Buying a license with cryptocurrency
Hello!
I already searched the forums and saw that you have your reasons why cryptocurrency isn’t an option for purchase. However, I was wondering, if you make exceptions to this if contacted directly.
I would donate 20 euros or something (or the exact amount, all is good) and send info your way (I assume Coinpayments gives a receipt with a reference or something).
I unfortunately cannot use a card. If this is not possible, then that’s alright too.
Thanks!
For others seeing this post: You can buy the supporter certificate and the android coupon code for the apk with crypto currency, see thread Purchase licensce/supporter certificate with cryptocurerncy
