Vault does not lock on iMac; hangs system completely and requires restart
Working on an iMac with Monterey 12.2.1 and latest version of Cryptomator (1.6.15); volume type: WebDAV. No applications are calling on any files in the vault. Dropbox is not syncing. I try to lock the vault. Then everything hangs. No option to lock gracefully and no possibility of force quitting Cryptomator. Everything completely hangs: I cannot even Force Quit anything. I have to manually restart my computer. Any advice? Thanks.
(Also, if the vault is unlocked upon putting system to sleep then after the system wakes up, if I click on anything in the vault the same behavior as above: the system completely freezes to the point that a forced restart is required.)
Update: Updated to 1.6.16. And installed MacFuse. Makes no difference at all.
Some logs in case it’s helpful:
16:05:53.447 [main] INFO  o.c.common.settings.SettingsProvider - Settings loaded from /Users/ag/Library/Application Support/Cryptomator/settings.json
16:05:53.465 [main] INFO  org.cryptomator.common.Environment - user.home: /Users/ag
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - java.library.path: :/Applications/Cryptomator.app/Contents/app:/Users/ag/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - user.language: en
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - user.region: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - logback.configurationFile: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.settingsPath: ~/Library/Application Support/Cryptomator/settings.json
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/Library/Application Support/Cryptomator/ipc.socket
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.logDir: ~/Library/Logs/Cryptomator
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.loopbackAlias: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.pluginDir: ~/Library/Application Support/Cryptomator/Plugins
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.mountPointsDir: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.minPwLength: null
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.16
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.buildNumber: dmg-4100
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.showTrayIcon: true
16:05:53.467 [main] INFO  org.cryptomator.common.Environment - cryptomator.p12Path: ~/Library/Application Support/Cryptomator/key.p12
16:05:53.467 [main] INFO  o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.16 on Mac OS X 12.2.1 (aarch64)
16:05:53.467 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
16:05:53.468 [main] DEBUG o.c.launcher.SupportedLanguages - Using system locale
16:05:53.502 [main] INFO  org.cryptomator.ipc.Server - Spawning IPC server listening on socket /Users/ag/Library/Application Support/Cryptomator/ipc.socket
16:05:56.248 [main] DEBUG o.c.launcher.IpcMessageHandler - Received launch args:
16:05:56.252 [main] DEBUG o.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI...
16:05:56.648 [JavaFX Application Thread] INFO  o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 3615ms
16:05:56.652 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
16:05:56.654 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayIntegrationProvider: Found implementation: org.cryptomator.macos.tray.MacTrayIntegrationProvider in jar /Applications/Cryptomator.app/Contents/app/mods/integrations-mac-1.1.2.jar
16:05:56.663 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayIntegrationProvider: Implementation is available: org.cryptomator.macos.tray.MacTrayIntegrationProvider
16:05:56.835 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 01
16:05:56.836 [App Scheduled Executor 01] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 02
16:05:56.837 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
16:05:56.838 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - UiAppearanceProvider: Found implementation: org.cryptomator.macos.uiappearance.MacUiAppearanceProvider in jar /Applications/Cryptomator.app/Contents/app/mods/integrations-mac-1.1.2.jar
16:05:56.839 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - UiAppearanceProvider: Implementation is available: org.cryptomator.macos.uiappearance.MacUiAppearanceProvider
16:05:56.890 [JavaFX Application Thread] TRACE o.cryptomator.ui.fxapp.FxApplication - FxApplication.start()
16:06:01.594 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationTerminator - Enabling sudden termination
16:06:01.613 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
16:06:01.615 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Found implementation: org.cryptomator.ui.traymenu.AwtTrayMenuController in jar /Applications/Cryptomator.app/Contents/app/mods/cryptomator-1.6.16.jar
16:06:01.626 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Implementation is available: org.cryptomator.ui.traymenu.AwtTrayMenuController
16:06:01.717 [JavaFX Application Thread] DEBUG o.c.u.traymenu.AwtTrayMenuController - initialized tray icon
16:06:01.729 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 001
16:06:02.016 [JavaFX Application Thread] DEBUG o.cryptomator.ui.common.FontLoader - Loaded family: Font Awesome 5 Free Solid
16:06:02.031 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowTitleController - init MainWindowTitleController
16:06:02.046 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
16:06:02.046 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Found implementation: org.cryptomator.macos.keychain.MacSystemKeychainAccess in jar /Applications/Cryptomator.app/Contents/app/mods/integrations-mac-1.1.2.jar
16:06:02.047 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Implementation is available: org.cryptomator.macos.keychain.MacSystemKeychainAccess
16:06:02.192 [JavaFX Application Thread] TRACE o.c.ui.mainwindow.ResizeController - init ResizeController
16:06:02.194 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowController - init MainWindowController
16:06:02.249 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationWindows - visible windows: 1
16:06:02.414 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Main window initialized after 9381ms
16:06:04.561 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationWindows - visible windows: 2
16:06:04.571 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationWindows - visible windows: 1
16:06:05.123 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
16:06:05.123 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - AutoStartProvider: Found implementation: org.cryptomator.macos.autostart.MacAutoStartProvider in jar /Applications/Cryptomator.app/Contents/app/mods/integrations-mac-1.1.2.jar
16:06:05.124 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - AutoStartProvider: Implementation is available: org.cryptomator.macos.autostart.MacAutoStartProvider
16:06:05.216 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationWindows - visible windows: 2
16:06:06.149 [App Scheduled Executor 02] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to /Users/ag/Library/Application Support/Cryptomator/settings.json
16:06:06.158 [App Scheduled Executor 02] INFO  o.c.common.settings.SettingsProvider - Settings saved to /Users/ag/Library/Application Support/Cryptomator/settings.json
16:06:07.310 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 002
16:06:07.311 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.UpdateChecker - Checking for updates...
16:06:09.524 [JavaFX Application Thread] INFO  o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.6.16, lastest version: 1.6.16
Can anyone help? I really want to use Cryptomator but it’s constantly freezing the Finder (see original message). Any help appreciated!
I have updated my OS to Monterey 12.6. No change at all. After the vault has been open for a while, locking my vault fails and causes the Finder to freeze requiring a full restart.
Can anyone help at all?
UPDATE: With help from Cryptomator support, I realized that I had not installed MacFuse properly. (Turns out it’s not so straightforward on Apple Silicon machines.) I now have MacFuse working properly and the freezing-upon-locking problem seems to have vanished.
