aranud
#1
hi,
Sorry for bad english
I have create a folder “vault” on my synology with more 923GB free.
I add new vault on Cryptomator from \192.168.1.38\Vault
After save, drive mount show the size of my master driver C: and not the size on the synology :o
I take screenshots :
On my synology :
On my desktop, you can see Vault = Drive C size :
I have try, to delete and recreate but same issue :’(
thank you for help
This is a known issue with windows WebDAV.
Please switch to Dockany in the settings of cryptomator.
aranud
#3
hi,
Thank you, i have switch with dockany and it is run fine
