Hi everyone, I used Cryptomator 4days ago, at that time I create my vault in the same directory with my data files to be encrypted(and it create a subdirectory with the same name of current directory). Then I use Ctrl+X to cut all my files and paste it into the vault. Everything looks good . 3 days later however, I have to reboot my computer (since there are some issues while my laptop doesn’t display any WiFi SSID on the taskbar, not important). But after I reboot my laptop, I found that there was no *.cryptomator file under the vault directory leaving all my files encrypted. I also remember the password and recover phrase, is there any way to recover my data?
very similar to the case mentioned here, but I have tried to downgrade to 1.5.17 and nothing worked. Any help is highly appreciated.
