Hi there,
just bought Cryptomator Android from Google Play and installed it successfully. Now I would like to use it in my other Android devices (phone), do I require a license key to do it, which I don’t have?
How about installing Cryptomator in my wife’s phone, do I need another license for her?
Timo
This works the same as other apps that you’ve bought via Google Play. If you’re using the same Google account, you don’t have to purchase it again.
Cryptomator is eligible for Family Library. If you’ve set it up on your wife’s phone, you don’t need an additional purchase for this case either.
If the Playstore on one of your devices thinks you need to buy the app again, see here for more info: On how many devices can the app be installed using Google Play Store?
