I have started using Cryptomator from 2 days ago to sync my data to Google Drive for Edu (unlimited). But I am stuck at 0.99TB since today morning. Is there a way to solve this limitations?
Note: My Google Drive quota is unlimited storage. I have used Dokany volume type.
Michael
February 21, 2020, 12:15pm
#2
Hi. Cryptomator does not have space limitations either.
So the question is: does the copy process of files into the vault stuck, or the sync?
The copy process of files into the vault is stuck.
Michael
February 21, 2020, 2:48pm
#4
Do you use WebDAV or dokany as volume type?
If you use WebDAV, then maybe the WebDAV limitations affects you. So please change.
Is there an error message?
Something suspicious in the log file?
Here is the content of cryptomator0.log:
10:52:45.023 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.15 on Windows 10 10.0 (amd64)
10:52:47.399 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
10:52:47.831 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
10:52:48.000 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
10:52:48.043 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
10:52:55.016 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Unable to load existing keychain file, creating new keychain.
10:53:01.637 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
10:54:11.408 [Background Thread 2] INFO com.dokany.java.DokanyDriver - Dokany version: 130
10:54:11.408 [Background Thread 2] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
10:54:36.795 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
22:56:09.810 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Administrator\AppData\Roaming\Cryptomator\settings.json
02:08:19.115 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Administrator\AppData\Roaming\Cryptomator\settings.json
Michael
February 22, 2020, 2:25pm
#8
Mhm cannot see anything that would explain your issue. Maybe someone else an idea?
