Hello folks,
I use Cryptomator 1.6.5. on a windows 11 machine. A synology NAS DS920 is connect via LAN to the machine, on which several vaults lie. I can unlock any vault via Cryptomator by accessing it through its according directory in the “network” drive in windows explorer.
This is what I do to reproduce the bug:
- I mount one of my vaults from NAS through its windows network directory as a drive on my windows machine.
- From another external HDD mounted to the windows machine, I try to copy quite a big chunk of files (~50GB, ~100,000 files) via the windows explorer copy tool (essentially ctrl+c/+v).
- After ~1 minute, while the copy wizard is still assessing the size/amount of files to be copied on the HDD, all (!) mounted drives are closed by Crptomator. When i remount the drive while the copy process is still assessing the files to be copied, Cryptomator will unmount the vault again after less than 1 minute.
This is undesired behavior, as I wish the vault not to be randomly unmounted so my copy process can finish.
This is, what the log says:
08:20:24.092 [dokanMount-1-callback-3] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
08:20:24.093 [dokanMount-1-callback-3] TRACE o.c.frontend.dokany.ReadWriteAdapter - (40) / opened successful with handle 40.
08:20:24.093 [dokanMount-1-callback-4] TRACE o.c.frontend.dokany.ReadWriteAdapter - (40) getFileInformation() is called for /.
08:20:24.093 [dokanMount-1-callback-4] TRACE o.c.frontend.dokany.ReadWriteAdapter - (40) File Information successful read from /.
08:20:24.093 [dokanMount-1-callback-0] TRACE o.c.frontend.dokany.ReadWriteAdapter - (40) cleanup() is called for /.
08:20:24.093 [dokanMount-1-callback-1] TRACE o.c.frontend.dokany.ReadWriteAdapter - (40) closeFile() is called for /.
08:20:37.993 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
CreateDisposition -- OPEN_EXISTING
createOptions -- [FILE_DIRECTORY_FILE, FILE_SYNCHRONOUS_IO_NONALERT]
accessMasks -- [SYNCHRONIZE]
fileAccessMasks -- []
fileAttributes -- [].
08:20:38.107 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
08:20:38.107 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - (114) / opened successful with handle 114.
08:20:38.108 [dokanMount-4-callback-0] TRACE o.c.frontend.dokany.ReadWriteAdapter - (114) getFileInformation() is called for /.
08:20:38.108 [dokanMount-4-callback-0] TRACE o.c.frontend.dokany.ReadWriteAdapter - (114) File Information successful read from /.
08:20:38.108 [dokanMount-4-callback-3] TRACE o.c.frontend.dokany.ReadWriteAdapter - (114) cleanup() is called for /.
08:20:38.108 [dokanMount-4-callback-4] TRACE o.c.frontend.dokany.ReadWriteAdapter - (114) closeFile() is called for /.
08:20:38.110 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
08:20:38.110 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
08:20:38.111 [dokanMount-4-callback-2] TRACE o.c.frontend.dokany.ReadWriteAdapter - (115) / opened successful with handle 115.
08:20:38.111 [dokanMount-4-callback-0] TRACE o.c.frontend.dokany.ReadWriteAdapter - (115) getFileInformation() is called for /.
08:20:38.111 [dokanMount-4-callback-0] TRACE o.c.frontend.dokany.ReadWriteAdapter - (115) File Information successful read from /.
08:20:38.111 [dokanMount-4-callback-3] TRACE o.c.frontend.dokany.ReadWriteAdapter - (115) cleanup() is called for /.
08:20:38.111 [dokanMount-4-callback-4] TRACE o.c.frontend.dokany.ReadWriteAdapter - (115) closeFile() is called for /.
08:21:05.702 [dokanMount-2-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
08:21:05.703 [dokanMount-2-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
08:21:05.797 [dokanMount-1-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
08:21:05.797 [dokanMount-3-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
08:21:05.798 [dokanMount-3-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
08:21:05.798 [dokanMount-1-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
08:21:05.798 [dokanMount-1-main] WARN o.c.f.dokany.OpenHandleFactory - Closing unclosed handle to /
08:21:06.703 [dokanMount-2-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault '2013_2019-personal_imagery'
08:21:06.703 [dokanMount-2-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
08:21:06.705 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
08:21:06.798 [dokanMount-3-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault '2020_2021-personal_imagery'
08:21:06.798 [dokanMount-1-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault 'private'
08:21:06.798 [dokanMount-3-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
08:21:06.798 [dokanMount-1-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
08:21:06.798 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
08:21:06.799 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
08:21:23.345 [dokanMount-4-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
08:21:23.345 [dokanMount-4-main] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
08:21:24.346 [dokanMount-4-main] INFO org.cryptomator.common.vaults.Vault - Unmounted vault '04_data_misc'
08:21:24.346 [dokanMount-4-main] TRACE org.cryptomator.common.vaults.Vault - Trying to close associated CryptoFS...
08:21:24.346 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
08:21:24.347 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: true
I have no clue, what is happening here. Any guesses anyone & solutions to it?
Cheers
Aphexer
