This just doesn’t seem right…
The first time i saw this post i wanted to say “that’s normal”. But after some time thinking and talking with other developers, we profiled the application several times and after anaylzing the results we concluded there must be a memory leak. And this was correct! Not only that, with high probability also now Cryptomator / Dokany crashes after heavy use is fixed.
Thank you for giving the initial hint to delve deeper into this!
