First time having issues with Cryptomator. I have not conducted any OS software updates between now and the last time I accessed my vault (yesterday). Attempted to unlock vault as normal today and received an unexpected error and the following, which the app requested I copy/paste when contacting for help:
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: ru.serce.jnrfuse.FuseException: Unable to mount FS
at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:46)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
... 12 more
at org.cryptomator.frontend.fuse.mount.AbstractMounter.lambda$mount$0(AbstractMounter.java:26)
... 1 more
... 2 more
