jgorres
October 29, 2021, 12:38pm
1
Hello everybody,
The main GUI windows is not presented on my Kubuntu 20.04.3 system. I tried the appimage version as well as the ppa - same result.
The Cryptomator icon is shown in the right hand bottom corner of the KDE control panel, right click presents the menu (German version) “Anzeigen /Einstellungen/Alle sperren/Beenden”.
“Einstellungen” presents the setup options, “Anzeigen ” does not work.
Any idea how to solve this problem?
Regards,
Jörn.
infeo
October 29, 2021, 1:22pm
2
Does the logfile contain any ERRORs, WARNings or Exceptions ? You can paste the content here. If you have privacy concerns, i can send you a PM, where you can answer with the log file.
Thanks for the welcome greeting
Here is the latest log:
16:29:38.842 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.1 on Linux 5.4.0-89-generic (amd64)
16:29:38.848 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
16:29:38.880 [main] WARN org.cryptomator.ipc.IpcCommunicator - Failed to create IPC server
java.net.BindException: Die Adresse wird bereits verwendet
at java.base/sun.nio.ch.UnixDomainSockets.bind0(Native Method)
at java.base/sun.nio.ch.UnixDomainSockets.bind(Unknown Source)
at java.base/sun.nio.ch.ServerSocketChannelImpl.unixBind(Unknown Source)
at java.base/sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at java.base/java.nio.channels.ServerSocketChannel.bind(Unknown Source)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ipc.Server.create(Server.java:33)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ipc.IpcCommunicator.create(IpcCommunicator.java:47)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.Cryptomator.run(Cryptomator.java:77)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.Cryptomator.main(Cryptomator.java:57)
16:29:38.998 [main] DEBUG o.c.launcher.IpcMessageHandler - Received launch args:
16:29:39.001 [main] DEBUG org.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI...
16:29:39.021 [main] DEBUG org.cryptomator.common.CommonsModule - Starting App Scheduled Executor 01
16:29:39.024 [App Scheduled Executor 01] DEBUG org.cryptomator.common.CommonsModule - Starting App Scheduled Executor 02
16:29:39.155 [main] DEBUG o.c.ui.traymenu.TrayIconController - initialized tray icon
16:29:39.164 [main] DEBUG o.cryptomator.ui.launcher.UiLauncher - Hiding application...
16:29:39.167 [main] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 001
16:29:50.225 [AWT-EventQueue-0] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 002
16:29:50.226 [App Background Thread 002] DEBUG o.c.ui.launcher.FxApplicationStarter - Starting JavaFX runtime...
16:29:50.421 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
16:29:50.614 [JavaFX Application Thread] TRACE o.cryptomator.ui.fxapp.FxApplication - FxApplication.start()
16:29:51.412 [JavaFX Application Thread] DEBUG org.cryptomator.ui.common.FontLoader - Loaded family: Font Awesome 5 Free Solid
16:29:51.431 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowTitleController - init MainWindowTitleController
16:29:56.436 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 003
16:29:56.438 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.UpdateChecker - Checking for updates...
16:29:57.134 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.6.1, lastest version: 1.6.1
16:30:40.595 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
16:30:40.977 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Showing Preferences
16:30:41.508 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to /home/jgorres/.config/Cryptomator/settings.json
16:30:41.517 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/jgorres/.config/Cryptomator/settings.json
infeo
October 29, 2021, 3:06pm
4
Since you are using KDE as the desktop environment, you might be affected by
opened 09:30PM - 27 Oct 21 UTC
closed 06:23AM - 28 Oct 21 UTC
type:bug
type:upstream-bug
os:linux
misc:gui
- [X] I have searched [existing issues](htt… ps://github.com/cryptomator/cryptomator/issues?q=) for duplicates
- [X] I agree to follow this project's [Code of Conduct](https://github.com/cryptomator/cryptomator/blob/develop/.github/CODE_OF_CONDUCT.md)
### Summary
Since 1.6.0 version, I have the error "Exception in thread "JavaFX Application Thread" java.io.UncheckedIOException: Failed to load /fxml/main_window.fxml" when I run Cryptomator and no GUI appears
### What software is involved?
- Operating System: Archlinux
- Java : java-17-openjdk
- Cryptomator: 1.6.1
### Volume Type
_No response_
### Steps to Reproduce
1. Run Cryptomator 1.6.1 on Archlinux(AUR package or Appimage)
### Expected Behavior
Cryptomator must not generate java exception
### Actual Behavior
Java exception during startup
### Reproducibility
Always
### Relevant Log Output
```shell
23:17:36.900 [main] DEBUG org.cryptomator.common.Environment - user.home: /home/fate
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - java.library.path: :/opt/cryptomator/lib/app:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - user.language: fr
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - user.region: null
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - logback.configurationFile: null
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/.config/Cryptomator/ipc.socket
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.keychainPath: null
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.pluginDir: ~/.local/share/Cryptomator/plugins
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.minPwLength: null
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.1
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.buildNumber: aur-1
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - cryptomator.showTrayIcon: false
23:17:36.902 [main] DEBUG org.cryptomator.common.Environment - fuse.experimental: false
23:17:36.919 [main] DEBUG org.cryptomator.common.ShutdownHook - Registered shutdown hook.
23:17:36.958 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/fate/.config/Cryptomator/settings.json
23:17:36.958 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/fate/.Cryptomator/settings.json
23:17:36.994 [main] INFO org.cryptomator.common.settings.SettingsProvider - Settings loaded from /home/fate/.Cryptomator/settings.json
23:17:36.996 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.1 on Linux 5.14.14-arch1-1 (amd64)
23:17:37.014 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /home/fate/.config/Cryptomator/ipc.socket
23:17:37.301 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.common.FxmlLoaderFactory.createScene(FxmlLoaderFactory.java:61)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.common.FxmlLoaderFactory.createScene(FxmlLoaderFactory.java:47)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.mainwindow.MainWindowModule.provideMainScene(MainWindowModule.java:76)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.mainwindow.MainWindowModule_ProvideMainSceneFactory.provideMainScene(MainWindowModule_ProvideMainSceneFactory.java:31)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl.fxmlSceneScene(DaggerCryptomatorComponent.java:5933)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:6062)
at dagger@2.39/dagger.internal.DoubleCheck.get(DoubleCheck.java:47)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.mainwindow.MainWindowComponent.showMainWindow(MainWindowComponent.java:28)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.fxapp.FxApplication.lambda$showMainWindow$1(FxApplication.java:114)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:457)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:456)
at javafx.graphics/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:290)
Caused by: javafx.fxml.LoadException:
file:///opt/cryptomator/lib/app/mods/cryptomator-1.6.1.jar!/fxml/vault_detail_locked.fxml:13
file:///opt/cryptomator/lib/app/mods/cryptomator-1.6.1.jar!/fxml/vault_detail.fxml:51
file:///opt/cryptomator/lib/app/mods/cryptomator-1.6.1.jar!/fxml/main_window.fxml:20
at javafx.fxml/javafx.fxml.FXMLLoader.constructLoadException(FXMLLoader.java:2707)
at javafx.fxml/javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:944)
at javafx.fxml/javafx.fxml.FXMLLoader$InstanceDeclarationElement.processAttribute(FXMLLoader.java:981)
at javafx.fxml/javafx.fxml.FXMLLoader$Element.processStartElement(FXMLLoader.java:230)
at javafx.fxml/javafx.fxml.FXMLLoader$ValueElement.processStartElement(FXMLLoader.java:755)
at javafx.fxml/javafx.fxml.FXMLLoader.processStartElement(FXMLLoader.java:2808)
at javafx.fxml/javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2634)
at javafx.fxml/javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2548)
at javafx.fxml/javafx.fxml.FXMLLoader$IncludeElement.constructValue(FXMLLoader.java:1153)
at javafx.fxml/javafx.fxml.FXMLLoader$ValueElement.processStartElement(FXMLLoader.java:757)
at javafx.fxml/javafx.fxml.FXMLLoader.load(FXMLLoader.java:2516)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.common.FxmlLoaderFactory.load(FxmlLoaderFactory.java:42)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.common.FxmlLoaderFactory.createScene(FxmlLoaderFactory.java:59)
... 15 more
Caused by: java.lang.NullPointerException: Cannot load from object array because "response" is null
at org.purejava.KDEWallet.isOpen(KDEWallet.java:113)
at integrations.linux@1.0.0/org.cryptomator.linux.keychain.KDEWalletKeychainAccess$ConnectedWallet.isLocked(KDEWalletKeychainAccess.java:103)
at java.base/java.util.Optional.map(Unknown Source)
at integrations.linux@1.0.0/org.cryptomator.linux.keychain.KDEWalletKeychainAccess.isLocked(KDEWalletKeychainAccess.java:41)
at org.cryptomator.desktop@1.6.1/org.cryptomator.common.keychain.KeychainManager.isLocked(KeychainManager.java:80)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.mainwindow.VaultDetailLockedController.<init>(VaultDetailLockedController.java:39)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.mainwindow.VaultDetailLockedController_Factory.newInstance(VaultDetailLockedController_Factory.java:71)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl.vaultDetailLockedController(DaggerCryptomatorComponent.java:5837)
at org.cryptomator.desktop@1.6.1/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:6096)
at org.cryptomator.desktop@1.6.1/org.cryptomator.ui.common.FxmlLoaderFactory.constructController(FxmlLoaderFactory.java:74)
at javafx.fxml/javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:941)
... 34 more
23:17:43.350 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.6.1, lastest version: 1.6.1
### Anything else?
_No response_
We’ll release next week Cryptomator 1.6.2 which contains a fix for the issue.
Hi infeo,
Thanks for the prompt reply and your assistance.
I will wait for the update and confirm the outcome of it.
Regards,
Jörn.
