im using cryptomator 1.4.17 and Mac OS Catalina 10.15.4. How can I make spotlight find the files in the fuse drive/ vault?
Hope to find a solution here.
Greetings from Germany
thanks for the info.
mabe someone has a alternative solution for this.
is the feature going to come in the next update or is this a general problem, because spotlight is essential to find documents and files?
im hoping to find a solution for the issue
Agreed that this is a big issue. I assume Cryptomator is aware of it, but I’ll add my voice that the current setup is non-intuitive, and counter-productive.
If there’s any way Cryptomator can adjust the FUSE settings so that mounted (unencrypted) Vaults get indexed by Spotlight, I hope they can do this in an update. And tell us it’s coming if it is.
Until then, a workaround is to use something like EasyFind and tell it to specifically search in the mounted Vault. Which is a pain but works.
unknowable
