Hello, I choose WebDAV, type https://webdav.yandex.com and put my correct username with password. I constantly gen the same error: “WebDAV could not be authentificated”. What should I do to fix this?
UPD: It’s solved. I enabled 2fa and created app pasword for cryptomator. Now it works.
Maybe you have enabled two-factor authentication? Often then the WebDAV login is blocked using your normal user password, then you need to setup an app password and use this one in the Cryptomator App.
