Unexpected Error | Please Help
Hello there,
I created this account, because I got a problem with the Software.
I installed the desktop app and I tried to link my “old” safe.
So the program said, that I need to update the safe to a new format.
I clicked the checkbox and hit next, but then this error occured:
grafik
"org.cryptomator.cryptofs.migration.api.NoApplicableMigratorException
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:111)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:117)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:140)
Does someone know this error?
OS: Windows 10 Pro 64bit
Software Version: 1.5.16
I would be very happy about any help.
Kind regards
Stefanako
Hi. Can you please have a look into the masterkey file and name the vault version of your vault.
If you want to upgrade from a very old version, you have to do some additional steps.
Thanks for the quick help, it just works now!
