Fisrt of all, your app rocks.
Yesterday I was in the need to print an email from my email client app, so in the printing utility from Android there is an option to print as pdf. So I was trying to save the file into my vault. But there isn’t a path to my vault from the printing utility.
You may say I can use the sharing option from my email client. But it sends a text file with an url where you can read the message in a web browser. So the sharing option is not an option! But anyway I think it should happen the same thing if you want to save your work directly to your vault from a text editor for example.
In desktop platforms, the vaults are mounted on virtual drives, so you can use any application to save your work directly to your vault.
In short, ¿Is there an option to save your work from apps to your vault in Android?
Thx in advanced.
