I’m uploading a 4tb vault to Google Drive via Google Drive File Stream.
The only solution that worked untill this moment was buying a new 4tb hard drive, and setting this drive as cache of Google Drive File Stream application for Windows.
Then inside of the drive provided by the application, create the encrypted vault.
All other tries with CyberDuck or MountainDuck where full of fails and errors.
Now at least its uploading. Err, not at all!
The Google Drive File Stream application begun to show me an error saying that ‘Some file couldn’t be uploaded, so it was put inside lost_and_found folder’.
The fact is that inside this folder there is already 2gb of files that I don’t know from wich folders on the Vault structure it was taken off.
I tryed to decrypt this files with sanitizer, but i have this error:
Exception in thread “main” java.lang.IllegalArgumentException: Unsupported vault version 7
at org.cryptomator.sanitizer.CryptorHolder.bestGuessCryptorProvider(CryptorHolder.java:91)
at org.cryptomator.sanitizer.restorer.VaultDecryptor.run(VaultDecryptor.java:32)
at org.cryptomator.sanitizer.commands.DecryptVaultRunner.run(DecryptVaultRunner.java:21)
at org.cryptomator.sanitizer.commands.DecryptVaultCommand.run(DecryptVaultCommand.java:91)
at org.cryptomator.sanitizer.commands.Commands.run(Commands.java:75)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:16)
at java.base/java.util.Optional.ifPresent(Optional.java:176)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:12)
Is there any idea on how can I found from wich folders on the vault structure, those files are taken off?
