Is it ok to have a vault open on 2 or more computers at the same time?
Hi
I wonder if it is ok to have a vault open on various computers and operating systems (Mac, Windows, Linux) at the same time. Are there any issues with that?
Background: I work constantly and simultaneously at different locations on site and via Teamviewer. The vault is stored at kDrive - collaborative storage on a 100% Swiss Made cloud which is unfortunately not E2E encrypted. Hence the use of Cryptomator.
Yes.
see here: Multiple Locations
or here Search results for 'multiple' - Cryptomator Community
Edit: Thanks for your quick help!
I Use OneDrive on several systems but the data is encrypted by Cryptomator.
As long as you keep OneDrive in SYNC in the different systems, it works for me perfectly already for more than 4 years.
I have since 2020, version 1.5.x ( now almost 2025 and Cryptomator version 1. 14.2 (msi 5384 ) not one issue seen …
When I miss data on system1, almost 100% sure the OneDrive data sync was not finished yet on system 2.
Be aware of 100% Synced data or other shared data.
Issue with missing data has nothing to do with Cryptomator !!!
Cheers,
Jan
