Hi!
(I try to write this in english even if it’s not my first language - I hope it’'s possible to understand my problem
I’m using Cryptomator for windows, and I automatically sync my vaults with sciebo, a cloud service offered by various german universities. The two versions (the local one and the one in the cloud) seem to be identical. If I unlock the vault directly on the sciebo-server (via webdav or cyberduck) all my files are displayed - but if I open the local vault, it seems to be empty.
This phenomenon is relatively new, everything workes fine for severeal month. Also this is not happening with all my (seven) vaults - four are working perfectly, three show the behavior described above.
Any ideas anybody? Maybe a problem with different versions of cryptomator as I somtimes opened some of the vaults via webdav from a second computer (windows as well)?
Thank you for your help!
colonius
