I have several in sync.ffs_db files in top level encrypted directories. When I unlock a drive, these files all have “Date modified” dates equal to the time when the drive was opened, except for one. It is showing yesterday’s date and when I try to sync the decrypted directory to a backup, I get an error saying the file cannot be copied. All other sync.ffs_db file do not generate this error. Any suggestions on how to fix this? I an concerned that if I delete the sync.ffs_db file I will lose the directory. Thanks for your help.
when you try to copy the file in question, does the log file contain any ERRORs, WARNings or Exceptions?
those are related to FreeFileSync - how often do you perform a sync of your dir and to/from how many destinations - if another machine does perform a sync simultaneously the db might become confuses but it shouldn’t be rated to cryptomator - as far as I can say if you delete ore move the sync.ffs.db file you should ‘only’ loose your sync database for FreeFileSync and might have to perform another full first sync - depending on the size that might or might not be a problem …
