I recently upgraded to macOS “Big Sur” but this is the first time I attempt to unlock my vault since the upgrade to Big Sur. I’m not sure if this is related to the upgrade, but suddenly I am no longer able to unlock my vault which is located on iCloud Drive. When I attempt to unlock, I receive “an unexpected error occurred” message and spits out a error debug log which basically appears that it’s unable to mount the FS and returns error code 1.
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:107)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:45)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:105)
… 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:43)
… 13 more
… 14 more
