org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 53 has occurred.
The network path was not found.
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:65)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:49)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 53 has occurred.
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:62)
... 12 more
