I know there are multiple topics on this already, but can anything be done about the “Lock failed” popup that always comes up when I try to lock my vault?
I am using v1.6.14 on Windows 11.
I have attached screenshots of the issue, and I can see what files are currently locked, but the files are only locked/opened by Cryptomator and not by any other Windows processes or programs.
Before locking, I always do this:
- I verify that Cryptomator is not reading or writing (in the right corner of the window)
- I verify Dropbox is done syncing the files
Sometimes when the “Lock Failed” comes up, I will wait a few minutes and try again, and it will lock. Most times, however, I wait, and it never locks (it will keep showing me the “Lock Failed” popup window). So then I have to force lock it, but that always makes me nervous about losing file data.
Screenshot: Cryptomator Lock Issue
Debug log:
10:22:03.289 [App Background Thread 031] TRACE o.c.f.fuse.locks.PathWLockImpl - Acquired write path lock for '[]'
10:22:03.290 [App Background Thread 031] TRACE o.c.f.fuse.locks.PathWLockImpl - Released write path lock for '[]'
10:22:03.290 [App Background Thread 031] INFO o.cryptomator.ui.lock.LockWorkflow - Locking Dropbox failed (forced: false).
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.FuseMountException: Unmount refused: There are open files or pending operations.
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:106)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.Vault.lock(Vault.java:178)
at org.cryptomator.desktop@1.6.14/org.cryptomator.ui.lock.LockWorkflow.lock(LockWorkflow.java:63)
at org.cryptomator.desktop@1.6.14/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:57)
at org.cryptomator.desktop@1.6.14/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:34)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: Unmount refused: There are open files or pending operations.
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.AbstractMount.unmount(AbstractMount.java:33)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:104)
... 10 common frames omitted
