My company gives me 5TB of OneDrive storage. I would like to use this storage to securely store 800GB of my photos and videos (without the company taking a peek).
However, my boot drive (C:) is where the OneDrive folder is located and it only runs to 200GB. I have set the OneDrive to “Free Up Space” on for the Vault. But, how can I get the 800GB of photos into the vault when my local HDD isn’t able to hold that much data?
If you have anywhere else enough free space, you can create your vault there and configure the OneDrive App to use this path as sync folder.
If not I do not see a way to do this with Cryptomator desktop. But you can give cyberduck a try if you want to create/access a vault directly online in your OneDrive storage (then of course without the sync of the OneDrive app).
