Hello dear community. I have the following problem. I have encrypted my data using Cryptomator v. 1.531 at a cloud provider. A week ago I could no longer access the data. My password is not accepted. An update to version 1.6x unfortunately only brings the message window that an update of the database must be performed. When I confirm this and enter the password, the password is not accepted either. Enclosed is the corresponding log.
Does anyone have any idea how I can get my data?
13:32:04.946 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.13 on Windows 10 10.0 (amd64)
13:32:07.750 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
13:32:09.130 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
13:32:10.165 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.13 on Windows 10 10.0 (amd64)
13:32:10.305 [main] INFO org.cryptomator.launcher.Cryptomator - Found running application instance. Shutting down...
13:39:01.490 [JavaFX Application Thread] INFO o.c.w.k.WindowsProtectedKeychainAccess - Unable to load existing keychain file, creating new keychain.
13:39:02.485 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\user\AppData\Roaming\Cryptomator\settings.json
13:39:43.303 [App Background Thread 003] INFO org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
13:39:44.217 [App Background Thread 003] INFO com.dokany.java.DokanyMount - Dokany API/driver version: 141 / 400
13:39:44.308 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\ user \AppData\Roaming\Cryptomator\settings.json
13:39:50.222 [App Background Thread 003] WARN o.c.frontend.dokany.MountFactory - Mounting timed out.
13:39:50.222 [App Background Thread 003] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'U_Sammlung' succeeded.
13:40:59.890 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
13:45:19.411 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.13 on Windows 10 10.0 (amd64)
13:45:19.528 [main] INFO org.cryptomator.launcher.Cryptomator - Found running application instance. Shutting down...
13:45:19.541 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
13:45:31.263 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\ user \AppData\Roaming\Cryptomator\settings.json
13:45:53.663 [App Background Thread 006] INFO org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
13:45:54.671 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\ user \AppData\Roaming\Cryptomator\settings.json
13:46:17.306 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
14:25:08.858 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
14:51:16.391 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
14:51:58.843 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
14:52:09.674 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\ user \AppData\Roaming\Cryptomator\settings.json
14:52:30.701 [App Background Thread 006] INFO org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
14:52:31.704 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\ user \AppData\Roaming\Cryptomator\settings.json
14:52:37.650 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
Translated with www.DeepL.com/Translator (free version)
