Hi all, problem’s simple: After installing CM, clicking the plus-button and “create new vault” the window even displayed in the tutorial won’t open. Instead a “windows”-window opens and that’s that…
I’d appreciate any help.
Thanks,
R
Thanks,
R
Which cryptomator version and which windows version do you use?
Do you receive an error Message?
Can you please enable debug mode, proceeded until your error and provide the Logfile?
Thanks for the quick answer and sorry for the late reply.
However, I think it was a problem on my side. My Computer wouldn’t let me save anything. I restarted it on the next day and it then worked and works ever since, for which I decided to buy the programm.
Thank you and best regards
R
