e68f000-7f640e69c000 r-xp 00000000 00:85 182517987                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libverify.so
7f640e69c000-7f640e89b000 ---p 0000d000 00:85 182517987                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libverify.so
7f640e89b000-7f640e89d000 r--p 0000c000 00:85 182517987                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libverify.so
7f640e89d000-7f640e89e000 rw-p 0000e000 00:85 182517987                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libverify.so
7f640e89e000-7f640e8cf000 rw-p 00000000 00:00 0
7f640e8cf000-7f640e8e4000 r-xp 00000000 00:85 182517771                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnet.so
7f640e8e4000-7f640eae3000 ---p 00015000 00:85 182517771                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnet.so
7f640eae3000-7f640eae4000 r--p 00014000 00:85 182517771                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnet.so
7f640eae4000-7f640eae5000 rw-p 00015000 00:85 182517771                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnet.so
7f640eae5000-7f640eaf7000 r-xp 00000000 00:85 182517803                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnio.so
7f640eaf7000-7f640ecf6000 ---p 00012000 00:85 182517803                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnio.so
7f640ecf6000-7f640ecf7000 r--p 00011000 00:85 182517803                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnio.so
7f640ecf7000-7f640ecf8000 rw-p 00012000 00:85 182517803                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libnio.so
7f640ecf8000-7f640ecfc000 ---p 00000000 00:00 0
7f640ecfc000-7f640eef9000 rw-p 00000000 00:00 0
7f640eef9000-7f640eefa000 ---p 00000000 00:00 0
7f640eefa000-7f640effb000 rw-p 00000000 00:00 0
7f640effb000-7f640efff000 ---p 00000000 00:00 0
7f640efff000-7f640f1fc000 rw-p 00000000 00:00 0
7f640f1fc000-7f640f200000 ---p 00000000 00:00 0
7f640f200000-7f640f3fd000 rw-p 00000000 00:00 0
7f640f3fd000-7f640f401000 ---p 00000000 00:00 0
7f640f401000-7f640f4fe000 rw-p 00000000 00:00 0
7f640f4fe000-7f640f502000 ---p 00000000 00:00 0
7f640f502000-7f640f5ff000 rw-p 00000000 00:00 0
7f640f5ff000-7f640f603000 ---p 00000000 00:00 0
7f640f603000-7f6410000000 rw-p 00000000 00:00 0
7f6410000000-7f6410021000 rw-p 00000000 00:00 0
7f6410021000-7f6414000000 ---p 00000000 00:00 0
7f6414000000-7f6414021000 rw-p 00000000 00:00 0
7f6414021000-7f6418000000 ---p 00000000 00:00 0
7f6418000000-7f6418021000 rw-p 00000000 00:00 0
7f6418021000-7f641c000000 ---p 00000000 00:00 0
7f641c000000-7f641c021000 rw-p 00000000 00:00 0
7f641c021000-7f6420000000 ---p 00000000 00:00 0
7f6420000000-7f6420021000 rw-p 00000000 00:00 0
7f6420021000-7f6424000000 ---p 00000000 00:00 0
7f6424000000-7f6424001000 r--p 00000000 00:2f 530860                     /usr/lib64/libXdamage.so.1.1.0
7f6424001000-7f6424002000 r-xp 00001000 00:2f 530860                     /usr/lib64/libXdamage.so.1.1.0
7f6424002000-7f6424003000 r--p 00002000 00:2f 530860                     /usr/lib64/libXdamage.so.1.1.0
7f6424003000-7f6424004000 r--p 00002000 00:2f 530860                     /usr/lib64/libXdamage.so.1.1.0
7f6424004000-7f6424005000 rw-p 00003000 00:2f 530860                     /usr/lib64/libXdamage.so.1.1.0
7f6424005000-7f6424009000 ---p 00000000 00:00 0
7f6424009000-7f6424206000 rw-p 00000000 00:00 0
7f6424206000-7f642420a000 ---p 00000000 00:00 0
7f642420a000-7f6424407000 rw-p 00000000 00:00 0
7f6424407000-7f642440b000 ---p 00000000 00:00 0
7f642440b000-7f6424608000 rw-p 00000000 00:00 0
7f6424608000-7f6424609000 ---p 00000000 00:00 0
7f6424609000-7f64247e6000 rw-p 00000000 00:00 0
7f64247e6000-7f64247e7000 ---p 00000000 00:00 0
7f64247e7000-7f64248e8000 rw-p 00000000 00:00 0
7f64248e8000-7f64248e9000 ---p 00000000 00:00 0
7f64248e9000-7f64273f4000 rw-p 00000000 00:00 0
7f64273f4000-7f64273f5000 ---p 00000000 00:00 0
7f64273f5000-7f64274f6000 rw-p 00000000 00:00 0
7f64274f6000-7f64274f7000 ---p 00000000 00:00 0
7f64274f7000-7f64275f8000 rw-p 00000000 00:00 0
7f64275f8000-7f64275f9000 ---p 00000000 00:00 0
7f64275f9000-7f6427832000 rw-p 00000000 00:00 0
7f6427832000-7f6427e92000 ---p 00000000 00:00 0
7f6427e92000-7f6427e96000 rw-p 00000000 00:00 0
7f6427e96000-7f6427ece000 ---p 00000000 00:00 0
7f6427ece000-7f6427ed2000 rw-p 00000000 00:00 0
7f6427ed2000-7f6427efa000 ---p 00000000 00:00 0
7f6427efa000-7f6428032000 rw-p 00000000 00:00 0
7f6428032000-7f6428692000 ---p 00000000 00:00 0
7f6428692000-7f6428696000 rw-p 00000000 00:00 0
7f6428696000-7f64286ce000 ---p 00000000 00:00 0
7f64286ce000-7f64286d2000 rw-p 00000000 00:00 0
7f64286d2000-7f64286fa000 ---p 00000000 00:00 0
7f64286fa000-7f6428721000 rw-p 00000000 00:00 0
7f6428721000-7f64287ed000 ---p 00000000 00:00 0
7f64287ed000-7f64287ee000 rw-p 00000000 00:00 0
7f64287ee000-7f64287f4000 ---p 00000000 00:00 0
7f64287f4000-7f64287f5000 rw-p 00000000 00:00 0
7f64287f5000-7f64287fa000 ---p 00000000 00:00 0
7f64287fa000-7f6428821000 rw-p 00000000 00:00 0
7f6428821000-7f64288ed000 ---p 00000000 00:00 0
7f64288ed000-7f64288ee000 rw-p 00000000 00:00 0
7f64288ee000-7f64288f4000 ---p 00000000 00:00 0
7f64288f4000-7f64288f5000 rw-p 00000000 00:00 0
7f64288f5000-7f64288fa000 ---p 00000000 00:00 0
7f64288fa000-7f6428921000 rw-p 00000000 00:00 0
7f6428921000-7f64289ed000 ---p 00000000 00:00 0
7f64289ed000-7f64289ee000 rw-p 00000000 00:00 0
7f64289ee000-7f64289f4000 ---p 00000000 00:00 0
7f64289f4000-7f64289f5000 rw-p 00000000 00:00 0
7f64289f5000-7f64289fa000 ---p 00000000 00:00 0
7f64289fa000-7f6429000000 rw-p 00000000 00:00 0
7f6429000000-7f6429270000 rwxp 00000000 00:00 0
7f6429270000-7f6429592000 ---p 00000000 00:00 0
7f6429592000-7f642a0b2000 rwxp 00000000 00:00 0
7f642a0b2000-7f6430ac9000 ---p 00000000 00:00 0
7f6430ac9000-7f6430d49000 rwxp 00000000 00:00 0
7f6430d49000-7f6438000000 ---p 00000000 00:00 0
7f6438000000-7f6438d44000 rw-p 00000000 00:00 0
7f6438d44000-7f643c000000 ---p 00000000 00:00 0
7f643c000000-7f643c001000 r--p 00000000 00:2f 530857                     /usr/lib64/libXcomposite.so.1.0.0
7f643c001000-7f643c002000 r-xp 00001000 00:2f 530857                     /usr/lib64/libXcomposite.so.1.0.0
7f643c002000-7f643c003000 r--p 00002000 00:2f 530857                     /usr/lib64/libXcomposite.so.1.0.0
7f643c003000-7f643c004000 r--p 00002000 00:2f 530857                     /usr/lib64/libXcomposite.so.1.0.0
7f643c004000-7f643c005000 rw-p 00003000 00:2f 530857                     /usr/lib64/libXcomposite.so.1.0.0
7f643c005000-7f643c007000 r--p 00000000 00:2f 512865                     /usr/lib64/libXrender.so.1.3.0
7f643c007000-7f643c00e000 r-xp 00002000 00:2f 512865                     /usr/lib64/libXrender.so.1.3.0
7f643c00e000-7f643c010000 r--p 00009000 00:2f 512865                     /usr/lib64/libXrender.so.1.3.0
7f643c010000-7f643c011000 r--p 0000a000 00:2f 512865                     /usr/lib64/libXrender.so.1.3.0
7f643c011000-7f643c012000 rw-p 0000b000 00:2f 512865                     /usr/lib64/libXrender.so.1.3.0
7f643c012000-7f643c014000 r--p 00000000 00:2f 512868                     /usr/lib64/libXfixes.so.3.1.0
7f643c014000-7f643c017000 r-xp 00002000 00:2f 512868                     /usr/lib64/libXfixes.so.3.1.0
7f643c017000-7f643c018000 r--p 00005000 00:2f 512868                     /usr/lib64/libXfixes.so.3.1.0
7f643c018000-7f643c019000 r--p 00005000 00:2f 512868                     /usr/lib64/libXfixes.so.3.1.0
7f643c019000-7f643c01a000 rw-p 00006000 00:2f 512868                     /usr/lib64/libXfixes.so.3.1.0
7f643c01a000-7f643c01d000 r--p 00000000 08:05 151483134                  /home/hornet/.config/dconf/user
7f643c01d000-7f643c021000 r--p 00000000 00:2f 585561                     /usr/lib64/gio/modules/libdconfsettings.so
7f643c021000-7f643c026000 r-xp 00004000 00:2f 585561                     /usr/lib64/gio/modules/libdconfsettings.so
7f643c026000-7f643c029000 r--p 00009000 00:2f 585561                     /usr/lib64/gio/modules/libdconfsettings.so
7f643c029000-7f643c02a000 r--p 0000b000 00:2f 585561                     /usr/lib64/gio/modules/libdconfsettings.so
7f643c02a000-7f643c02b000 rw-p 0000c000 00:2f 585561                     /usr/lib64/gio/modules/libdconfsettings.so
7f643c02b000-7f643c4d9000 rw-p 00000000 00:00 0
7f643c4d9000-7f643c5bf000 ---p 00000000 00:00 0
7f643c5bf000-7f643c5d6000 rw-p 00000000 00:00 0
7f643c5d6000-7f643c6aa000 ---p 00000000 00:00 0
7f643c6aa000-7f643e7e6000 r--s 00000000 00:85 182518051                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/modules
7f643e7e6000-7f643e7ed000 r-xp 00000000 00:85 182518019                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libzip.so
7f643e7ed000-7f643e9ec000 ---p 00007000 00:85 182518019                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libzip.so
7f643e9ec000-7f643e9ed000 r--p 00006000 00:85 182518019                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libzip.so
7f643e9ed000-7f643e9ee000 rw-p 00007000 00:85 182518019                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libzip.so
7f643e9ee000-7f643ea13000 r-xp 00000000 00:85 7819                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjava.so
7f643ea13000-7f643ec12000 ---p 00025000 00:85 7819                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjava.so
7f643ec12000-7f643ec13000 r--p 00024000 00:85 7819                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjava.so
7f643ec13000-7f643ec15000 rw-p 00025000 00:85 7819                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjava.so
7f643ec15000-7f643ec4a000 r--s 00000000 00:44 12978                      /var/lib/nscd/passwd
7f643ec4a000-7f643ec65000 r-xp 00000000 00:85 7931                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjimage.so
7f643ec65000-7f643ee64000 ---p 0001b000 00:85 7931                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjimage.so
7f643ee64000-7f643ee66000 r--p 0001a000 00:85 7931                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjimage.so
7f643ee66000-7f643ee67000 rw-p 0001c000 00:85 7931                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjimage.so
7f643ee67000-7f643ee6a000 r--p 00000000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee6a000-7f643ee6e000 r-xp 00003000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee6e000-7f643ee6f000 r--p 00007000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee6f000-7f643ee70000 ---p 00008000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee70000-7f643ee71000 r--p 00008000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee71000-7f643ee72000 rw-p 00009000 00:2f 544604                     /lib64/librt-2.31.so
7f643ee72000-7f643ee76000 ---p 00000000 00:00 0
7f643ee76000-7f643f073000 rw-p 00000000 00:00 0
7f643f073000-7f64402b8000 r-xp 00000000 00:85 182519419                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/server/libjvm.so
7f64402b8000-7f64404b8000 ---p 01245000 00:85 182519419                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/server/libjvm.so
7f64404b8000-7f6440560000 r--p 01245000 00:85 182519419                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/server/libjvm.so
7f6440560000-7f644059a000 rw-p 012ed000 00:85 182519419                  /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/server/libjvm.so
7f644059a000-7f644061b000 rw-p 00000000 00:00 0
7f644061b000-7f644061e000 r--p 00000000 00:2f 556479                     /lib64/libz.so.1.2.11
7f644061e000-7f644062c000 r-xp 00003000 00:2f 556479                     /lib64/libz.so.1.2.11
7f644062c000-7f6440632000 r--p 00011000 00:2f 556479                     /lib64/libz.so.1.2.11
7f6440632000-7f6440633000 ---p 00017000 00:2f 556479                     /lib64/libz.so.1.2.11
7f6440633000-7f6440634000 r--p 00017000 00:2f 556479                     /lib64/libz.so.1.2.11
7f6440634000-7f6440635000 rw-p 00018000 00:2f 556479                     /lib64/libz.so.1.2.11
7f6440635000-7f6440644000 r-xp 00000000 00:85 7971                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjli.so
7f6440644000-7f6440843000 ---p 0000f000 00:85 7971                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjli.so
7f6440843000-7f6440844000 r--p 0000e000 00:85 7971                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjli.so
7f6440844000-7f6440845000 rw-p 0000f000 00:85 7971                       /tmp/.mount_cryptowE2Ty5/lib/runtime/lib/libjli.so
7f6440845000-7f644084c000 r--p 00000000 00:2f 544600                     /lib64/libpthread-2.31.so
7f644084c000-7f644085c000 r-xp 00007000 00:2f 544600                     /lib64/libpthread-2.31.so
7f644085c000-7f6440861000 r--p 00017000 00:2f 544600                     /lib64/libpthread-2.31.so
7f6440861000-7f6440862000 r--p 0001b000 00:2f 544600                     /lib64/libpthread-2.31.so
7f6440862000-7f6440863000 rw-p 0001c000 00:2f 544600                     /lib64/libpthread-2.31.so
7f6440863000-7f6440867000 rw-p 00000000 00:00 0
7f6440867000-7f6440868000 r--p 00000000 00:2f 530869                     /usr/lib64/libXinerama.so.1.0.0
7f6440868000-7f6440869000 r-xp 00001000 00:2f 530869                     /usr/lib64/libXinerama.so.1.0.0
7f6440869000-7f644086a000 r--p 00002000 00:2f 530869                     /usr/lib64/libXinerama.so.1.0.0
7f644086a000-7f644086b000 r--p 00002000 00:2f 530869                     /usr/lib64/libXinerama.so.1.0.0
7f644086b000-7f644086c000 rw-p 00003000 00:2f 530869                     /usr/lib64/libXinerama.so.1.0.0
7f644086c000-7f6440871000 rw-p 00000000 00:00 0
7f6440871000-7f6440878000 ---p 00000000 00:00 0
7f6440878000-7f6440880000 rw-s 00000000 00:3c 41356                      /tmp/hsperfdata_hornet/23578
7f6440880000-7f644099c000 r-xp 00000000 00:85 3779                       /tmp/.mount_cryptowE2Ty5/lib/libapplauncher.so
7f644099c000-7f6440b9b000 ---p 0011c000 00:85 3779                       /tmp/.mount_cryptowE2Ty5/lib/libapplauncher.so
7f6440b9b000-7f6440ba4000 r--p 0011b000 00:85 3779                       /tmp/.mount_cryptowE2Ty5/lib/libapplauncher.so
7f6440ba4000-7f6440ba5000 rw-p 00124000 00:85 3779                       /tmp/.mount_cryptowE2Ty5/lib/libapplauncher.so
7f6440ba5000-7f6440ba8000 rw-p 00000000 00:00 0
7f6440ba8000-7f6440bfc000 r--p 00000000 00:2f 469971                     /usr/lib/locale/en_US.utf8/LC_CTYPE
7f6440bfc000-7f6440e74000 r--p 00000000 00:2f 469706                     /usr/lib/locale/en_US.utf8/LC_COLLATE
7f6440e74000-7f6440e77000 rw-p 00000000 00:00 0
7f6440e77000-7f6440e9c000 r--p 00000000 00:2f 544580                     /lib64/libc-2.31.so
7f6440e9c000-7f6440fe8000 r-xp 00025000 00:2f 544580                     /lib64/libc-2.31.so
7f6440fe8000-7f6441033000 r--p 00171000 00:2f 544580                     /lib64/libc-2.31.so
7f6441033000-7f6441036000 r--p 001bb000 00:2f 544580                     /lib64/libc-2.31.so
7f6441036000-7f6441039000 rw-p 001be000 00:2f 544580                     /lib64/libc-2.31.so
7f6441039000-7f644103d000 rw-p 00000000 00:00 0
7f644103d000-7f644104c000 r--p 00000000 00:2f 544584                     /lib64/libm-2.31.so
7f644104c000-7f64410e8000 r-xp 0000f000 00:2f 544584                     /lib64/libm-2.31.so
7f64410e8000-7f6441181000 r--p 000ab000 00:2f 544584                     /lib64/libm-2.31.so
7f6441181000-7f6441182000 r--p 00143000 00:2f 544584                     /lib64/libm-2.31.so
7f6441182000-7f6441183000 rw-p 00144000 00:2f 544584                     /lib64/libm-2.31.so
7f6441183000-7f6441184000 r--p 00000000 00:2f 544582                     /lib64/libdl-2.31.so
7f6441184000-7f6441185000 r-xp 00001000 00:2f 544582                     /lib64/libdl-2.31.so
7f6441185000-7f6441186000 r--p 00002000 00:2f 544582                     /lib64/libdl-2.31.so
7f6441186000-7f6441187000 r--p 00002000 00:2f 544582                     /lib64/libdl-2.31.so
7f6441187000-7f6441188000 rw-p 00003000 00:2f 544582                     /lib64/libdl-2.31.so
7f6441188000-7f644118a000 rw-p 00000000 00:00 0
7f644118a000-7f644118b000 r--s 00000000 00:5f 100815                     /run/user/1000/dconf/user
7f644118b000-7f644118c000 r--p 00000000 00:2f 511747                     /usr/lib64/libXau.so.6.0.0
7f644118c000-7f644118d000 r-xp 00001000 00:2f 511747                     /usr/lib64/libXau.so.6.0.0
7f644118d000-7f644118e000 r--p 00002000 00:2f 511747                     /usr/lib64/libXau.so.6.0.0
7f644118e000-7f644118f000 r--p 00002000 00:2f 511747                     /usr/lib64/libXau.so.6.0.0
7f644118f000-7f6441190000 rw-p 00003000 00:2f 511747                     /usr/lib64/libXau.so.6.0.0
7f6441190000-7f6441191000 ---p 00000000 00:00 0
7f6441191000-7f6441192000 r--p 00000000 00:00 0
7f6441192000-7f6441193000 ---p 00000000 00:00 0
7f6441193000-7f6441194000 r--p 00000000 00:2f 469712                     /usr/lib/locale/en_US.utf8/LC_NUMERIC
7f6441194000-7f6441195000 r--p 00000000 00:2f 469715                     /usr/lib/locale/en_US.utf8/LC_TIME
7f6441195000-7f6441196000 r--p 00000000 00:2f 469710                     /usr/lib/locale/en_US.utf8/LC_MONETARY
7f6441196000-7f6441197000 r--p 00000000 00:2f 469709                     /usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
7f6441197000-7f6441198000 r--p 00000000 00:2f 469713                     /usr/lib/locale/en_US.utf8/LC_PAPER
7f6441198000-7f6441199000 r--p 00000000 00:2f 469711                     /usr/lib/locale/en_US.utf8/LC_NAME
7f6441199000-7f644119a000 r--p 00000000 00:2f 469705                     /usr/lib/locale/en_US.utf8/LC_ADDRESS
7f644119a000-7f644119b000 r--p 00000000 00:2f 469714                     /usr/lib/locale/en_US.utf8/LC_TELEPHONE
7f644119b000-7f644119c000 r--p 00000000 00:2f 469708                     /usr/lib/locale/en_US.utf8/LC_MEASUREMENT
7f644119c000-7f64411a3000 r--s 00000000 00:2f 571073                     /usr/lib64/gconv/gconv-modules.cache
7f64411a3000-7f64411a4000 r--p 00000000 00:2f 544572                     /lib64/ld-2.31.so
7f64411a4000-7f64411c4000 r-xp 00001000 00:2f 544572                     /lib64/ld-2.31.so
7f64411c4000-7f64411cc000 r--p 00021000 00:2f 544572                     /lib64/ld-2.31.so
7f64411cc000-7f64411cd000 r--p 00000000 00:2f 469707                     /usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
7f64411cd000-7f64411ce000 r--p 00029000 00:2f 544572                     /lib64/ld-2.31.so
7f64411ce000-7f64411cf000 rw-p 0002a000 00:2f 544572                     /lib64/ld-2.31.so
7f64411cf000-7f64411d0000 rw-p 00000000 00:00 0
7ffc088ff000-7ffc08920000 rw-p 00000000 00:00 0                          [stack]
7ffc089cd000-7ffc089d1000 r--p 00000000 00:00 0                          [vvar]
7ffc089d1000-7ffc089d3000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0                  [vsyscall]
VM Arguments:
jvm_args: -Djava.library.path=/tmp/.mount_cryptowE2Ty5/lib/app:/tmp/.mount_cryptowE2Ty5/bin -Djava.launcher.path=/tmp/.mount_cryptowE2Ty5/bin -Dcryptomator.logDir=~/.local/share/Cryptomator/logs -Dcryptomator.settingsPath=~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json -Dcryptomator.ipcPortPath=~/.config/Cryptomator/ipcPort.bin:~/.Cryptomator/ipcPort.bin -Dcryptomator.mountPointsDir=~/.local/share/Cryptomator/mnt -Dcryptomator.buildNumber=appimage-1 -Xss2m -Xmx512m
java_command: org.cryptomator.launcher.Cryptomator
java_class_path (initial): /tmp/.mount_cryptowE2Ty5/lib/app/launcher-1.5.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/dbus-java-3.0.2.jar:/tmp/.mount_cryptowE2Ty5/lib/app/fuse-nio-adapter-1.2.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jetty-util-9.4.28.v20200408.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jetty-xml-9.4.28.v20200408.jar:/tmp/.mount_cryptowE2Ty5/lib/app/cryptofs-1.9.10.jar:/tmp/.mount_cryptowE2Ty5/lib/app/j2objc-annotations-1.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jsr305-3.0.2.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jetty-io-9.4.28.v20200408.jar:/tmp/.mount_cryptowE2Ty5/lib/app/easybind-1.0.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/secret-service-1.0.0-RC.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jetty-webapp-9.4.28.v20200408.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jnr-ffi-2.1.12.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jackson-databind-2.10.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jnr-a64asm-1.0.0.jar:/tmp/.mount_cryptowE2Ty5/lib/app/javax.inject-1.jar:/tmp/.mount_cryptowE2Ty5/lib/app/ui-1.5.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/hkdf-1.0.2.jar:/tmp/.mount_cryptowE2Ty5/lib/app/gson-2.8.6.jar:/tmp/.mount_cryptowE2Ty5/lib/app/keychain-1.5.3.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jnr-posix-3.0.54.jar:/tmp/.mount_cryptowE2Ty5/lib/app/asm-analysis-7.1.jar:/tmp/.mount_cryptowE2Ty5/lib/app/asm-7.1.jar:/tmp/.mount_cryptowE2Ty5/lib/app/javafx-controls-14.jar:/tmp/.mount_cryptowE2Ty5/lib/app/webdav-nio-adapter-1.0.11.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jnr-x86asm-1.0.2.jar:/tmp/.mount_cryptowE2Ty5/lib/app/guava-28.2-jre.jar:/tmp/.mount_cryptowE2Ty5/lib/app/cryptolib-1.3.2.jar:/tmp/.mount_cryptowE2Ty5/lib/app/javafx-fxml-14-linux.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jna-platform-5.1.0.jar:/tmp/.mount_cryptowE2Ty5/lib/app/jackrabbit-webdav-2.21.0.jar:/tmp/.mount_cryptowE2Ty5/lib/app/dagger-2.27.jar:/tmp/.mount_cryptowE2Ty5/lib/app/javafx-base-14.jar:/tmp/.mount_cryptowE2Ty5/lib/app/asm-commons-7.1.jar:/tmp/.mount_cryptowE2Ty5/lib/app/commons-io-2.6.jar:/tmp/.mount_cryptowE2Ty5/lib/app/error_pron
Launcher Type: SUN_STANDARD
[Global flags]
     intx CICompilerCount                          = 4                                         {product} {ergonomic}
     uint ConcGCThreads                            = 3                                         {product} {ergonomic}
     uint G1ConcRefinementThreads                  = 10                                        {product} {ergonomic}
   size_t G1HeapRegionSize                         = 1048576                                   {product} {ergonomic}
    uintx GCDrainStackTargetSize                   = 64                                        {product} {ergonomic}
   size_t InitialHeapSize                          = 526385152                                 {product} {ergonomic}
   size_t MarkStackSize                            = 4194304                                   {product} {ergonomic}
   size_t MaxHeapSize                              = 536870912                                 {product} {command line}
   size_t MaxNewSize                               = 321912832                                 {product} {ergonomic}
   size_t MinHeapDeltaBytes                        = 1048576                                   {product} {ergonomic}
   size_t MinHeapSize                              = 8388608                                   {product} {ergonomic}
    uintx NonNMethodCodeHeapSize                   = 5839372                                {pd product} {ergonomic}
    uintx NonProfiledCodeHeapSize                  = 122909434                              {pd product} {ergonomic}
    uintx ProfiledCodeHeapSize                     = 122909434                              {pd product} {ergonomic}
    uintx ReservedCodeCacheSize                    = 251658240                              {pd product} {ergonomic}
     bool SegmentedCodeCache                       = true                                      {product} {ergonomic}
   size_t SoftMaxHeapSize                          = 536870912                              {manageable} {ergonomic}
     intx ThreadStackSize                          = 2048                                   {pd product} {command line}
     bool UseCompressedClassPointers               = true                                 {lp64_product} {ergonomic}
     bool UseCompressedOops                        = true                                 {lp64_product} {ergonomic}
     bool UseG1GC                                  = true                                      {product} {ergonomic}
Logging:
Log output configuration:
 #0: stdout all=warning uptime,level,tags
 #1: stderr all=off uptime,level,tags
Environment Variables:
JAVA_HOME=/usr/lib64/jvm/jre-openjdk
JRE_HOME=/usr/lib64/jvm/java-11-openjdk-11
PATH=/home/hornet/bin:/usr/local/bin:/usr/bin:/bin
USERNAME=hornet
SHELL=/bin/bash
DISPLAY=:0
HOSTTYPE=x86_64
OSTYPE=linux
MACHTYPE=x86_64-suse-linux
Signal Handlers:
SIGSEGV: [libjvm.so+0xf1af70], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGBUS: [libjvm.so+0xf1af70], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGFPE: [libjvm.so+0xf1af70], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGPIPE: SIG_IGN, sa_mask[0]=00000000000010000000000000000000, sa_flags=SA_RESTART
SIGXFSZ: [libjvm.so+0xbbdbc0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGILL: [libjvm.so+0xf1af70], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGUSR2: [libjvm.so+0xbbda60], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
SIGHUP: [libjvm.so+0xbbe060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGINT: [libjvm.so+0xbbe060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGTERM: [libjvm.so+0xbbe060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGQUIT: [libjvm.so+0xbbe060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
---------------  S Y S T E M  ---------------
OS:NAME="openSUSE Tumbleweed"
# VERSION="20200502"
ID="opensuse-tumbleweed"
ID_LIKE="opensuse suse"
VERSION_ID="20200502"
PRETTY_NAME="openSUSE Tumbleweed"
ANSI_COLOR="0;32"
CPE_NAME="cpe:/o:opensuse:tumbleweed:20200502"
BUG_REPORT_URL="https://bugs.opensuse.org"
HOME_URL="https://www.opensuse.org/"
LOGO="distributor-logo"
uname:Linux 5.6.8-1-default #1 SMP Thu Apr 30 10:47:01 UTC 2020 (63116ab) x86_64
OS uptime: 0 days 1:27 hours
libc:glibc 2.31 NPTL 2.31
rlimit: STACK 8192k, CORE infinity, NPROC 128089, NOFILE 524288, AS infinity, DATA infinity, FSIZE infinity
load average:3.10 2.76 1.98
/proc/meminfo:
MemTotal:       32821212 kB
MemFree:         9542708 kB
MemAvailable:   22033088 kB
Buffers:         2478812 kB
Cached:         10943056 kB
SwapCached:            0 kB
Active:          5505548 kB
Inactive:       11509600 kB
Active(anon):    3596520 kB
Inactive(anon):   732584 kB
Active(file):    1909028 kB
Inactive(file): 10777016 kB
Unevictable:          48 kB
Mlocked:              48 kB
SwapTotal:      33554428 kB
SwapFree:       33554428 kB
Dirty:              1064 kB
Writeback:           528 kB
AnonPages:       3423732 kB
Mapped:          6463840 kB
Shmem:            736244 kB
KReclaimable:     268288 kB
Slab:             583324 kB
SReclaimable:     268288 kB
SUnreclaim:       315036 kB
KernelStack:       26448 kB
PageTables:        59036 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    49965032 kB
Committed_AS:   20952860 kB
VmallocTotal:   34359738367 kB
VmallocUsed:       53492 kB
VmallocChunk:          0 kB
Percpu:            24448 kB
HardwareCorrupted:     0 kB
AnonHugePages:   1093632 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
FileHugePages:         0 kB
FilePmdMapped:         0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
DirectMap4k:     1054028 kB
DirectMap2M:    18819072 kB
DirectMap1G:    14680064 kB
/proc/sys/kernel/threads-max (system-wide limit on the number of threads):
256179
/proc/sys/vm/max_map_count (maximum number of memory map areas a process may have):
65530
/proc/sys/kernel/pid_max (system-wide limit on number of process identifiers):
32768
container (cgroup) information:
container_type: cgroupv1
cpu_cpuset_cpus: 0-11
cpu_memory_nodes: 0
active_processor_count: 12
cpu_quota: no quota
cpu_period: 100000
cpu_shares: no shares
memory_limit_in_bytes: unlimited
memory_and_swap_limit_in_bytes: not supported
memory_soft_limit_in_bytes: unlimited
memory_usage_in_bytes: 16204308480
memory_max_usage_in_bytes: 16226725888
Steal ticks since vm start: 0
Steal ticks percentage since vm start:  0.000
CPU:total 12 (initial active 12) (12 cores per cpu, 2 threads per core) family 23 model 8 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, mmxext, 3dnowpref, lzcnt, sse4a, ht, tsc, tscinvbit, tscinv, bmi1, bmi2, adx, sha, fma
CPU Model and flags from /proc/cpuinfo:
model name	: AMD Ryzen 5 2600 Six-Core Processor
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca
Memory: 4k page, physical 32821212k(9542708k free), swap 33554428k(33554428k free)
vm_info: OpenJDK 64-Bit Server VM (14.0.1+8) for linux-amd64 JRE (14.0.1+8) (Zulu14.28+21-CA), built on Apr  3 2020 14:34:19 by "zulu_re" with gcc 7.3.1 20180303 (Red Hat 7.3.1-5)
END.
When you switch the volume type to WebDAV in the general settings, virtual drive tab , does this crash still occur?
And do you store your password in the system?
I do not store my password. Switching to WebDAV however, does allow me to mount the volume. So I guess it is some problem with fuse.
© 2020 Skymatic GmbH • Privacy PolicyImpressum
