I’m having the same issue. Can not open/mount the vault. This is the first time I have used Cryptomator and I have created 2 vaults, but can not mount them. ** Cryptomator 1.5.16 (exe-2831.223) Windows 10 Home, Version 20H2, Build 19042.1110, Intel i7-8750H, 12g Ram
… 11 more
… 13 more
Thanks. Updating Dokany did not solve the issue. I did increase the wait time in the cryptomator.cfg: java-options=-Dorg.cryptomator.frontend.dokany.mountTimeOut=30000
Increasing the timeout did unlock the vault, but automatically and in 1 second, it re-locked.
CRYPTOMATOR LOG:
10:30:31.986 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.16 on Windows 10 10.0 (amd64)
10:30:31.999 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
10:30:32.000 [main] DEBUG org.cryptomator.launcher.IpcFactory - [Client] Failed to connect.
10:30:32.075 [main] DEBUG org.cryptomator.launcher.IpcFactory - [Server] Wrote IPC port 50369 to C:\Users\BlaineC\AppData\Roaming\Cryptomator\ipcPort.bin
10:30:32.077 [main] DEBUG o.c.launcher.IpcProtocolImpl - Received launch args:
10:30:32.078 [main] DEBUG org.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI...
10:30:32.272 [main] DEBUG o.c.ui.traymenu.TrayIconController - initialized tray icon
10:30:32.276 [main] DEBUG o.cryptomator.ui.launcher.UiLauncher - Showing application...
10:30:32.279 [main] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 001
10:30:32.279 [App Background Thread 001] DEBUG o.c.ui.launcher.FxApplicationStarter - Starting JavaFX runtime...
10:30:32.284 [main] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 002
10:30:32.505 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
10:30:32.634 [JavaFX Application Thread] TRACE o.cryptomator.ui.fxapp.FxApplication - FxApplication.start()
10:30:33.068 [JavaFX Application Thread] DEBUG org.cryptomator.ui.common.FontLoader - Loaded family: Font Awesome 5 Free Solid
10:30:33.085 [JavaFX Application Thread] DEBUG o.c.u.m.MainWindowTitleController - init MainWindowTitleController
10:30:33.250 [JavaFX Application Thread] DEBUG o.c.u.m.MainWindowController - init MainWindowController
10:30:33.311 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
10:30:33.663 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Showing MainWindow
10:30:38.088 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 003
10:30:38.090 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.UpdateChecker - Checking for updates...
10:30:40.351 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.16, lastest version: 1.5.16
10:30:59.563 [JavaFX Application Thread] DEBUG o.c.w.k.WindowsProtectedKeychainAccess - Attempting to load keychain from C:\Users\BlaineC\AppData\Roaming\Cryptomator\keychain.json
10:31:13.364 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Scheduled Executor 01
10:31:13.372 [JavaFX Application Thread] DEBUG o.c.u.r.RemoveVaultController - Removing vault test.
10:31:14.366 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:31:14.372 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:31:31.488 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
10:31:56.246 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Scheduled Executor 02
10:31:56.249 [JavaFX Application Thread] DEBUG o.c.u.r.RemoveVaultController - Removing vault Test2.
10:31:57.248 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:31:57.252 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:32:17.274 [JavaFX Application Thread] DEBUG o.c.u.a.AddVaultWelcomeController - AddVaultWelcomeController.createNewVault()
10:32:58.985 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 004
10:32:58.986 [App Background Thread 004] DEBUG o.c.c.common.ReseedingSecureRandom - Seeding CSPRNG with 55 bytes...
10:32:58.987 [App Background Thread 004] DEBUG o.c.c.common.ReseedingSecureRandom - Seeded CSPRNG.
10:32:59.309 [App Background Thread 004] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
10:32:59.554 [App Background Thread 004] TRACE o.c.cryptofs.fh.FileHeaderHolder - Generating file header for D:\Users\BlaineC\Documents\MEGAsync\StoneCold.Cryptomator\Test3\d\IL\RCXPRDDT2AQBBBJBTBHZAZDDELVCFC\FrM7Uj0EaGXeoqEMHBF91AO5agNF3kLb_KgO.c9r
10:32:59.555 [App Background Thread 004] TRACE o.c.cryptofs.fh.OpenCryptoFile - First channel for this openFile. Initializing file size...
10:32:59.559 [App Background Thread 004] TRACE o.c.cryptofs.ch.CleartextFileChannel - org.cryptomator.cryptofs.ch.CleartextFileChannel@11930744 - Writing file header.
10:32:59.567 [App Background Thread 004] INFO o.c.u.a.CreateNewVaultPasswordController - Created vault at D:\Users\BlaineC\Documents\MEGAsync\StoneCold.Cryptomator\Test3
10:33:00.570 [App Scheduled Executor 02] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:00.576 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:01.045 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
10:33:01.045 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: false
10:33:01.054 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 005
10:33:01.055 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Start unlock workflow for Test3
10:33:10.688 [JavaFX Application Thread] TRACE o.c.ui.unlock.UnlockController - UnlockController.unlock()
10:33:10.689 [App Background Thread 005] DEBUG org.cryptomator.common.vaults.Vault - Determining file name length limitations...
10:33:10.708 [App Background Thread 005] INFO org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
10:33:10.711 [App Background Thread 005] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
10:33:10.953 [App Background Thread 005] DEBUG o.c.c.common.MasterkeyBackupHelper - Verified backup file: D:\Users\BlaineC\Documents\MEGAsync\StoneCold.Cryptomator\Test3\masterkey.cryptomator.C5C5D2BD.bkup
10:33:11.052 [App Background Thread 005] DEBUG o.c.frontend.dokany.MountFactory - Mounting on F:\: ...
10:33:11.070 [App Background Thread 005] INFO com.dokany.java.DokanyMount - Dokany API/driver version: 150 / 400
10:33:11.709 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:11.713 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:21.163 [dokanMount-1-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
10:33:21.163 [App Background Thread 005] DEBUG o.c.frontend.dokany.MountFactory - Mounted directory at F:\ successfully.
10:33:21.165 [dokanMount-1-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
10:33:21.173 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Test3' succeeded.
10:33:21.174 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - start recording stats
10:33:21.195 [JavaFX Application Thread] DEBUG org.cryptomator.common.CommonsModule - Starting App Background Thread 006
10:33:22.166 [dokanMount-1-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault 'Test3'
10:33:22.166 [dokanMount-1-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
10:33:22.167 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
10:33:22.167 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: true
10:33:26.789 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.revealAndClose()
10:33:26.795 [JavaFX Application Thread] WARN o.c.u.unlock.UnlockSuccessController - Reveal failed.
org.cryptomator.common.vaults.Volume$VolumeException: java.lang.IllegalStateException: Filesystem not mounted.
at org.cryptomator.common.vaults.DokanyVolume.reveal(DokanyVolume.java:57)
at org.cryptomator.common.vaults.Vault.reveal(Vault.java:191)
at org.cryptomator.ui.common.VaultService$RevealVaultTask.call(VaultService.java:120)
at org.cryptomator.ui.common.VaultService$RevealVaultTask.call(VaultService.java:102)
Caused by: java.lang.IllegalStateException: Filesystem not mounted.
at com.dokany.java.DokanyMount.reveal(DokanyMount.java:180)
at org.cryptomator.common.vaults.DokanyVolume.reveal(DokanyVolume.java:55)
... 8 common frames omitted
10:33:27.791 [App Scheduled Executor 02] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:27.795 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:28.410 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.revealAndClose()
10:33:28.410 [JavaFX Application Thread] WARN o.c.u.unlock.UnlockSuccessController - Reveal failed.
10:33:32.066 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.revealAndClose()
10:33:32.067 [JavaFX Application Thread] WARN o.c.u.unlock.UnlockSuccessController - Reveal failed.
10:33:32.278 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.revealAndClose()
10:33:32.279 [JavaFX Application Thread] WARN o.c.u.unlock.UnlockSuccessController - Reveal failed.
10:33:32.481 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.revealAndClose()
10:33:32.481 [JavaFX Application Thread] WARN o.c.u.unlock.UnlockSuccessController - Reveal failed.
10:33:33.730 [JavaFX Application Thread] TRACE o.c.u.unlock.UnlockSuccessController - UnlockSuccessController.close()
10:33:34.739 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:34.742 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\BlaineC\AppData\Roaming\Cryptomator\settings.json
10:33:37.004 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
10:33:37.005 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: false
10:33:37.005 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Start unlock workflow for Test3
10:33:37.008 [App Background Thread 006] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
10:33:37.224 [App Background Thread 006] DEBUG o.c.c.common.MasterkeyBackupHelper - Verified backup file: D:\Users\BlaineC\Documents\MEGAsync\StoneCold.Cryptomator\Test3\masterkey.cryptomator.C5C5D2BD.bkup
10:33:37.227 [App Background Thread 006] DEBUG o.c.frontend.dokany.MountFactory - Mounting on F:\: ...
10:33:37.227 [App Background Thread 006] INFO com.dokany.java.DokanyMount - Dokany API/driver version: 150 / 400
10:33:47.308 [App Background Thread 006] DEBUG o.c.frontend.dokany.MountFactory - Mounted directory at F:\ successfully.
10:33:47.308 [dokanMount-2-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
10:33:47.310 [dokanMount-2-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
10:33:47.312 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Test3' succeeded.
10:33:47.313 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - start recording stats
10:33:48.311 [dokanMount-2-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault 'Test3'
10:33:48.311 [dokanMount-2-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
10:33:48.311 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
10:33:48.312 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: true
