Hi, is it possible to open container on qnap server via cryptomator.apk with webdav service ?
When Qnap does support WebDAV it should work. What happens exactly?
You can enable debug mode, reproduce the problem and send us the log file: How do I enable debug mode on Android?
Hi, QNAP supports Webdav and is enabled on https port 5001.
Shared folder name: Test
QNAP local adres: https://192.168.1.120
After put this https://192.168.1.120:5001/Test to Create cryptomator vault in Cryptomator.apk I see application error.
Okay. As mentioned before, can you please enable debug mode, reproduce the problem and send us the log file so that we can narrow down the problem.
Ok, I’ll back after weekend and will try do this.
