I’m trying to get started with Cryptomator (Win10 64 bit), creating a vault inside Dropbox. I want to create a vault in a custom Folder within the Dropbox Folders. Everytime I press the “search folder” button, Cryptomator crashes. I can not manually enter the directory.
I installed a vault on another PC (where I also use the Dropbox). Trying to install an existing vault, Cryptomator crashes, as soon as it starts searching for the vault.
Still crashing…but I found a solution: Create a vault in OneDrive. Copy it to the Dropbox-folder. Doubleclicking the vault-file will start Cryptomator an I can mount the vault.
