I have a cryptomator vault in my pCloud drive. Unfortunately when copying many files I often get a -43 or -36 error from the finder and the vault is unmounted right away. It often works after a second or third try.
Anybody had this issue before?
It’s a known Bug in Hight Sierra and Windows WebDAV.
Version 1.4 will add FUSE support in addition to WebDAV.
So … is this still an issue on macOS High Sierra 10.13.3?
If yes, when can we expect to see a fix?
edit: Okay, I just gave Cryptomator Version 1.3.2 (1046) a try and it seems it still has the problem. The container unmounted while operation.
Thanks for the reply. When can we expect the update?
There’s no release date announced yet.
Since it is understandable that not all of our users can track all development activities on GitHub, I would like to write a few paragraphs here about the technical updates that are planned for Cryptomator in 2018 and their impact on usage.
This is a companion discussion topic for the original entry at https://cryptomator.org/blog/2018/01/07/roadmap_en.html
