Hi, since until 1.4.11 Cryptomator showed a message each time a new version was available. Since 1.4.11 it doesn’t do it anymore, even though “Check for update” is checked. Does anyone have the same problem ? Nothing in my config changed since 1.4.11.
Could you please look inside the log file? Maybe there is a message that the update check failed for some reason.
