I created a brand new vault (600GB) and I must check the integrity of the new vault before storing away.
I tried to run sanitizer v0.16 and received the following error (which I expected since 1.5.5 is Vault 7):
Check failed: Vault version mismatch. Expected: 6 Actual: 7
Is there a new integrity-check tool I can use with the new vault?
Also, do you recommend FreeFileSync? I’ve had great success with this program.
But you don’t need the integrity check, if you have created and stored the vault locally. Most of the problems are due to incomplete sync.
A partial check of the vault on another system can be done be comparing the existence and size of encrypted files and the general vault structure. But you won’t find broken directory or symlinks or broken shorten file names.
