I want to use Cryptomator on a 32-bit netbook running Debian Linux 10 (Buster). This is now my backup computer, but I’d like to get this working. Can anyone please advise the best way to try this?
the current AppImage says 64-bit only, and the ‘system requirements’ refer to an Oracle Java version that only runs on 64-bit machines
I am willing to install an old version (eg a 32-bit .deb file) but I am not sure which one to try
I followed by starting Cryptomator using the java command mentioned in the post above. Here is what I got:
michael@debian-netbook:/opt/Cryptomator/app$ java -jar Cryptomator-1.3.2.jar
18:57:22.798 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.2 on Linux 4.19.0-5-686-pae (i386)
18:57:22.886 [main] WARN org.cryptomator.launcher.InterProcessCommunicator - System property cryptomator.ipcPortPath not set.
18:57:22.895 [main] DEBUG org.cryptomator.launcher.InterProcessCommunicator - Could not connect to running process.
18:57:23.731 [main] ERROR org.cryptomator.launcher.Cryptomator - Failed to initiate inter-process communication.
java.nio.file.AccessDeniedException: .ipcPort.tmp
at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:90)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116)
at java.base/sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:215)
at java.base/java.nio.file.Files.newByteChannel(Files.java:370)
at java.base/java.nio.file.Files.newByteChannel(Files.java:421)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.writePort(InterProcessCommunicator.java:172)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.(InterProcessCommunicator.java:164)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.(InterProcessCommunicator.java:148)
at org.cryptomator.launcher.InterProcessCommunicator.start(InterProcessCommunicator.java:74)
at org.cryptomator.launcher.InterProcessCommunicator.start(InterProcessCommunicator.java:56)
at org.cryptomator.launcher.Cryptomator.main(Cryptomator.java:29)
