Running Debian Bookwork Linux machine with KDE as desktop environment.
Cyrptomator would launch yet no mounting is happening. Nor I am able to open any Cryptomator window when chossing so via the icon tray.
That happens with both the Appimage and deb packages.
I am not sure what is causing this issue on one of the machines, and would appreciate any solution for this issue thus I can mount Cryptomator.
Thank you
0:03:42.307 [JavaFX Application Thread] ERROR o.c.ui.fxapp.FxApplicationWindows - Failed to display stage
java.util.concurrent.CompletionException: java.lang.NoClassDefFoundError: Could not initialize class de.swiesend.secretservice.simple.SimpleCollection
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source)
at javafx.graphics@20.0.2/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(Unknown Source)
at javafx.graphics@20.0.2/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(Unknown Source)
at javafx.graphics@20.0.2/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(Unknown Source)
at javafx.graphics@20.0.2/com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at javafx.graphics@20.0.2/com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class de.swiesend.secretservice.simple.SimpleCollection
at org.cryptomator.integrations.linux@1.4.0-beta2/org.cryptomator.linux.keychain.SecretServiceKeychainAccess.isSupported(SecretServiceKeychainAccess.java:28)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$15$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at java.base/java.util.stream.SortedOps$RefSortingSink.end(Unknown Source)
at java.base/java.util.stream.Sink$ChainedReference.end(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.toArray(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.toList(Unknown Source)
at org.cryptomator.desktop@1.11.0/org.cryptomator.common.keychain.KeychainModule.provideSupportedKeychainAccessProviders(KeychainModule.java:19)
at org.cryptomator.desktop@1.11.0/org.cryptomator.common.keychain.KeychainModule_ProvideSupportedKeychainAccessProvidersFactory.provideSupportedKeychainAccessProviders(KeychainModule_ProvideSupportedKeychainAccessProvidersFactory.java:29)
at org.cryptomator.desktop@1.11.0/org.cryptomator.launcher.DaggerCryptomatorComponent$CryptomatorComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:9206)
at dagger@2.48.1/dagger.internal.DoubleCheck.get(DoubleCheck.java:47)
at org.cryptomator.desktop@1.11.0/org.cryptomator.launcher.DaggerCryptomatorComponent$CryptomatorComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:9201)
at org.cryptomator.desktop@1.11.0/org.cryptomator.launcher.DaggerCryptomatorComponent$CryptomatorComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:9195)
at org.cryptomator.desktop@1.11.0/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:3139)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.common.FxmlLoaderFactory.constructController(FxmlLoaderFactory.java:78)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader$ValueElement.processAttribute(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader$InstanceDeclarationElement.processAttribute(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader$Element.processStartElement(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader$ValueElement.processStartElement(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader.processStartElement(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader.loadImpl(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader$IncludeElement.constructValue(Unknown Source)
at javafx.fxml@20.0.2/javafx.fxml.FXMLLoader.load(Unknown Source)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.common.FxmlLoaderFactory.load(FxmlLoaderFactory.java:46)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.common.FxmlLoaderFactory.createScene(FxmlLoaderFactory.java:63)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.common.FxmlLoaderFactory.createScene(FxmlLoaderFactory.java:51)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.mainwindow.MainWindowModule.provideMainScene(MainWindowModule.java:78)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.mainwindow.MainWindowModule_ProvideMainSceneFactory.provideMainScene(MainWindowModule_ProvideMainSceneFactory.java:38)
at org.cryptomator.desktop@1.11.0/org.cryptomator.launcher.DaggerCryptomatorComponent$MainWindowComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:3072)
at org.cryptomator.desktop@1.11.0/org.cryptomator.ui.mainwindow.MainWindowComponent.showMainWindow(MainWindowComponent.java:28)
... 8 common frames omitted
Caused by: java.lang.ExceptionInInitializerError: Exception org.freedesktop.dbus.exceptions.AddressResolvingException: Cannot Resolve Session Bus Address: MachineId file can not be found [in thread "JavaFX Application Thread"]
at org.freedesktop.dbus@4.3.0/org.freedesktop.dbus.utils.AddressBuilder.getDbusMachineId(AddressBuilder.java:133)
at org.freedesktop.dbus@4.3.0/org.freedesktop.dbus.connections.impl.DBusConnectionBuilder.forSessionBus(DBusConnectionBuilder.java:44)
at org.freedesktop.dbus@4.3.0/org.freedesktop.dbus.connections.impl.DBusConnectionBuilder.forSessionBus(DBusConnectionBuilder.java:65)
at de.swiesend.secretservice@2.0.0-alpha/de.swiesend.secretservice.simple.SimpleCollection.getConnection(SimpleCollection.java:140)
at de.swiesend.secretservice@2.0.0-alpha/de.swiesend.secretservice.simple.SimpleCollection.<clinit>(SimpleCollection.java:40)
... 62 common frames omitted
