Hello, I wand to buy a license with bitcoin. Better if you make implementation without third party services.
We don’t accept cryptocurrency ourselves, but we have a reseller who does:
https://digitalgoods.proxysto.re/?lang=en
Hi! I just bought a license on digitalgoods.proxysto.re, entered it to android app and got an error message that my license is invalid… why so?
My app is installed from F-droid.
Have you purchased an Android license key or desktop supporter certificate?
I’ve purchased “Cryptomator for Android License Key (Coupon)”.
Just sent you a direct message
For others stumbling about the same problem: What you buy on https://digitalgoods.proxysto.re is a coupon code. Use it on https://cryptomator.org/android/ during checkout to retrieve a license key for the Android app.
I have the same problem I purchased a desktop supporter certificate
and got a code from digitalgoods.proxysto.re
where do I apply this on the software?
Hello, would you mind giving some more details on how to retrieve the actual license? I purchased the Cryptomator for Android License Key (Coupon) and I tried to enter that code on the checkout form on Cryptomator for Android in the “Add Discount” field but it says “You need to enter a valid coupon code.” Am I doing something wrong?
It should work exactly as you described it. Can you send me please the coupon code in a direct messsage or via support@cryptomator.org ? Then we’ll have a look at it.
