Error message when opening vault
Hi, I keep getting the following message when opening my vault:
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:57: execution error: An error of type -5014 has occurred. (-5014)
	at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:65)
	at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:49)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:57: execution error: An error of type -5014 has occurred. (-5014)
	at org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter.mount(MacAppleScriptMounter.java:50)
	at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:62)
	... 12 more
Can someone explain to me what seems to be the problem? Thanks in advance.
Hi and welcome.
Please see here: Cryptomator cannot connect to the vault
