Win10 Pro, Cryptomator 1.4.6 (Dokany mode), and Dropbox 68.4.102.
As far as I can recall, this problem began with 1.4.6. When attempting to quit Cryptomator with a vault located on Dropbox mounted, I get the following error popup:
Vault(s) in use
One or more vaults are still in use by other programs. Please close them to allow Cryptomator to shut down properly, then try again.
If this doesn’t work, Cryptomator can shut down forcefully, but this can incur data loss and is not recommended.
If I hit the “Cancel” button, Cryptomator exits. I have never tried Force Shutdown or Try Again options.
I have debug log from another instance of this happening. It’s 11.5 MB in size.
This happens every time I quit Cryptomator with my vault mounted. I have confirmed that there are no tasks accessing the vault at the time or files from the vault opened.
I have found that this error does not occur if I explicitly lock the vault before exiting out of Cryptomator. This only happens if I exit out of Cryptomator with the vault unlocked and mounted. It did not behave this way previously.
