After updating Cryptomator for Windows 10 to version 1.14.0, I noticed that after unlocking the vault, its maximum size was limited to 237gb in total. Previously, its capacity was the same as my pCloud. I have almost 1TB of free space on pCloud, and the vault shows me that I have 45gb left. Why is this happening?
thanks
Please check that your configured virtual file system is not set to WebDAV. (Cryptomator Settings Volume Type)
If set to WebDAV, you are facing this: Virtual drive shows capacity of system partition (C:)
@Michael, thanks for your reply
I checked Volume Type and it was set to WebDav (Windows Explorer). Another option that was available was WebDav (Http Address). I closed Cryptomator and pCloud, restarted and this time I had the WinFsp option. I set that option and the problem was solved. Thanks.
