Error when trying to unlock personal vault
Hi there,
I continuously receive an error when trying to unlock my vault. The error message said to report the error so here it is:
org.cryptomator.cryptolib.api.UnsupportedVaultFormatException: Tried to open vault of version 999, but can only handle version 7
	at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:117)
	at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:108)
	at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:40)
	at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:41)
	at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
	at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
	at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:337)
	at org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:130)
	at org.cryptomator.common.vaults.Vault.unlock(Vault.java:147)
Same as this: Cryptomator repeatedly losing access to more and more vaults
The vault is format 8 and can only be openend with desktop app 1.6.x or higher.
Please check if you are using the latest desktop app.
ah thanks so much! works now!
