Files integration similar to Secure ShellFish
I know this has been discussed before and I also saw the milestone added on github for version 1.5. I just wanted to check if there is any ETA and how the integration will work? For me the Files integration is what‘s keeping from using Cryptomator.
Also, I think the way Secure ShellFish is working on iOS might be a good solution for Cryptomator: The app itself is just for configuration and all files are accessed through the files app (the app would be encrypting in the background). I‘m not certain that would technically be possible, but just wanted to put it out there.
Philipp
A post was merged into an existing topic: iOS Files integration
