Hi. I am using Cryptomator with google drive. My google drive has unlimited storage. But when i make a vault, it only shows 99 gb. is there a limit or something. I am using Monterey on Mac m1.
Hi. I guess you are on windows and I guess you have configured WebDAV as volume type in the cryptomator settings.
If I am right: see here
You can change the volume type to FUSE (WinFSP) to avoid that.
@ Michael. I am on macos and i am using macfuse
Ok. The virtual drive does show the capacity of the local storage where your vault is stored local.
If there’s 99 GB of free storage on your system, then this is normal behaviour.
Oh ok thx for the info. But this mean that i can make as many vaults as i want right? @Michael
yes that is right.
No limits
Thank you for the help
